Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. May 3, 2022 at 8:48 AM
    #621
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    It snows in Maryland, Virginia and North Carolina. All three states south of Delaware.
    TRD-ED likes this.
  2. May 3, 2022 at 8:51 AM
    #622
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    This could be true ... and for you I sincerely hope that it is. But I think your next move is to tell them you don't think this is a comprehensive review. At this point, you are requesting the truck be sent to a Toyota Certified Mechanic to conduct a thorough test -- and the cost of that should be covered by the dealer. If it comes back from that second opinion okay then ask for the lifetime engine warranty to be safe.
  3. May 3, 2022 at 8:52 AM
    #623
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Agreed....the original poster has been made whole? Issue resolved?
  4. May 3, 2022 at 8:54 AM
    #624
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    The work was done at the dealership... but the part that failed was an approved and authorized Toyota component installed by an approved and authorized Toyota dealership according to Toyota recommendations.
    Junkhead and Tacoma Mike like this.
  5. May 3, 2022 at 9:00 AM
    #625
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Me too.
  6. May 3, 2022 at 9:01 AM
    #626
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    they said its fine because no lights are on the dash.
  7. May 3, 2022 at 9:06 AM
    #627
    Rannyhill
    Rannyhill [OP] Well-Known Member
    2021 Silver Sky TRD Sport 4wd
    Posts concern the 21. I had an 18 prior to my 21. The oil issue pertains to the 21.
    Kev250R and Junkhead like this.
  8. May 3, 2022 at 9:07 AM
    #628
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Firstly, its not my vehicle, and I'm not the OP, so I've not once claimed that.
    Secondly, I'm just here for discussion; I'm okay with being wrong and eating my words. If fine print says its technically a warranty issue, cool; that doesn't change the fact that the engine ran with no oil, to the point of knocking, and they claim it to have no damage because they refilled it with oil, with no actual inspection for damage.
    Thirdly, eat a snickers
    Fourthly, just for fun and conspiracy, if they had an opportunity to make money off of the situation, why wouldn't they, unless it pointed to some sort of admission of fault?
  9. May 3, 2022 at 9:08 AM
    #629
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    My worthless opinion once again...
    I'd consult an attorney (first visit should be free) and let he/her tell me my legal options, and then make a decision on how/if I wanted to move forward. Then I'd stop posting on TW until a solution has been resolved.
    Unless you're comfortable with the information the dealership has given you; in which case, it's a done deal.
    Best of luck to you.
    I'm sure we all want the best outcome for you, but we're really just a bunch of internet dumbasses.
  10. May 3, 2022 at 9:08 AM
    #630
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    So the OEM plastic housing unit may have been over-torqued, causing the cut in the unit? Maybe it was a slow leak that got bigger as the heat affected it.
    Can they provide photos?
    I'd also ask for a second opinion from another Toyota dealership.
  11. May 3, 2022 at 9:10 AM
    #631
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    How did they check for metal? I'd be asking for an independent oil analysis (like from Blackstone) that shows no abnormalities in the oil. If that comes back good, I'd personally feel fairly confident that there was no MAJOR damage. But, I'd still expect an extended warranty. Just looking at the oil and saying it looks fine is just not enough.
    Depending on how long you drove it while it was oil-starved, it might be fine.
    Bigmatt503 likes this.
  12. May 3, 2022 at 9:13 AM
    #632
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    The only way to inspect the engine is to remove parts....pull the oil pan, disconnect main bearings, rod bearings, inspect and measure, pull valve covers, inspect cams, etc, etc. I really wouldn't want that to happen to my new truck. So....two options....
    1) Consider the engine unharmed but demand and receive an engine warranty along with an acknowledgement from the dealer that they caused a "lack of oil" incident, so that any future engine problems are by default the result of this and thus will be covered.
    2) Or....tell the dealer that you want a new truck. The deal would be full trade-in value along with the new truck at dealer cost.
    You...not the dealer....needs to decided what you prefer.
    I do NOT recommend an engine inspection since that requires a true tear-down to determine damage. It only takes one trashed bearing to cause a major future issue, and that could be tough to find without a detailed tear-down.
    Make it easy on yourself...at least demand the dealer put in writing that their work resulted in a "lack of oil" incident and that any engine problems will be due to this incident and thus covered. That in turn will push them toward option 2, which is a new vehicle. If I was the dealer that's the direction I would want to go...it gets rid of the problem and costs almost nothing. Your trade now gets sold to someone else, and any engine problems (if any) gets covered by Toyota under warranty, not the dealer. In other words, the dealer should be motivated toward option 2 as long as you demand option 1 as a minimum.
  13. May 3, 2022 at 9:14 AM
    #633
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    if there's "no" damage i'm sure they wouldn't mind buying it back...lol
  14. May 3, 2022 at 9:16 AM
    #634
    SpikerEng
    SpikerEng Well-Known Member
    Leon
    Portland, OR
    "Absence of evidence is not evidence of absence", especially when one doesn't bother to look for the evidence very closely.
