Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. May 2, 2022 at 1:41 PM
    #541
    ThAkki
    ThAkki ¯\_(ツ)_/¯
    If I was in your shoes, I’d probably just trade it in - as long as I don’t loose any money from the deal. I just don’t think I can live with the thought of my engine knocking and them telling me they didn’t find anything.
  2. May 2, 2022 at 1:43 PM
    #542
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I’m thinking now…..is this what generally happens when you find a sub 10k vehicle on a dealers lot? A honked-up service job I suppose. So many land mines to navigate during a vehicles purchase.
  3. May 2, 2022 at 1:46 PM
    #543
    Rannyhill
    Rannyhill [OP] Well-Known Member
    2021 Silver Sky TRD Sport 4wd
    It’ll be interesting to see what the report says. My mechanic buddy will be going over it to interpret what was done. The only way I see keeping the truck is if my friend oks it. In that circumstance does everyone think it would be reasonable to ask for an extended warranty if I don’t trade it?
    JRuss505, TRDSport10, TomTwo and 2 others like this.
  4. May 2, 2022 at 1:47 PM
    #544
    ThAkki
    ThAkki ¯\_(ツ)_/¯
    That is why I do not buy a used car anymore. Learned my lesson with a previous purchase. Transmission issues.
    Junkhead, TacoCat and Rannyhill[OP] like this.
  5. May 2, 2022 at 1:48 PM
    #545
    Rannyhill
    Not necessarily. The truck I traded in had right at 10,000 3 years old. Someone got a good one in that case.
    ABA180, usmc2msu and Junkhead like this.
  6. May 2, 2022 at 1:49 PM
    #546
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    For “fun”, I’m speculating that the oil filter cap o-ring was installed in the wrong spot and not in it’s proper groove. Anyone that’s read the warning on the box flap on a Toyota filter cartridge should know what I mean.
    If it were mine, I’d have them take an oil sample and cut open the pleats of the filter element to inspect for metallic particles after 100 miles or so, and again at the next oil change interval. On their dime. Any abnormal findings on the sample or glitter in the filter = bad news. If all good, put some more miles on it. Like 300K.
    Oil pressure does not lube an engine, it only gets the oil to where it needs to be to lubricate. And that lubricating oil film does not disappear in a couple seconds. Timing chain tensioners, VVTI cam phasers, and hydraulic lifters get noisy without oil pressure, and are probably what you heard when the oil pressure dropped.
  7. May 2, 2022 at 1:52 PM
    #547
    mquibble
    Michael
    2021 TacomaTRD Pro
    Perfectly reasonable and expected request. An extended warranty cost them very little. Let’s also do an oil and filter change at 100, 500 and 1,000 miles.
    Rannyhill[QUOTED][OP] likes this.
  8. May 2, 2022 at 1:52 PM
    #548
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Any damage isn't acceptable. You didn't do this, they did. They need to make (you) whole. Remember that.
    AgentCovert, JRuss505, 1bad2k and 4 others like this.
  9. May 2, 2022 at 1:59 PM
    #549
    ThAkki
    ThAkki ¯\_(ツ)_/¯
    I don’t see why it wouldn’t be reasonable to ask. I know it’ll give me peace of mind if they do extend my warranty.
  10. May 2, 2022 at 2:12 PM
    #550
    GarrettTacoma
    GarrettTacoma Well-Known Member
    2022 2.7L SR DCSB 2022 TRD OR DCLB
    Yes sir - totally agree
    Otterstuff and TomTwo like this.
  11. May 2, 2022 at 2:26 PM
    #551
    Tradbow
    Tradbow Active Member
    Phil
    This has been an interesting thread to watch. I have never let the dealership touch my vehicles, except for Warranty issues. I think the OP has been patient with the dealership and they need to make this right. I probably would trade in as well if I got a fair price on both the trade and the new vehicle.
    TomTwo likes this.
  12. May 2, 2022 at 2:32 PM
    #552
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Being a former Toyota technician. If they didn’t pull the oil pan and and rod caps, and main bearing caps and inspect, if they didn’t pull valve covers and inspect cam journals at minimum thats not an acceptable inspection imo.
  13. May 2, 2022 at 2:51 PM
    #553
    Lambo9418
    Lambo9418 Well-Known Member
    JP
    Black 2019 TRD Pro
  14. May 2, 2022 at 2:51 PM
    #554
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    would be nice to know where it was leaking from. if that is not stated in this "report" then they are covering something up, IMO
  15. May 2, 2022 at 3:26 PM
    #555
    RDW59565
    RDW59565 Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    So.....they will be showing you the borescope video, the results of the differential compression test, and the oil analysis of the oil that was left in the engine (if none in the pan, then of the oil in the filter housing)????
    Obviously, if you go with plan B, the value of your trade will be AT LEAST equal to the price you originally paid.
  16. May 2, 2022 at 3:37 PM
    #556
    Rannyhill
    All that remains to be seen. Unless I’m completely convinced a thorough inspection has been performed AND an extended warranty is put in place sufficient in length to give me peace of mind, on to plan B.
  17. May 2, 2022 at 5:05 PM
    #557
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Ditto....I've said that before...they should make ZERO money on any deals.
  18. May 2, 2022 at 5:12 PM
    #558
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    This is a great point, report should include where its leaking from. Don't think I've heard this mentioned before in this thread, and should be top of the list, one of the first things the dealer reveals.
    Rannyhill[OP] likes this.
  19. May 2, 2022 at 5:15 PM
    #559
    Rannyhill
    In my follow up email I specifically asked for the cause of the leak to be stated. We’ll see if it’s included. Hopefully I’ll get it sometime tomorrow.
  20. May 2, 2022 at 5:21 PM
    #560
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    it makes no difference, still his fault
