Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. May 15, 2022 at 3:43 PM
    #1061
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I've been wrenching for close to 20 years. I used to trust myself and tighten things by feel. A lot of things I still do.
    Now I use a torque wrench for engine oil drain plugs, diff drain plugs, most suspension, etc. I especially use it for the 18 ft lb on this weak canister on the 3rd gen Tacoma.
  2. May 15, 2022 at 4:03 PM
    #1062
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Sorry, just getting back online. All my reading says 25Nm, or ~18ftlb.
    Superdave1.0 likes this.
  3. May 15, 2022 at 4:05 PM
    #1063
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I torque the canister to 216 inch pounds.
  4. May 15, 2022 at 4:10 PM
    #1064
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I agree, most surfaces that gall together are different metals. Like aluminum vs steel. Or stainless steel vs aluminum. The threads on the housing and cover are very large. The aluminum cover has been used by Toyota for years without problems. The composite cover is cheaper to manufacture it’s all about money :spending:
  5. May 15, 2022 at 5:11 PM
    #1065
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    Thinking about this, rannyhill said he made it about 4 miles and heard a knock then at about 5 miles it started knocking horribly and warning lights popped up. The way the oil filter housing is designed, it has a flange that mates up to the engine, almost creating an added safety seal to prevent or slow down an improperly installed or missing seal.
    I would be curious to see how fast that much oil could leak out completely with no seal at all. And if the O-ring was installed but cut, it still filled 95% of the O-ring groove, it would be that much slower.
    This thought supports the idea maybe something else was the cause and they are indeed using the O-ring as an excuse. Maybe someone else could test this theory for us? If each member following this thread pitches in $.10, that would more than cover a new engine for the tester.
  6. May 15, 2022 at 5:13 PM
    #1066
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    How many people do you think are following this thread? For the bargain basement price of $5k for an engine you'd need 50,000 followers to pony up $.10
    jackn7 likes this.
  7. May 15, 2022 at 5:18 PM
    #1067
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Do you mean the "MX" thread in my sig?
    *MX=Maintenance
  8. May 15, 2022 at 5:24 PM
    #1068
    Superdave1.0
    SoCal
    What if the o ring becomes dislodged or damaged while turning the cap? It is a tight fit. Of course it should be lubed with oil before install. Just a thought.
  9. May 15, 2022 at 5:30 PM
    #1069
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I'm going to test that o-ring fit within the next couple of months.
    If the o-ring is lubricated with oil prior to placement on the housing seal ring, it should adjust to the twisting threads and seat properly.
    Of course, this is just speculation right now until I actually do the oil change.
    I'm not anxious to do the MX but each day, more questions come about this seemingly simple process.
  10. May 15, 2022 at 6:14 PM
    #1070
    Superdave1.0
    SoCal
    The conclusion is canister style oil filters are just too difficult for the dealer techs to handle. Too many issues with over tightening and leakage. Toyota surely recognizes this, and has returned to the regular spin on filter as seen on the new Tundra.
  11. May 15, 2022 at 6:25 PM
    #1071
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I agree with the sentiments above tenfold. If you have to refer to the book on how tight a damn bolt needs to be, you are either a novice who does not understand how to wrench by feel, or someone who has no business wrenching under the hood of a vehicle (unless you are okay with paying after the fact to undo the damages you did).
    I don't know. People will disagree with myself and the folks who wrote the statements above, but years of experience has taught me how to wrench properly, use common sense, proper judgement, and when to or not to consult with the book on things.
    Otterstuff[QUOTED] likes this.
  12. May 15, 2022 at 6:40 PM
    #1072
    TomTwo
    Bill
    I-85 Southbound
    What do you work on mostly ?
    Superdave1.0[QUOTED] likes this.
  13. May 15, 2022 at 6:44 PM
    #1073
    Superdave1.0
    SoCal
    Now 90% Tacomas. I do lift kit installs/maintenance on them weekly. Also am a personal mechanic for a guy that owns 40+ cars. 30 of them being Corvettes.
  14. May 15, 2022 at 6:45 PM
    #1074
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Sounds like a nice gig. :)
  15. May 15, 2022 at 6:49 PM
    #1075
    TomTwo
    Bill
    I-85 Southbound
    Nice! In 40+ years of turning wrenches I have worked on everything except Boats and Planes.
    I will send you a PM tomorrow with a lift question on my Truck
  16. May 15, 2022 at 6:50 PM
    #1076
    Superdave1.0
    SoCal
    What did it for me was my previous job. Was a body shop estimator for some time. Went to the Mercedes dealer to pick up a car we sent there for clearing/resetting codes. The most experienced, highest paid service tech at the dealer went around each wheel with his torque wrench to tighten lug nuts. He did that shit so fast. Didn’t have to think about it, Feel the click, next.
    Yes an experienced mechanic can and should be able to do it by feel. A quality mechanic is not ashamed to pull out the torque wrench for critical components.
  17. May 15, 2022 at 6:53 PM
    #1077
    TomTwo
    Bill
    I-85 Southbound
    Good Labor is NOT cheap!
    Cheap Labor is NOT good.
    44-16 Taco, ULURU, zoo truck and 6 others like this.
  18. May 16, 2022 at 5:37 AM
    #1078
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I believe it all boils down to "Training" and attitude.
    What kind of leadership at Toyota is in-place that focuses on training?
    I know you can train someone and sign them off but at the end of the day, does the employee take pride in ownership of a job process?
    This kind of activity seems to be prevalent at a small percentage of locations. Are these incidents reviewed/elevated to Senior Leadership for improvement to prevent mistakes?
    These are the kinds of issues that require a "Root Cause Analysis" to familiarize technicians regarding scheduled maintenance processes.
  19. May 16, 2022 at 6:16 AM
    #1079
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Lets see some pics. Ideally of C2s...
    shakerhood likes this.
  20. May 16, 2022 at 9:46 AM
    #1080
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Yep!