    I've spent decades in the aerospace industry (granted, a bit different from automotive), and the logic is always that if something anomalous happens, you have to prove that no damage occurred. Of particular importance for a device that is supposed to last for millions of revolutions (your engine) is to prove that no damage occurred that would affect the life expectancy of the device. We would typically require a life test to be conducted of a similarly damaged device, for twice the number of expected cycles. So if Toyota can prove to you that you can run an engine with no oil for 5-10 minutes, and then still be good for 200K-300K miles, then you can take their word for it. Otherwise, they have no idea what the incipient damage may be.
  15. May 3, 2022 at 9:16 AM
    #635
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Their response is the equivalent of a doctor telling you that the cough you are complaining about is nothing, don't worry about it.
    Oil pressure starvation damages plain bearing surfaces by smearing the soft metal surfaces. Plain bearing engines like your Tacoma need significant (30-50 PSI) to provide the thin shear film between the bearing surface and the crankshaft journal. That thin oil film is the actual bearing, no matter how many "experts" on here claim otherwise.
    Plain bearings damaged by momentary oil starvation do not fail immediately. If damaged (highly likely) the bearing surface(s) have been galled, maybe the journals have been as well. There will be very little chance of freeborn metal particulate in the oil...now. But it will over time shed small pieces as the rotating (formerly glass smooth) surfaces polish away the displaced bearing alloy. The damaged surface will also be unable to properly maintain the thin shear film, it will excape past the damaged surface. The damage will continue until it is severe enough that it will become apparent something is wrong. How long that takes is the unknown. Unless the main caps and rod end caps were removed and each bearing removed inspected (journals too) they don't know anything, they're guessing.
    A roller bearing engine is rare in automobiles and multi cylinder vehicles in general, but very common in single cylinder high performance engines like Moto-X bikes, high HP go carts, etc. The Suzuki GS1100 engines from the 80's is an exception, it had a roller bearing crankshaft and rods. This required the crankshaft to be made in multiple pieces. The rods and bearings would have the journals fit is place then press the journals to the crankshaft counter weights and end journals to make the assembly. Suzuki's specification for oils pressure was 2.5 psi - 7 psi. Roller bearing just need to be wet with oil.
    TLDR: Tell the dealer since the engine is in perfect condition, he won't have a problem selling for you at top dollar, then applying the proceeds towards your new Tacoma. I'll drive the loaner until you sell mine. Thanks.
  16. May 3, 2022 at 9:17 AM
    #636
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    1. This is the dealer's fault. The tech didn't ensure the O-ring was seated in the correct groove on install. The tech also didn't check the filter housing for leaks after.
    2. What did the dealer offer as compensation? Has an extended powertrain warranty been agreed to? Remind them of item 1. above and remind them an extended warranty costs them nothing up front.
    3. All the people demanding engine teardowns, new truck, etc. aren't being realistic in a shop environment. Remember the truck is yours until you sell it, then it's someone else's problem. Drive it until the factory powertrain warranty or the negotiated extended warranty expires, whichever is longer, then unload the truck at market value.
    Kev250R and JJ Diablo like this.
  17. May 3, 2022 at 9:38 AM
    #637
    Spacecoast
    2022 White SR5 2.7L
  18. May 3, 2022 at 9:47 AM
    #638
    DonNH
    DonNH Well-Known Member
    Don
    Southern NH
    90 xcab>01dcsb>14dclb sport
    A lot of comments about getting the extended warranty, but as has been alluded to in a couple posts, that brings its own set of challenges -
    If it's a Toyota warranty and the engine fails (or just starts to consume more oil - I've got over 100K on my engine and it doesn't consume any
    noticeable oil, but I think Toyota will say 1 quart in 5,000 miles is "normal"), they still may go back and say it's the dealer's problem, or scrutinize
    all the maintenance records for some reason to deny.
    If it's a dealer warranty, they still have to be in business when the problem comes up, as well as not trying to get out of it based on maintenance
    records, etc.
    You could be stuck having to get all your future service performed by that dealership exactly at the scheduled times in order to feel confident that
    they won't find a way to back out.
    Big tall dave likes this.
  19. May 3, 2022 at 10:06 AM
    #639
    clg
    clg Well-Known Member
    2017 Off-road
    Do NOT request an inspection of the engine that isn't a tear down, that right there is as close to OJ trying the glove on as it gets. It takes them a week to drain and fill the oil without finding metal, and people recommend boroscoping an engine when you wouldn't even see wear to bearing surfaces? Give your heads a shake.
  20. May 3, 2022 at 10:23 AM
    #640
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    I would not sleep at night. Sell it to Carvana and get a different one.
    jetfishn likes this.
