Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. May 13, 2022 at 1:09 PM
    #1021
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I'd point you towards some Highlander forums or other Toyota makes with aluminum housings, but it probably wouldn't change your mind. And I don't mean that in an arguable way, I mean even though it happens, it won't be enough to turn the average person (you or me) away.
    PokerPilot likes this.
  2. May 13, 2022 at 1:12 PM
    #1022
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Sorry bruh, dont have this. But what I do have a shit ton of experience getting apart galled aluminum hardware.
  3. May 13, 2022 at 1:13 PM
    #1023
    saint277
    saint277 Vigilo Confido
    You've galled this housing or seen others do it?
  4. May 13, 2022 at 1:56 PM
    #1024
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    WooHoooooo!!!!
  5. May 13, 2022 at 2:04 PM
    #1025
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Just picking a post to reply to here with a thought. I think the underlying problem with the housing is, there are no instructions anywhere to lubricate that new o-ring. Am I correct? What I do is 1.) lubricate that o-ring while in the housing, and 2.) lubricate the inside walls of what the housing screws into (Mounting, engine, whatever it's called). I imagined a twisted 0-ring from first day I changed my own oil in this 2020 Tacoma, it's just logical, if that o-ring goes in dry in my opinion I think that o-ring could get bunched up or pinched during install.
    Big tall dave likes this.
  6. May 13, 2022 at 2:11 PM
    #1026
    saint277
    Most of the filter kits come with install instructions, on the topic of lubrication there should be plenty of residual oil inside the housing. You should still lubricate the o ring with new oil, but unless you cleaned the housing out with solvent and an air gun its not going to be dry when it goes in even if you forget. Not twisting the o ring is good and I think this is were most people would mess up.
    thomasburk[QUOTED] likes this.
  7. May 13, 2022 at 2:24 PM
    #1027
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    you mean like getting spark plugs out of an aluminum head? i experienced that once and it sucked since i was changing the plugs on a girlfriends 2nd gen T-Bird. got them out but i thought i screwed up big time getting the first one out.
    golfindia[QUOTED] and wilcam47 like this.
  8. May 13, 2022 at 2:35 PM
    #1028
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Yup, I believe there’s even a torque spec for the valve cores in the tires nowadays.....
    Times have changed and these are some crazy days we’re living in.......Lol
    wilcam47 likes this.
  9. May 13, 2022 at 2:37 PM
    #1029
    saint277
    I just used to use my 1/2 impact gun to install those cores, now the boss makes me do it right.:mad:
  10. May 13, 2022 at 2:39 PM
    #1030
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  11. May 13, 2022 at 3:04 PM
    #1031
    golfindia
    Yes.
    pickup truck
  12. May 13, 2022 at 3:44 PM
    #1032
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I like to think of them as darwin award winners in the waiting
  13. May 13, 2022 at 3:52 PM
    #1033
    TACO-TY
    TACO-TY Not so well-known member
    Tyler
    Eastern WA
    '24 SR6-MT DCSB
    GOOD LUCK @Rannyhill I hope you come out ahead! I'm out! Your thread is officially jacked.
    :stayontopic:
    mardis928 and Big tall dave like this.
  14. May 13, 2022 at 5:31 PM
    #1034
    PokerPilot
    PokerPilot Well-Known Member
    I'd like OP to weigh-in and let us know if he's seen his truck yet. I'd especially like to know if it looks like it has a drain plug in it or, if it does, does it look new? I still am suspicious about the convenient nick on the o-ring. If OP see's the engine and believes it is the old plug I'll be a believer in the o-ring thingamadingy.
  15. May 13, 2022 at 5:42 PM
    #1035
    PokerPilot
    I've got a question. Let's assume the oil change was executed perfectly but the supplied/new o-ring was defective with a nick in it. Let's also assume that the nick was such it is reasonable for someone not to notice it. What would everyone's expectations be then? Would we all be thinking the dealer alone should make it right or do we believe it is a warranty issue from Toyota because their oil filter was defective? The reason I ask is that if we begin leaning toward Toyota why would the dealer be the one coming up with the solution rather than Toyota. Because the solution seems to be coming from the dealer I lean more to side that implicates their culpability rather than the filter manufacturer.
    Travlr likes this.
  16. May 13, 2022 at 5:46 PM
    #1036
    saint277
    You would somehow need to prove the part was defective preinstall, Toyota would certainly deny it was otherwise and blame the installer.
  17. May 13, 2022 at 5:48 PM
    #1037
    Bishop84
    Bishop84 Well-Known Member
  18. May 14, 2022 at 5:25 AM
    #1038
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    It doesn't matter. Part of the procedure is running the truck and checking for leaks. They didn't do that.
    cryptolime, TacoCat and Big tall dave like this.
  19. May 14, 2022 at 5:44 AM
    #1039
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Impact guns dumb everyone down, so it’s a close call on that 3%
    44-16 Taco likes this.
  20. May 14, 2022 at 7:00 AM
    #1040
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Anyone that uses an impact gun on an oil filter canister is beyond the 3% threshold and is a moron.
    Lt. Dangle, 44-16 Taco and Travlr like this.
