Oil change disaster advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rannyhill, Apr 24, 2022.
  1. Apr 24, 2022 at 8:53 PM
    #101
    05 4x4
    05 4x4 Well-Known Member
    I wouldnt accept anything but a complete replacement engine. Id push for an extended warranty as well, in case oil has caused any issues with electrical under the truck. Also I would ask to inspect the engine when they have it torn apart. They are going to have to pull the valve covers to inspect the cams and also the oil pan to inspect down there... I would want to see it and bring a competent mechanic with you who can see if cams are scored, any metal bearing metal in the oil pan, etc. I would ask to even be there when they tear it down... The bottom of the oil pan might tell you a lot. If it was at the point of knocking and shaking, there cant not be damage to the cylinder walls, in my opinion....
    Rannyhill[OP] likes this.
  2. Apr 24, 2022 at 9:33 PM
    #102
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    if they are going to replace the engine they probably won’t spend the tech time to tear it down. They will just put it back in the crate and send it back as a core.
    if they do an engine replacement (as they should..it’s the right thing to do..), why add tension to the process with a supervisory visit?
    I don’t see any connectors down on the business end that would be a problem down the line.
  3. Apr 24, 2022 at 10:07 PM
    #103
    RustySocket
    RustySocket Professional Cat Herder
    SW Washington
    2022 Celestial Silver SR5 DCSB
    I had a 2006 Ford Powerstroke that dumped all it's oil on the way home from the dealership brand new rig, it had 27 miles on it. Corporate flew an engineer out to look at it and it was determined an O ring had failed on the HPFP and essentially pumped all the oil out. It left me stranded about half way home and was towed back to the dealer with a no-start condition. Between all of that stuff happening and the truck getting fixed, the owner of the dealership contacted me and basically said they would unwind the deal, put me in a new rig, and make it right. I ended up in a slightly higher trim level with some different options. I had gotten myself prepared for a battle that didn't happen.
    Be careful about threatening a to get a lawyer to early, Once you do that it ties the hands of some people that may be otherwise inclined to help you. You stated you had a good prior relationship and had purchased a few vehicles, that alone, with a cool head, will work in your favor. I was in a customer service/ sales role, but once you threatened legal action all I could do was shut up and turn it over to the staff attorneys. I always advised upset clients to let me go to bat for them first, some did, some didn't. Most businesses want to retain your relationship with them... lawyers mess things up.
    With 7K on the clock, your expectations of a new truck are probably unrealistic, but a new crate motor probably isn't and a time based only extended warranty on the powertrain at the bare minimum. Alternatively get them to trade you out of it for the depreciation into a new rig.
    Good luck and I hope it all works out to your satisfaction. Crappy situation.
    Dayen, TheAredub, la0d0g and 11 others like this.
  4. Apr 24, 2022 at 10:09 PM
    #104
    RustySocket
    SW Washington
    Lots of truth here.
    OP you have to be realistic. It's just a truck. You want to be made whole. Just say that and hold up on the lawyer until you know you need one.
  5. Apr 24, 2022 at 10:32 PM
    #105
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Best post. OP doesn't deserve to deal with this. Hell even if he had a 300K engine, the engine was ruined because of the service provided and they need to make it right. Period.
    I echo the free branny new engine, platinum warranty, and free rental until the vehicle is back to you.
  6. Apr 24, 2022 at 10:51 PM
    #106
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    This all day long. Don't even talk to them further without one. Nuff said ... MooseMan out. :hattip:
    AllTacosFloat likes this.
  7. Apr 24, 2022 at 11:06 PM
    #107
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Regardless if there is any engine damage caused or not, what would Toyota do if I were to do my own oil change, screw up the same way this dealership did?
    I would suspect that Toyota would say that I voided the warranty at this point. With that, I would suspect that Toyota Corporate won't be backing the dealership on this one either.
    Hopefully the dealership makes things right with a proper repair on the engine, and bless you with a significant warranty. If they don't then they may lose your family's loyalty in the future, as well as risk you not recommending their business to anyone in the future.
    I'd still sell it to THAT dealership after all is fixed, especially if anything pops up on Carfax that might reduce the value in any way. Then order a new one.
