Oil Change from Hell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by majpooper, Mar 14, 2025.
  1. Apr 19, 2025 at 1:35 PM
    #181
    InThePlains
    InThePlains Well-Known Member
    I haven't taking the filter drain off for 10+ years, just crack the filter housing open a turn or two, let it drain till the flow stops(~30 seconds), then take the whole thing off. At lease you can wrap a paper towel around the filter housing so the oil will run down following the paper towel.
    Always replace the filter first so you have an empty pan to catch everything without splashing oil.
  2. Apr 19, 2025 at 2:57 PM
    #182
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    It was kinda hilarious. I do all of my oil changes and never had an issue with it before. I must have eaten my wheaties the last time I took it off and on.. Even with my full skid plate removal I can be done and buttoned up in under 30 minutes.
  3. Apr 20, 2025 at 3:27 PM
    #183
    majpooper
    majpooper [OP] Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    That's the way I have been doing oil changes for years and years and years - well not the filter first but basically how I take the filter off - kind of - I use an old sock or rag or nothing . . . . . but that is not cool any more - I got the tube thing and a special kind of wrench and even a cooler filter housing for my next oil change. I'm going high tech baby not the old fashioned Grandpa oil change any more for me.
  4. Apr 20, 2025 at 4:42 PM
    #184
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Getting the oil filter drain cap off has been my issue since I changed my oil at 15,000 miles after the first Toyota care oil change at 10K. When I did it at 5k miles everything was so smooth and easy. After that I'd try to remove it and the entire cap would turn. I could never get it loose of the truck being all oiled up. last oil change I went with the aluminum filter cap and a new drain cover so I should be good to go and make less mess. I have a stone driveway and I always lay down old cardboard to work on so that catches any mess that missed the drain pan.
    Barsoom likes this.
  5. Jun 9, 2025 at 1:49 PM
    #185
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    I used all this stuff and did my last oil change the way the cool guys do it even using the aluminum housing. I still got some oil on my hand . . . . OK the tube thing works better and less messy the filter wrench is works better. Still there was nothing wrong with the old fashioned way - I know, I know, change is hard for old guys like me.
    Taco_mike73 and TacoTime55 like this.
  6. Jun 9, 2025 at 5:13 PM
    #186
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Congrats!
    Admitting "change can be better," takes guts...at least, it's challenging to say so.
    I did one oil change without Fumoto and MotivX Kit...only happened once.
    I've become more proficient at oil changes now that I have a routine.
  7. Jun 9, 2025 at 5:20 PM
    #187
    Taco_mike73
    York, PA
    When I got my truck nearly 5 years ago now. I got the older style motiveX filter wrench for my first oil change and nothing else. I did Okay with it at 5,000 before the Gorillas at the dealership did a Toyota care service and over torqued everything it was easy. I didn't know what pepole were talking about "hard to change the oil" after Toyota Care... Understood.
    I got the new version with full kit now too. It is very nice to use.
    Fireball 00 likes this.
  8. Jun 10, 2025 at 12:32 PM
    #188
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    In all seriousness I think "routine" is the key - we (or at least I) tend to become creatures of habit.
    I had done oil changes the same way literally for 30+ years - it worked, a little messy so why change.
    TacoTime55[QUOTED] likes this.
  9. Jun 10, 2025 at 4:39 PM
    #189
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Very much so as far as routine goes.
    I've adapted to the canister type housing with its winglets...and the over-torqued unit.
    Previous oil filters damage would be forcing the filter wrench on an over-torqued old-style filter and possibly piercing it.
    Luckily, that did not happen to me but I came close!
    Canister Housing is a different design that I wasn't familiar with but...once I got the process/steps to success, the confidence grew.
