Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. Apr 24, 2022 at 12:52 PM
    Rannyhill
    Rannyhill [OP] Well-Known Member
    2021 Silver Sky TRD Sport 4wd
    Long time lurker here, first time poster. I wish my first post was a positive one but stuff happens. Took my one year old 2021 TRD Sport 4wd in for its first oil change this week just shy of 7,000 miles to the dealer. It’s a dealer me and my family have purchased multiple vehicles from throughout the years with no issues until now.
    I left the service department and traveled approximately 4 miles and heard an engine knock, almost like a brief octane issue. About a mile later approaching a 4 way stop, the engine started knocking horribly with the simultaneous appearance of warning lights on the dash (check engine, oil). I stopped as soon as possible in a parking lot and got out to inspect the issue. Underneath, oil was completely coating the underside including the rear axle and fuel tank. Any opinions on degree of possible engine damage?
    I called the dealer immediately who dispatched a tow truck to bring me and my truck back. They immediately put me in a loaner truck and said they would be back in contact. I would love to hear some advice from you guys about how to proceed from this point. My initial thought is that since my truck is still basically a new truck that it should be replaced with a new one. My plan was to give this truck to my son in 3-4 years and get a new Tacoma.
  2. Apr 24, 2022 at 12:57 PM
    Buckfat
    Buckfat Well-Known Member
    N GA
    2019 DCSB OR
    Find a good attorney.
  3. Apr 24, 2022 at 1:00 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    my guess is they will fill it with oil and this time tighten the filter canister cover and drive it a good bit and if no sign of a knock they will say your truck is ready to pick up. let us know what happens.
  4. Apr 24, 2022 at 1:01 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Ouch. WTF.... that sucks. But as you say shit happens. All you can do now is wait to see what the dealer says. Their move. Keep us updated. I know I wouldn't be happy at all either.
  5. Apr 24, 2022 at 1:04 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Sub’d for outcome. Sounds likely that your engine would be replaced, but who knows until the dealer takes a look.
    Would you be satisfied if the engine was replaced and you were in an equivalent loaner during the repair? I don’t know if a dealer buy back is common in a situation like this.
  6. Apr 24, 2022 at 1:04 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    DOCUMENT EVERYTHING. Keep all correspondence, everything. Hopefully they will replace the engine...no oil, all the engine bearings will be bad and engine is basically trash.
  7. Apr 24, 2022 at 1:07 PM
    Rannyhill
    If it was an older truck I’d have no problem with an engine replacement. Since this is an almost new truck that I intended to pass down to my son I’d be very concerned about issues cropping up down the road.
    cgs2k2, OZ TRD, wi_taco and 3 others like this.
  8. Apr 24, 2022 at 1:10 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    If they had run the engine and checked for leaks like they are supposed to, this would not have happened. Full negligence on part of the dealer.
    Do not accept the truck back without a boroscope of the cylinders, compression test, and oil analysis reports. These engines have a coating applied to the pistons so will run a long time starved of oil. I would guess you were past the point of no return if the engine was knocking.
  9. Apr 24, 2022 at 1:10 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    A potential solution would be an extended warranty.
  10. Apr 24, 2022 at 1:12 PM
    Bishop84
    Bishop84 Well-Known Member
    So usually what happens is they replace the engine it and offer extended warranty.
    Ideally you want them to buy it back and set you up with a new model.
    Worst case scenario is they fix it with a new oil change and send you on your way.
  11. Apr 24, 2022 at 1:20 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I would not accept ANYTHING less than a new engine replacement and an extended warranty. Whether the damage to your current engine shows up now or in 50,000 or 100,000mi, it will show up. Good luck OP.
    RJR9603, BRFab, henryp and 10 others like this.
  12. Apr 24, 2022 at 1:24 PM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    I would want the engine replaced (new) and under body washed. Give me a loaner until the truck is ready. Keep us posted as to what they offer you. Not sure you need an attorney at this point.
  13. Apr 24, 2022 at 1:29 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip: sorry this has to be your first post.
    Not to immediately throw the dealer under the bus, everyone makes mistakes, see how they handle it.
    Prediction:
    They will correct the leak and fill the oil, it will probably seem to run fine. They will clean the mess and try to send you on your way with some free future services for your trouble.
    Is it fine, maybe - we don't know.
    If it seems to run fine there is a very low percent chance they will give you a new engine or do anything further to this one.
    Politely push for a complimentary platinum warranty -- if it makes it the next 100k it probably is indeed fine.
    Please keep us updated.
  14. Apr 24, 2022 at 1:45 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Lifetime warranty on drivetrain or give me a new truck
    Merling, 1bad2k, gsubioguy and 4 others like this.
  15. Apr 24, 2022 at 2:02 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    A 7,000 mile truck that should ultimately get 300,000 miles, hmmmm. Taking any kind of warranty that expires at 100,000 doesn’t seem correct to me. Damage has occurred to that engine and may seem fine for quite some time, possibly even past 100,000 miles. At 150,000, 200,000 or more that damage which will prevent the truck from making it to 300,000 like all others will and it will be your responsibility.
    i purchased my truck for a lot of money based on it likely achieving many maintenance free miles. A truck that has an oil failure like yours likely won’t experience similar longevity.
    asuchemist, TS4x4, Junkhead and 4 others like this.
  16. Apr 24, 2022 at 2:07 PM
    Rannyhill
    Mquibble, that’s my exact concern and why I feel like a replacement truck is in order here. Also need to add that I’m that guy who parks at the far end of the parking lot to try and avoid door dings. My truck was the cleanest one on the lot when I drove it into the service department. Not a blemish on it.
    RJR9603, Radar1005, tacotoe and 3 others like this.
  17. Apr 24, 2022 at 2:12 PM
    geo8866
    geo8866 Unknown
    2019 TRD Sport cement
    They will not replace an engine if they do not find damage. They are going to redo the oil change, drive it 20 or 30 miles, and if nothing is detected, you're lucky if they offer you complementary service. Also, even a little oil makes a big mess. You did the right thing by stopping right away. All of the oil didn't necessarily drain out and you didn't necessarily cause any engine damage. As much as it sucks, I think you're getting your truck back with an apology.
  18. Apr 24, 2022 at 2:12 PM
    radclerk1
    radclerk1 Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    Trade it when you get it back after they fix it. You’ll get more now for a trade than any other time in history. Probably what you paid.
  19. Apr 24, 2022 at 2:14 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Lifetime warranty, buy the truck from you or agree on a cash payment for possible future repairs.
    GarlicFarts likes this.
  20. Apr 24, 2022 at 2:15 PM
    geo8866
    geo8866 Unknown
    I don't say this to be cruel or rude, but there is zero chance you will get a new truck.
