Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. May 2, 2022 at 5:23 PM
    #561
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    I don't think an extended warranty will give you any piece of mind. Every time you hear a sound or the engine uses some oil, you'll have it in the shop. And I probably would too.
  2. May 2, 2022 at 5:32 PM
    #562
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i dont like this for you at all. More needs to be done. In my area you cant find a 4x4 on a lot. So its months with an order to replace that truck.
    Otterstuff likes this.
  3. May 2, 2022 at 5:37 PM
    #563
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    There are so many different variables and possible outcomes here that I think the only thing to do is hold tight, read the inspection report once complete, post it here, and go from there. This thread is slam packed with speculation of all sorts and very few hard facts to go on, yet.
  4. May 2, 2022 at 5:46 PM
    #564
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    You bring up good points as an experienced tech.
    These inspection processes/results should be in the report at a minimum.
  5. May 2, 2022 at 5:54 PM
    #565
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Correct. When OP shows up, if at minimum. If the rod caps and bearing, the main caps and bearings, cam shafts and journal caps aren’t sitting on a bench, I’d say call me when those are off and walk out. Under no circumstances is a visual inspection with a borescope acceptable.
  6. May 2, 2022 at 6:00 PM
    #566
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Did you laugh?
  7. May 2, 2022 at 6:01 PM
    #567
    Rannyhill
    Rannyhill [OP] Well-Known Member
    2021 Silver Sky TRD Sport 4wd
    If I had to guess it was scoped with none of what you’ve suggested being done. This is based on my conversation today. That’s why I requested the report be emailed so I can bounce it off of my new knowledgeable friends here on TW.
  8. May 2, 2022 at 6:01 PM
    #568
    Rannyhill
    Yes. The timing was impeccable.
    Junkhead likes this.
  9. May 2, 2022 at 6:25 PM
    #569
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    or tries to hide if it was the fault of the dealer and not a fault of something bad from the factory.
    if corporate toyota says it is tech error they might try and leave the dealer to resolve it. would think the dealer would have some kind of malpractice insurance for this kind of situation.
  10. May 2, 2022 at 6:49 PM
    #570
    Chris2009
    Chris2009 Well-Known Member
    Massachusetts
    2013 Reg Cab 4x4
    The dealer will now dig their heels regarding their findings even though it is simply not possible that running that engine without oil didn’t cause damage.
  11. May 2, 2022 at 6:52 PM
    #571
    Rannyhill
    That’s exactly why if I ultimately decide to keep the truck I’m asking for a mega extended warranty so they’ll have an opportunity to back up that “finding”.
    Junkhead and TomTwo like this.
  12. May 2, 2022 at 6:56 PM
    #572
    Chris2009
    Massachusetts
    2013 Reg Cab 4x4
    How much warranty are you going to ask for? Isn’t their longest 7 years 130k miles? If that works for you, great, but that’d be a no-go for me.
  13. May 2, 2022 at 6:59 PM
    #573
    Rannyhill
    I’ll just have to feel them out once I have time to digest the report. Once I post what was done I’m sure the experts here will quickly weigh in on whether what they did would be considered a proper inspection or not.
  14. May 2, 2022 at 7:14 PM
    #574
    gotoman1969
    Definitely curious to see what they did.
  15. May 2, 2022 at 7:23 PM
    #575
    Chris2009
    Massachusetts
    2013 Reg Cab 4x4
    If for no other reason than to hash this out - I guess what I’m getting at is what’s the point of a 100k warranty on an engine that has proven itself good for hundreds of thousands of miles if treated right? This one experienced some childhood trauma so there’s no telling what the future holds for it but the dealership just showed you their cards by claiming there was no damage. They’ll dig their heels in on that now. In the interest of saving you time - I’d grab the highest ear you can (this guy undoubtedly knows your story) and ask that they exchange the truck for you. It was new when you brought it in, damaged goods on the way out. If they still don’t see it your way I guess you live with it or lawyer up after having independent analysis done.
    TRDSport10 and RedDemolisher like this.
  16. May 2, 2022 at 7:50 PM
    #576
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    In my opinion (which obviously means nothing); this is a very generic answer given to you solely to see if you'll go away or dig in your heels. I'm sure they're hoping you'll accept their response and go away.
    woods_24, usmc2msu, Junkhead and 3 others like this.
  17. May 2, 2022 at 8:48 PM
    #577
    ScrippsRanch67
    Bob
    Fiberglass shell
    The Dealership most likely has Insurance for this type of event...might be a huge deductible!
    shakerhood likes this.
  18. May 2, 2022 at 8:56 PM
    #578
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    Not being in the middle of this, I can't know for sure, but I sense that you are right. I have been waiting -- and have thought the OP was doing the right thing -- until the dealer showed their hand. And, now they have. They have shown you that they find no damage -- which means their opening salvo is a big "you get nothing." They may or may not be serious about that -- as you suggest they could be testing you to see what they can get away with.
    I would tell them to send you the report (as you did) but also send a message to them that you are disappointed in their response, you have very serious doubts about the technical review that they did, and, of course, they have an incentive to say everything is fine because it is in their interest to do so. I would let them know that their response cannot be trusted and that you are looking at all of your options, including everything from a second opinion to downright legal action. You should then let the sales person know they are playing games and that you are prepared to respond accordingly -- and see if the salesperson can get that message to them.
    So here is where we are: 1) They have now taking a position (the truck is find, pound dirt). You now need to look at your range of options, including getting a second report from an independent source, trading in the vehicle, pursing the issue with Toyota, looking at potential legal remedies, etc. You don't have to threaten them. Just let them know this is what you are looking at and how they respond to your concerns will determine your course of action.
    They have revealed themselves and their position seems terrible ... the burden is on them to prove the test was exhaustive. And in the end, they have an incentive for the engine to be okay. If I was in your shoes, I would ask the truck be delivered to place where you can get a second opinion from a Toyota Certified Master Mechanic. See how they respond to that ...
    Oh. And let them know the cost for the full engine review from a second source should and will be paid by the dealer.
  19. May 2, 2022 at 9:18 PM
    #579
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If the dealer says there's no damage, you have 60,000 miles to prove them right or wrong! Drive the truck until the expiration of the powertrain warranty or whatever extended engine warranty you're able to negotiate. Trade it in or sell it private party at that time.
    na8rboy and Kev250R like this.
  20. May 2, 2022 at 9:23 PM
    #580
    DJR81
    DJR81 Well-Known Member
    2013 5 lug 4 speed auto
    What made you trade that one in? Essentially a new truck still
