Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. May 16, 2022 at 9:54 AM
    #1081
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    LOLLY, b_r_o, ColoradoTJ and 12 others like this.
  2. May 16, 2022 at 10:00 AM
    #1082
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I go by the tire-shop ugga method.
    Its two short and one long ugga, but that last ugga stays with a death grip on the trigger until the tool gets hot enough to brand your palm. Then you move one nut to the left and repeat.
    ...my spark plugs never see it coming.
    b_r_o, B1gDaddyT and 33yrsoftoys like this.
  3. May 16, 2022 at 10:31 AM
    #1083
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Didn't know that early C2s still had drum brakes. Nice pics! Looks like a cool shop. Thanks for posting.
  4. May 16, 2022 at 10:52 AM
    #1084
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    before I believe 1972, Disk brakes were an option.
  5. May 16, 2022 at 10:59 AM
    #1085
    Superdave1.0
    SoCal
    1965 was first year for disc brakes, also last year drum brakes were an option.
    StayinStock and RustyGreen like this.
  6. May 16, 2022 at 11:03 AM
    #1086
    suprafastcelica
    Tiffin, OH
    For the Corvette I'm guessing. All cars from the federal stand point had to have disk on the front at a minimum starting in 1972. I believe Dodge had an extra year for some reason.
    Superdave1.0[QUOTED] likes this.
  7. May 16, 2022 at 11:05 AM
    #1087
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    I prefer 3 ftm-lb of force.
    shakerhood[QUOTED] likes this.
  8. May 16, 2022 at 11:05 AM
    #1088
    Superdave1.0
    SoCal
    Yeah we were talking about Corvettes, but now I see your point.
    By the way the drum brakes on the c2 corvette were HUGE. Much larger than say a Tacomas rear drum brakes.
    shakerhood likes this.
  9. May 16, 2022 at 11:11 AM
    #1089
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Interesting, I did not know that. I had a '71 Mustang with drums on the front, but found out there was a '71.5 that came with disc brakes. Braking in that car was . . . interesting at times.
    shakerhood and ABA180 like this.
  10. May 16, 2022 at 11:19 AM
    #1090
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    So Rannyhill... How about an update? Have things been resolved? To your satisfaction?
    Or did did the dealership and Toyota find a way to put the problem on you?
    AZ Pete and kahanabob like this.
  11. May 16, 2022 at 11:35 AM
    #1091
    PokerPilot
    PokerPilot Well-Known Member
    But the dealer is on the record for stating it was a nicked o-ring. No need to prove anything. My point is they say it was a bad component but the solution isn't coming from Toyota. The solution is coming from the "dealer" which suggests they know the excuse won't hold up with the manufacturer but sounds more innocent to the customer.
    thomasburk likes this.
  12. May 16, 2022 at 11:41 AM
    #1092
    RVAE38
    RVAE38 Well-Known Member
    2019 tacoma
    They probably just haven't yet located another truck that had same issue.
    TomTwo likes this.
  13. May 16, 2022 at 12:14 PM
    #1093
    PokerPilot
    Funny you say this. Post #653 essentially says the same thing.
    I bet we can’t even recreate that problem. I’d even venture a guess saying if the o-ring wasn’t even installed, making it worse than a nick, that the oil wouldn’t drain all-out within the 4 miles or so you indicated you had driven.
    hfjeff[QUOTED] likes this.
  14. May 16, 2022 at 12:26 PM
    #1094
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Only one way to find out :boink: I'm not gonna volunteer. I've seen what an oil leak will do at idle oil pressures. Send it 5 miles down the road at who knows how many RPMS, I'll pass on that test. There's a reason people check for leaks immediately after an oil change. You don't wanna find out the hard way 5 miles down the road that you had a little bitty drip.
    Travlr likes this.
  15. May 16, 2022 at 12:29 PM
    #1095
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 74 VW had 4 wheel drums.
    Big tall dave and RustyGreen like this.
  16. May 16, 2022 at 12:29 PM
    #1096
    saint277
    saint277 Vigilo Confido
    orings get nicked on install, they don't come that way. Even if they did you would need to prove the installer didn't nick it on install, which unless the install was filmed you couldn't.
  17. May 16, 2022 at 12:40 PM
    #1097
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    CCTV. my guess the tech was interrupted just after he hand tightened the cap, maybe by a service writer asking a question about something else he had worked on and when he went back he forgot he did not tighten the cap. wild guess.
  18. May 16, 2022 at 12:44 PM
    #1098
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Auto trivia for the day:
    About 1976 was the last year for front drums on the domestics.
    Only on the end of model older generation cars:
    Chrysler A bodies - Dart, Valiant.
    Small AMC cars - Hornet, Gremlin.
    Ford - Maverick, Comet
    GM went all disk by 1975 I believe, the last being the Nova cars.
    TA2016 and shakerhood like this.
  19. May 16, 2022 at 12:44 PM
    #1099
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Yeah, but all this Technian had to do to prevent this entire debacle from happening in the first place was do a quick post job QC check. He would have noticed the leak (pretty sure they admitted to finding a fresh puddle of oil in the bay). Sometimes (actually most times), it's the little things!
    Travlr likes this.
  20. May 16, 2022 at 12:45 PM
    #1100
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    I don't believe the skid plate has a drain hole. You can't see a filter leak at idle with the skid plate on. Another design flaw if that is correct. I am sure the tech is not going to lower the truck, check for leaks, then lift back up to put skid plate on.
