Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. Apr 25, 2022 at 2:52 PM
    #181
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    If the brakes on my truck fail I have an emergency brake. But anyway.
    If the e-brake fails too, I have a range of outcomes anywhere from rolling to a stop safely, all the way to death.
    If I’m in an airplane and say, lose control of a flight surface, I’m going to die.
    The point is that the outcomes of aviation maintenance and auto maintenance, done incorrectly, have completely different risk profiles. They’re not comparable.
    chuam and Sharpish like this.
  2. Apr 25, 2022 at 2:54 PM
    #182
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When I took my truck in shortly after buying it for a transmission inspection, it was documented and is still on file with Toyota . That was over 11 years ago.
    It’s not hard to obtain service records from the dealership. And when/if I ever buy another used Toyota. I’ll ask for the service records first.
    As for CarFax? I don’t know.
    TomTwo likes this.
  3. Apr 25, 2022 at 3:06 PM
    #183
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    If it was starved of oil enough to start knocking, the motor is dicked.
  4. Apr 25, 2022 at 3:08 PM
    #184
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    Do you all really think that the engine would be damaged in that short a time? I thought he was searching for opinions on what problems to look for if his dealer just added oil and gave his truck back. I think I'm going to skip my free service appointments now. As high as gas is, it's about a wash to change it myself.
    JRuss505 and TomTwo like this.
  5. Apr 25, 2022 at 3:12 PM
    #185
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Yes, the engine can be damaged in a very short amount of time. I lost the bearings in a big block that I shut down less than a second after the low oil warning light.
    Otterstuff[QUOTED] and TomTwo like this.
  6. Apr 25, 2022 at 3:16 PM
    #186
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Yes the OP engine is damaged, It may not fail right away but it definitely will fail from this
    Otterstuff[QUOTED] likes this.
  7. Apr 25, 2022 at 3:24 PM
    #187
    TnShooter
    Deogee
    STOCK
    By the time this threads ends. OP will need to start a whole new one just to update us.
    OP, I seriously doubt you’ll get a new engine if a cylinder scope and pan drop shows nothing. I’d push for that and an extension on the warranty.
    Then take the truck an run it hard a few times. Don’t abuse it. Just let the transmission shift where it wants with the pedal to the floor. If it’s going to blow, you want it to blow sooner than later.
    If it doesn’t blow, (and I doubt it will), drive the truck and forget about it.
    Or worry yourself endlessly.
    Or trade it in.
    TomTwo likes this.
  8. Apr 25, 2022 at 3:26 PM
    #188
    galaxyz
    galaxyz Well-Known Member
    2016 Tacoma TRD Off Road
    Same thing happened to me with an old jeep I had. They ended up just re doing the oil change and sending me on my way. Looking back on it, I probably should have raised hell a little more. But i never had an issue
    TomTwo likes this.
  9. Apr 25, 2022 at 3:26 PM
    #189
    Rannyhill
    Rannyhill [OP] Well-Known Member
    2021 Silver Sky TRD Sport 4wd
    What they do or do not find is unknown at this point. Based on the totality of the circumstances my money is on significant detectable damage.
  10. Apr 25, 2022 at 3:29 PM
    #190
    TnShooter
    Deogee
    STOCK
    That would be best case scenario.
    And I’d be just fine with them finding damage. Then you know the problem and how to fix it.
    TomTwo likes this.
  11. Apr 25, 2022 at 3:30 PM
    #191
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    If it was knocking, it was damaged.
    wilcam47 and TomTwo like this.
  12. Apr 25, 2022 at 3:30 PM
    #192
    TomTwo
    Bill
    I-85 Southbound
    I hope they make you whole on this, Just don't forget you are the victim here in this situation. Play your position.
  13. Apr 25, 2022 at 3:33 PM
    #193
    Rannyhill
    Then the question becomes should I trust the dealer’s findings? I would have no immediate way to contest a finding of no damage. I still have a little faith that most people will at least try and do the right thing.
  14. Apr 25, 2022 at 3:33 PM
    #194
    Sharpish
    Brian
    Ask them for a mega extended warranty at the least. The motor is likely to grenade in the near future. Unless they totally dissemble it they won’t find scorched, scored or melted main bearings etc.
  15. Apr 25, 2022 at 3:34 PM
    #195
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Dealer is probably waiting to hear back from Toyota how to best proceed. Be patient. Toyota has a specific Field Rep. for each dealership. Once you get your first answer back or "proposal" and you aren't satisfied, you can ask to contact the Toyota Rep. directly. In addition, the Dealership has Insurance. If you want a new engine or "buyout" and replacement don't be shy about asking for that. I was an Insurance Agent for 10 years that specialized in Auto Dealerships. If you go the replacement route the dealership should provide you with a loaner or rental while you wait for your new Tacoma.
    ABA180, Big tall dave and Spacecoast like this.
  16. Apr 25, 2022 at 3:35 PM
    #196
    Rannyhill
    It was knocking indeed. Surely that knocking would produce visible metal shavings and/or scarring of certain components.
    TomTwo likes this.
  17. Apr 25, 2022 at 3:35 PM
    #197
    TomTwo
    Bill
    I-85 Southbound
    If done properly they will have photos and your engine serial # included. If they really want to help you out they should invite you back to the service dept and show you the damage.
    Big tall dave and Otterstuff like this.
  18. Apr 25, 2022 at 3:37 PM
    #198
    ScrippsRanch67
    Bob
    Fiberglass shell
    You sound like a nice person, to the dealership...it's only business. Take a stance that best fits your needs.
  19. Apr 25, 2022 at 3:40 PM
    #199
    Rannyhill
    Patience is one of my few virtues. I haven’t talked to anyone from the dealership since Friday when this happened. I do appreciate your insight on what could be going on behind the scenes. I’m not sure why they would involve a regional Toyota representative when this is clearly an issue involving a mistake made by a technician during the service.
  20. Apr 25, 2022 at 3:49 PM
    #200
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Why Toyota? It’s not a warranty issue. They may be waiting to hear back from their lawyers.