  8. Apr 25, 2022 at 4:58 AM
    #108
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    "Be careful about threatening a to get a lawyer to early, Once you do that it ties the hands of some people that may be otherwise inclined to help you. You stated you had a good prior relationship and had purchased a few vehicles, that alone, with a cool head, will work in your favor. I was in a customer service/ sales role, but once you threatened legal action all I could do was shut up and turn it over to the staff attorneys. I always advised upset clients to let me go to bat for them first, some did, some didn't. Most businesses want to retain your relationship with them... lawyers mess things up."
    ^^^ Voice of reason here ^^^
  9. Apr 25, 2022 at 5:11 AM
    #109
    Rannyhill
    Rannyhill [OP] Well-Known Member
    2021 Silver Sky TRD Sport 4wd
    That’s why I didn’t storm into the service manager’s office demanding stuff when I got back to the dealer. An attorney is my nuclear option that I hope is not needed. I’m in a good position IF one is needed because I have a good friend here in town who is an attorney.
  10. Apr 25, 2022 at 5:11 AM
    #110
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Yes, what RustyBucket said rings true. Do your best without the threat of lawyer.
  11. Apr 25, 2022 at 5:43 AM
    #111
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    I totally agree. Its one thing to have an oil leak after an oil change...but when you get engine noise because of that leak you now have actual damage.
    Since a new engine is in order, the question is..do I trust the dealership to remove and correctly install a new engine? Will my A/C leak, what about all the other hoses that need to be correctly installed? What other damage might occur with the engine pull and install, like paint damage around the fenders, hood, etc.
    What would I want? Answer: a different truck....not one that needs open surgery. Work with the dealer. See what they will do. If they are not reasonable, then get a lawyer.
  12. Apr 25, 2022 at 6:50 AM
    #112
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Look if the engine has any internal damage they will likely replace it, maybe with even a remanufactured one thats suppose to be good as new....thats how many warranties work. You won't be out any costs. I'd forget the lawyer for now.
    Kev250R likes this.
  13. Apr 25, 2022 at 7:06 AM
    #113
    Rannyhill
    You summed up my feelings exactly. I take extremely good care of my vehicles and not to brag, but when I rolled into the service department for the oil change I guarantee mine was the cleanest on the lot. I had just waxed it the week prior. Not a single dent or scratch on it, always garaged. The depreciation is also a concern because I’m sure an engine replacement would negatively affect the value on such a new truck.
    josefmd, mquibble and thomasburk like this.
  14. Apr 25, 2022 at 7:08 AM
    #114
    Rannyhill
    Thank you for providing some humor in this not so pleasant situation.
    RustySocket[QUOTED] and wilcam47 like this.
  15. Apr 25, 2022 at 7:16 AM
    #115
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Any updates today?
  16. Apr 25, 2022 at 7:18 AM
    #116
    USMC YATYAS
    USMC YATYAS Member
    United States
    no he should be getting a factory new engine not a reman.. unless it’s done by Toyota themselves
    Big tall dave likes this.
  17. Apr 25, 2022 at 7:22 AM
    #117
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Fight for a new engine at the least, new truck at most. Depending on how much damage it did you could be looking at an engine rebuild offer. But, IDC how good the mechanic is, it will never be the same. If they won't make good on it, complain to Toyota Corporate. If they still ignore you, lawyer up.
    Rannyhill[QUOTED][OP] likes this.
  18. Apr 25, 2022 at 7:24 AM
    #118
    Rannyhill
    Nothing so far. Truck was serviced Friday morning and I was broken down in a parking lot before lunch. It was a 3 hour wait for a tow truck but fortunately the kind folks at a veterinary office allowed me to wait in their lobby. By the time I got back to the dealer it was around 3. Shortly thereafter I was in the loaner having to hurry to pick my son up from school. Did ride by this weekend and my truck was still sitting behind the service building.
  19. Apr 25, 2022 at 7:25 AM
    #119
    TS4x4
    2018 TRD Offroad
    If he doesn't he should sell it to carmax or others immediately. Even with a *perfect* engine rebuild, there's going to be issues caused by this down the line. It's just how it is.
  20. Apr 25, 2022 at 7:41 AM
    #120
    Rannyhill
    Which is exactly why I don’t buy used vehicles.
