Oil Change from Hell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by majpooper, Mar 14, 2025.
  1. Mar 17, 2025 at 1:48 PM
    #121
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Teach your kids to change oil. Smaller hands.
    At my next oil chage, my teenage daugher will be helping me with the the oil change. Her brother helped me last time. Next time he is flying solo, under my supervision. 3 assists, then they start changing oil.
    jmneill likes this.
  2. Mar 17, 2025 at 2:34 PM
    #122
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Don't use the 3/8 drive for loosening. It will break. It is only intended for use when tightening to make it easy to use a torque wrench.
  3. Mar 17, 2025 at 3:01 PM
    #123
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Don't tell my tools about this. I've been using a 3/8 on these things every 5K for over 15 years, and probably a million miles in totality, and haven't had one break.
    First time for everything, though. I may be one oil change away from eating my words.. ¯\_(ツ)_/¯
    TacoTime55 likes this.
  4. Mar 17, 2025 at 3:05 PM
    #124
    Mach
    It definitely depends on how tight it is on there but if you look at the reviews of these tools they are full of instances of them breaking when used to loosen with the 3/8 drive.
    Barsoom and jmneill[QUOTED] like this.
  5. Mar 17, 2025 at 3:12 PM
    #125
    jmneill
    SE
    I believe that 100%.
    I think I bought my first one in 2013, and when I pulled it out of the box and had a look at it, I didn't know if it would make it through the first oil change.
    Unbelievably, it's still floating around the toolbox today.
    Don't know if the new ones are any stronger, but comparatively speaking, they're highly refined cosmetically.
    (MotivX brand)
  6. Mar 17, 2025 at 3:14 PM
    #126
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
  7. Mar 17, 2025 at 3:15 PM
    #127
    InThePlains
    InThePlains Well-Known Member
    26mm socket
  8. Mar 17, 2025 at 5:37 PM
    #128
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    my first oil change i had to use an 5/8 impact reduced to 3/8 to get the plastic cannister off. im just all over the place breaking rules.
    jmneill likes this.
  9. Mar 17, 2025 at 6:27 PM
    #129
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Exactly what I do. No issues whatsoever.
    Not sure why so many folks make it complicated.
    Koolbreeze7 likes this.
  10. Mar 17, 2025 at 6:33 PM
    #130
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Mine been just fine for over 6 years now. 5K oil changes too.
    Yes, the cartridge takes a few more extra steps but its definitely not complicated at all...
  11. Mar 17, 2025 at 6:40 PM
    #131
    iliketacosandburritos!
    iliketacosandburritos! Well-Known Member
    auskip07 and majpooper[OP] like this.
  12. Mar 17, 2025 at 7:13 PM
    #132
    majpooper
    majpooper [OP] Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    I feel deep shame . . . . I figured out what happened. Someone called it - I put the O ring in the wrong place. How? I guess the metal housing just looks different than the black plastic one because I always get the O ring in the right place on that one. I picked the metal housing out of the trash and was examining if center piece was higher than the filter (I used a fresh filter) - no it fit correctly THEN! I looked at the O ring that was still on and sure enough it was up too high. I was always sure not to put it too low at the bottom of the black plastic housing and I thought that's what I did - but no.
    Now to make me feel worse - I always the 3/8 for removal which evidently is a BIG no no - and I never use all the fancy stuff that everyone has talked about here - I didn't even know some of it even existed.
    Gee now I wonder if I should even be allowed to do my own oil changes.
    Oh and BTW - I started my military career as a helicopter mechanic and became a crew chief - it's a wonder my aircraft never fell out of the sky . . . . I mean helicopters have O rings that need changing.
  13. Mar 17, 2025 at 7:22 PM
    #133
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    Purchased in 17 from Toyota with 5000 miles on it. Needed 3/8 breaker bar with Motivx tool to get the canister loose. Threw the retaining clip thingy away then as well. Makes sense Motivx would recommend using the socket for removal, just never gave it a thought. Continue to remove to this day with the 3/8, but it is much easier now that it is torqued to spec every time, unlike the dealer's tech who did who knows what to it when they put it on. At 100,000 now. All good.
    MagicToolbox likes this.
  14. Mar 17, 2025 at 7:24 PM
    #134
    jerrybear
    17 off-road
    Lol, have to respect a humble man who can make fun of himself. We all have our moments.
    soundman98 and MagicToolbox like this.
  15. Mar 17, 2025 at 7:28 PM
    #135
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    well, an honest mechanic is hard to come by. :thumbsup:
    fortunately Tacoma's don't fly. :eek:
    :cheers:
    next mod? https://www.designboom.com/technology/xpeng-driving-car-flying-vehicle-11-11-2022
    actual video of flying car starts at 1:12:00
    soundman98 and nevertoomanytacos like this.
  16. Mar 17, 2025 at 9:01 PM
    #136
    Barsoom
    NW GA OTP
    Metal housing has another groove that look almost like the O ring groove, but it is not the same , IIRC, it has flat machined into it.
  17. Mar 17, 2025 at 9:23 PM
    #137
    InThePlains
    The correct and incorrect O ring placement is printed on every Toyota filter box.
    tacoman45 and nevertoomanytacos like this.
  18. Mar 18, 2025 at 3:37 AM
    #138
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    No need to feel shame, Learn and go on. That is what life is all about.
    usmc2msu likes this.
  19. Mar 18, 2025 at 4:43 AM
    #139
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    It's an honest mistake.
    Spending lots of time here on TW has "learned me" to avoid other's mistakes.
    It took a couple of tries but I've finally gotten confident doing my oil changes.
    Installing Fumoto and using the MotivX kit has made this task less messier.
    Reference pic for O-ring placement; you can just make out on the plastic where the O-ring is located.
  20. Mar 18, 2025 at 4:47 AM
    #140
    auskip07
    Skip
    Atlanta, Ga
    You would think the dealer oil change tech would have gotten it correct on my free oil change
