Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. Apr 26, 2022 at 8:04 AM
    #241
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    The trade-in value for the OP is the value of the truck when he drove it into the lot, not after the dealer tech did the damage. No matter the outcome, the dealer should NOT make any money on this situation. They have insurance to cover their mistake, they can fix the vehicle and sell it, and they can easily sell a new truck to the OP at their cost (which is thousands under MSRP).
    If it was me the hassle that this dealer has caused because they didn't pay and train their techs isn't going to make me whole even if I was to drive away in a new vehicle.
    AZ Pete likes this.
  2. Apr 26, 2022 at 8:18 AM
    #242
    l1011joe
    l1011joe Member
    2022 4x4 ordc automatic
    subbed for outcome and good luck op hopefully your dealer does you right and resolves to your satisfaction.
    Aqualoon and Rannyhill[OP] like this.
  3. Apr 26, 2022 at 8:33 AM
    #243
    Chris2009
    Chris2009 Well-Known Member
    Massachusetts
    2013 Reg Cab 4x4
    meh…if they give him an identical new truck I’d go ahead and call it even.:thumbsup:
    ValK83 and Off Topic Guy like this.
  4. Apr 26, 2022 at 12:04 PM
    #244
    Bigmatt503
    Bigmatt503 Well-Known Member
    Know one knows if he heard "rods knocking". It could have been many different things knocking
    TomTwo likes this.
  5. Apr 26, 2022 at 12:07 PM
    #245
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Probably his knees knocking?
    JJ Diablo and batt700 like this.
  6. Apr 26, 2022 at 12:57 PM
    #246
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Hearing knocking and then seeing oil under the truck with a warning light and low oil after an oil change seems like a reasonable person would say that was a rod knock from low oil pressure.
    batt700, Chris2009, US Marine and 2 others like this.
  7. Apr 26, 2022 at 1:00 PM
    #247
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    This thread turned into a :crapstorm: real fast. OP hopefully they might it right for you. It’s been a couple of days already and you’ve still heard nothing back? I would at the least be inquiring what exactly is going on.
    usmc2msu likes this.
  8. Apr 26, 2022 at 1:03 PM
    #248
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Why hasn't Toyota changed the design of the oil filter housing? It's been 7 years since the 3rd gen hit the market, the metal oil filter housing seems like a popular modification.
    There is no way the plastic housing is a better design.
    TomTwo likes this.
  9. Apr 26, 2022 at 1:06 PM
    #249
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Why? Do plastic ones explode?
    batacoma[QUOTED] likes this.
  10. Apr 26, 2022 at 1:09 PM
    #250
    auskip07
    Skip
    Atlanta, Ga
    Im sure it has to do with less material needed for the filter. "more green" either way they wont change it , nothing is idiot proof
  11. Apr 26, 2022 at 1:13 PM
    #251
    golfindia
    Yes.
    pickup truck
    Screwing Al into Al is suboptimal. With corrosion I bet more dum dums and techs get them stuck.
    GarlicFarts likes this.
  12. Apr 26, 2022 at 1:15 PM
    #252
    batacoma
    batacoma Truck Wars
    I don't own a 3rd gen and still want to change the filter housing. I don't like the way plastic filter housing sounds, it does not sound as durable. Plastic can get brittle and break. If the metal housing isn't prone to corrosion or rust, why not change the design. Probably wouldn't cost Toyota more than $20 per engine.
    Toyota probably only saves a few dollars per engine.
  13. Apr 26, 2022 at 1:17 PM
    #253
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    toyota says it's normal.
  14. Apr 26, 2022 at 1:18 PM
    #254
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    One plus of the plastic is if for some reason someone crossthreaded while installing, it would be the plastic canister and not the engine side.
    b_r_o, Kev250R, RustyGreen and 2 others like this.
  15. Apr 26, 2022 at 1:18 PM
    #255
    golfindia
    Yes.
    pickup truck
    Iron maiden sounds durable.
    Matic likes this.
  16. Apr 26, 2022 at 1:19 PM
    #256
    batacoma
    batacoma Truck Wars
    Is it aluminum to aluminum on the Tundra?
    If it's a bad idea why do people opt for the metal over plastic?
    JJ Diablo likes this.
  17. Apr 26, 2022 at 1:19 PM
    #257
    Matic
    Tricky Dick
    Easley, SC
    Run to the hills.
    grogorat, TacoCat and AMMO461 like this.
  18. Apr 26, 2022 at 1:21 PM
    #258
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Good point! Here's mine from today...I was curious plus I had the day off so...
    shakerhood[QUOTED] likes this.
  19. Apr 26, 2022 at 1:22 PM
    #259
    golfindia
    Yes.
    pickup truck
    Metal on metal plus water(puddles) equals corrosion.
    Don't ask me. I'm not "people".
  20. Apr 26, 2022 at 1:22 PM
    #260
    batacoma
    batacoma Truck Wars
    The plastic oil filter housing has kept me from purchasing a 3rd gen v6. I doubt if thats the sole reason, but I have thought about it when considering a 3rd gen v6 Tacoma.
