Oil Change from Hell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by majpooper, Mar 14, 2025.
  1. Mar 14, 2025 at 8:54 AM
    majpooper
    majpooper [OP] Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    I have been changing my oil for years - no problem.
    I saw a while back somewhere to replace the hard plastic oil filter housing with a more durable aluminum housing used on some other Toyota models. I order one but never installed it. Then there is that little plastic oil filter drain plug - supposed to make things a little less messy - drain the filter before removing it - never did that before either.
    Well yesterday I thought what the heck this aluminum housing has been sitting here with my oil change stuff for over a year why not change it out with the hard plastic one? Hummm - ever hear "if it ain't broke don't fix it." But first feeling adventurous I tried that little filter drain thing . . . . yeah that was a disaster, trying to plug it in resulted in oil running down my arm - at least the sleeve of my long sleeve tee caught most of it - I needed another oil change rag to add to the rag pile anyway. Then I couldn't pull it out to take out the filter housing. I had to pull it out with some pliers.
    But now the good part - I installed a new OEM filter in the aluminum housing. Refilled with 0-20 synthetic - basically I was done. Started her up to check for leaks and proper level and BOOM - oil all over my garage floor. Thankfully I have a Race Deck Floor. Needless to say I am back to the hard plastic filter housing and no I am not going to do the filter drain thing again.
    RunnerBlue4, 9th, tarbal255 and 2 others like this.
  2. Mar 14, 2025 at 9:07 AM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    STEELeR43, usmc2msu, kgilly and 4 others like this.
  3. Mar 14, 2025 at 9:10 AM
    lastcall190
    lastcall190 Well-Known Member
    NJ
    2023 Silver DCSB TRDOR
    Man, I've been there, complete with oil down the arm.
    I just took a length of hose, put it over the end of the plastic thing and routed it right into my drain pan. The trick I found was to not EASE it onto the housing, but I just lined it up and gave it the business and rammed it right in. If it partially connects/drains that's when the mess found me.
    At least it's done!
    Taco Egghead and Junkhead like this.
  4. Mar 14, 2025 at 9:19 AM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Weird flex on your Race Deck Floor…
    :anonymous:
  5. Mar 14, 2025 at 9:26 AM
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    so why was there oil on the floor after the start up?
    kgilly, SR-71A, Barsoom and 4 others like this.
  6. Mar 14, 2025 at 9:30 AM
    4x4engr
    4x4engr Well-Known Member
    Pete
    2017 Quicksand TRDOR 4x4
    Don't even bother with the oil filter drain plug. Just loosen the filter housing until oil drips out. I've never had luck with the plastic drain that comes with the filter but this method works for me and is mess free
  7. Mar 14, 2025 at 9:39 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    That motivX setup works really well.
    My guess for the leak is that the o-rings were on the wrong slots on the housing.
    I put the metal housing on a few year ago, then saw someone say that it a bad idea because it’s not made for the tacoma engine.
    DavesSR5, shakerhood and soundman98 like this.
  8. Mar 14, 2025 at 9:47 AM
    suprafastcelica
    Tiffin, OH
    I have the oil filter drain tool, the fumoto drain plug and the oil fill kit. I can just about change the oil without getting dirty.
  9. Mar 14, 2025 at 9:54 AM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    I know for sure it wasn't that - I've done too many oil changes to put the O ring in the wrong notch. I'm thinking I just got a housing that was not compatible - there may be an aluminum housing that is but somehow I ordered the wrong one.
  10. Mar 14, 2025 at 9:56 AM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    Yep - that's the way I have always done it. The Tacoma is the first vehicle I've owned that even had this filter drain thing. Anyway you can't teach an old dog new tricks.
  11. Mar 14, 2025 at 10:42 AM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Same here, this is my first engine with a cartridge filter. I never tried the drain that comes with the filter, the motivX works perfect.
    Which housing did you get?
    When I was looking around here for my 2017 people were ordering this oem#
    15620-31060.
  12. Mar 14, 2025 at 11:55 AM
    InThePlains
    InThePlains Well-Known Member
    I've never done it, nor have the dealer lube techs I've talked to. Totally worthless feature.
  13. Mar 14, 2025 at 12:53 PM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    well, i dunno. its friday and i feel like posting.
    if you know for sure you installed big o ring correctly, then could be wrong Al housing. I have seen something about that before.
    like one poster posted, just put a length of hose on the plastic nozzle and jam it in there before anything leaks out. if you nancy it, it will pee on you. hose gives you leverage to take it out, too. i change my oil without a drop on me or floor. hose directs to pan and care that pan is under housing when removing keeps it all clean. i have one plastic nozzle with a hose on it that gets reused over and over again. new nozzles are added to my collection.
    and happy pi day.
    edit: and there is no reason to replace plastic housing with Al if you are a careful wrencher with the right tool. :crapstorm:
  14. Mar 14, 2025 at 1:06 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    So how on earth did the aluminum housing cause a leak? If installed correctly it is no different than the composite. Sorry OP, but this sound like Operator Error versus the part causing the leak.
  15. Mar 14, 2025 at 1:09 PM
    2024OffRoad
    2024OffRoad Well-Known Member
    Let me guess without reading transmission fluid was involved
    Oh well wrong lol
  16. Mar 14, 2025 at 1:13 PM
    pdxTacoSR5
    PDX area
    before you corrected yourself, i was going to say you had a career in US politics.
    2024OffRoad[QUOTED] likes this.
  17. Mar 14, 2025 at 1:21 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Basically you were done? What does that mean, did you forget to install the O-ring for the housing?
  18. Mar 14, 2025 at 1:44 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    I don't see how the plastic one is such an issue. I think OCD people just get into this mindset. My plastic OEM one works just fine.
    Junkhead, TacoTime55 and Koolbreeze7 like this.
  19. Mar 14, 2025 at 1:46 PM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    2 words: MotivX kit
    OldSchlPunk, skidooboy and soundman98 like this.
  20. Mar 14, 2025 at 2:13 PM
    TheGrayNorthWest
    TheGrayNorthWest Well-Known Member
    The oil change system on the 3rd gen was definitely annoying when I first picked up my new truck. It's an oil filter and an oil change - the belief that "people should have to buy special tools to change their own oil might be a smart engineering decision" is baffling to me. If a car company is hell bent on changing something that really isn't broken, then I think they should actually try to make things more owner friendly . I hate giving props to Mopar, but the design on their 3.5L where there is an oil filter housing with a cap that is easily accessible when opening the hood, and you just unscrew it, pull the old filter, drop in a new one and close it up, and the filter is replaced feels like a change that actually makes sense.
