Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. May 14, 2022 at 7:08 AM
    #1041
    Chris2009
    Chris2009 Well-Known Member
    Massachusetts
    2013 Reg Cab 4x4
    It’s been more than 20 days. Nuts that this hasn’t been resolved.
    cryptolime, TacoCat and kahanabob like this.
  2. May 14, 2022 at 7:18 AM
    #1042
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    If the O-ring survived being stretched over the housing and worked into the ring groove, it would have done the job. Cut, nick whatever if the material was in place it would have compressed and sealed. A severely compromised O-ring would have broken during installation.
    Even if the O-ring was faulty, the critical act was the tech did not perform a leak check after the service.
    This is on the 100% on the dealer. The dealer may blame the O-ring, the filter, the design of the housing and probably Trump too when he's trying to browbeat OP into believing the idiotic excuse...but he knows better and will not ask Toyota to cover his screw-up.
  3. May 14, 2022 at 9:26 AM
    #1043
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i have been corrected, the T Bird was the new look version that came out in the early 2000's.
  4. May 15, 2022 at 9:32 AM
    #1044
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I did my oil change yesterday (first time in a really long time that I’ve done my own) and used a torque wrench on the canister. It ‘clicked’ right about the time I was thinking “that’s just about right”.
    I think the problem with the dealer guys is they do so many, they think they can do them with their eyes closed and are busy chatting with their stall buddies and listening to their EarPods.
    jackn7 and Superdave1.0 like this.
  5. May 15, 2022 at 9:40 AM
    #1045
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    I don't understand why we have to torque everything now. Any good mechanic can tell how tight something needs to be, based on the material. You don't tighten brass, copper, or plastic the same as hardened steel. Maybe it is inexperience or too many YouTube videos causing this.
  6. May 15, 2022 at 9:44 AM
    #1046
    la0d0g
    running for the hills
    For crawling not hauling
    There's nothing wrong with doing something to spec.
  7. May 15, 2022 at 10:13 AM
    #1047
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Mongo dont know own strength
    jackn7, 44-16 Taco, Travlr and 9 others like this.
  8. May 15, 2022 at 10:17 AM
    #1048
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I’ve always done all my own maintenance and I can fix most things I have the proper tools for, but I wouldn’t insult real mechanics by calling myself a “good mechanic”. I bought a torque wrench years ago for the sort of stuff they’re really needed for (camber bolts, crankshaft pulleys, lower ball joint bolts, etc…). But since I have one, I’ll use it on stuff that I could do without it, but I figure why not be exact? I’m not gonna bust it out to make sure my coolant overflow tank is torqued to the right ft. lbs., but for things like diff drain plugs, u-bolts, thermostat housings, etc… I think they’re nice.
  9. May 15, 2022 at 10:24 AM
    #1049
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Classic signs of an inexperienced tech..
    over-tightening the shit out of tiny bolts and leaving big bolts loose
    Generally speaking, the size of the fastener determines the range of torque
  10. May 15, 2022 at 10:32 AM
    #1050
    kahanabob
    Maui
    16 TRD 2WD 4DR
    what is the correct torque setting? thanks
  11. May 15, 2022 at 10:33 AM
    #1051
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I have torque wrenches and do use them when they are really warranted. But for routine stuff like basic maintenance that I have done a bazillion times (like oil changes), I usually just employ the "ugga" method. Light duty stuff gets a single ugga, medium duty stuff gets a double ugga; you get the point.
    PS: Your Ugga mileage may vary!
    jackn7, Travlr, Rock Lobster and 5 others like this.
  12. May 15, 2022 at 10:35 AM
    #1052
    Otterstuff
    How is the the correct torque setting determined and by whom? Again we could be dealing with an engineer that really isn't the best at his job.
  13. May 15, 2022 at 10:39 AM
    #1053
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Equipment has changed quite a bit over the years. Engines, transmissions and even transfer cases were manufactured from cast iron years ago. Almost everything on an older vehicle was more forgiving to ham handed treatment than it's modern replacement.
    As a semi-relevant example: In the early 80's Chrysler 4 cylinders used torque to yield head bolts, they were one time only use, the replacements cost about $18 for the set from Chrysler IIRC.
    "Good, experienced" mechanics didn't read the manual because it was "just a head gasket -- done 100's of em" and reused the bolts. That lead to repeat failures. 5 minutes of reviewing the manual and $18 could have saved the customer return.
    Manufacturers provide specifications for torque, lubricants, procedures, etc. -- sometimes they really don't matter that much, it is prudent however to look them up and make a conscious decision regarding them rather than simply going by experience alone. Usually following the published procedure will insure a successful outcome.
    AgentCovert and CraigF like this.
  14. May 15, 2022 at 10:42 AM
    #1054
    RustyGreen
    sleeping in a chair
    Pavement Princess
    You have to trust someone now and then -- when in doubt I think I will gamble and trust the engineers employed by a worldwide multi-billion dollar company. ;)
    jackn7, la0d0g, brian2sun and 2 others like this.
  15. May 15, 2022 at 10:44 AM
    #1055
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Excellent example. IMO for the magnitude of that job it seems prudent to replace the bolts anyway considering what's on the line, but especially since the manual dictated it.
    RustyGreen[QUOTED] likes this.
  16. May 15, 2022 at 11:34 AM
    #1056
    Otterstuff
    How many of you really think you need to torque your oil filter? The canister type has always been hand tighten in the past.
  17. May 15, 2022 at 11:44 AM
    #1057
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Agreed...instructions were to twist 1/4 turn when seal/contact is made.
    As long as you put a dab of new oil over the rubber seal, it would check good!
    Check for leaks afterwards...always!
  18. May 15, 2022 at 1:34 PM
    #1058
    kahanabob
    Maui
    16 TRD 2WD 4DR
    finally, the bottom link answered my question, 18 ft lbs..thanks
    TacoTime55[QUOTED] likes this.
  19. May 15, 2022 at 3:31 PM
    #1059
    Daffyduck
    Daffyduck Member
    2016Trd Dblcab Or
  20. May 15, 2022 at 3:32 PM
    #1060
    Daffyduck
    Daffyduck Member
    2016Trd Dblcab Or
    Why would Toyota get involved? This was all the dealers fault!
    2017 limited, TomTwo and wilcam47 like this.
