Oil Change. How can two Toyota's be so different...
Discussion in '1st Gen. Tacomas (1995-2004)' started by mjhenks, Jun 3, 2010.
  1. Jun 3, 2010 at 7:40 AM
    mjhenks
    mjhenks [OP] Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    Without trying i ended up owning two 2004 Toyota with V6 engines. Both with similar miles. One a Sienna, the other a Tacoma Double Cab. Changed both oils last weekend. How can one V6 do everything right and one get everything wrong......
    The Sienna was done in 20 minutes with not a drop of oil spilled. The Tacoma.... 2 hours later, an Exxon Valdez spill clean up and i was done. There has go to be a better way to get at that filter...... Went in thru the wheel well this time with a milk carton below it to catch oil and still made a mess.
    Anyways.... My rant is over....
  2. Jun 3, 2010 at 8:20 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    For starters, it's not "one V6" ...
    Two entirely different engines (VZ versus MZ series), different layouts, and different vehicles.
  3. Jun 3, 2010 at 8:28 AM
    mjhenks
    So.Cal
    Yah, I know they are different. Transverse vs straight mount and likely do not share any parts except the oil filter but man are they different.... Just had to rant.
  4. Jun 3, 2010 at 8:50 AM
    Boosted17
    Boosted17 Well-Known Member
    Cliff
    Florence, Ky
    Looking for a new Toyota Truck.
    2006 Corvette Z51 M6. Best mod ever!
    I put a plastic bag under my oil filter and that does a good job for me to keep the oil from making a huge mess.
  5. Jun 3, 2010 at 10:09 AM
    Barnone
    Barnone Guest
    Good tip. My 2.4l filter is in a bad place also.
  6. Jun 3, 2010 at 10:18 AM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    You are one year too early, the 05+ have filter access from up top looks easy dealers still doin mine for free so cant say for sure though.
  7. Jun 3, 2010 at 10:27 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Drain oil. Once it stops dripping, slide the catch can over so it's under the filter.
    unscrew filter with hand in plastic bag, drop filter in plastic bag. If there are drips, they'll go into the catch can.
  8. Jun 3, 2010 at 4:20 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    x2
  9. Jun 4, 2010 at 2:44 AM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Easy for me because I have access to a lift, but all I do is drop the skid plate and the oil from the oil filter drains straight down to the catch pan, as as cake.
    To the O.P. you must have a newer 1MZ-FE or 3MZ-FE because the first 1MZ-FE motors did not have oil drain funnel thing and it spilled all over the engine mount and to the subframe etc what a PITA.
  10. Jun 4, 2010 at 4:14 AM
    jandrews
    '09 FourDubDee TRD OR
    Easiest way to get an inverted (i.e. most of them) filter off is to put a catch pan underneath the mounted filter and unscrew the filter very slowly. Once it's about halfway or so unthreaded, oil will leak out and run down the side of the filter, dripping off the bottom. Leave it like this with the catch can underneath until it stops dripping, then finish unscrewing the filter and place it face down in the catch can to continue draining.
    No mess, neat as you please.
  11. Jun 4, 2010 at 8:33 AM
    ywen
    ywen Well-Known Member
    is it just me or does anyone else not find the oil change on the 3.4L to be that much of a hassel?
    Sure I had to turn my wheel to the left and rip off the fender shield, but it was pretty straight forward changing the filter...
  12. Jun 4, 2010 at 9:36 AM
    TacoRan
    TacoRan Well-Known Member
    I was wrestling it from the bottom thru the skid plate until I found this forum. Talk about a face palm moment.
  13. Jun 4, 2010 at 9:46 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    how do you get a catch pan up under the filter? there's just enough room to get my hand in there. ..much less anything else.
  14. Jun 4, 2010 at 12:06 PM
    snwbdr
    snwbdr Active Member
    San Diego, CA
    '14 DCSB V6 4x4
    agreed....
  15. Jun 4, 2010 at 12:11 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    :rofl: Im sorry, that was hilarious since that seems to remind me of my first oil change on the tacoma.
    I now go through the driver wheel well and remove the skids to let the oil drain out of the filter a little better and cleaner.
  16. Jun 4, 2010 at 12:13 PM
    ywen
    I only spilled oil because my clumsy ass bumped into the filled oil catch pan... not from the filter placement.
    And I sprayed oil during the front diff fluid change because the cheap a$$ harbor freight fluid pump I was using blew up in my face because I was pumping too fast.
  17. Jun 4, 2010 at 1:54 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    theres a company somewhere that makes a filter relocation kit for the 1st gen tacoma v6...i just cant recall who right now
  18. Jun 4, 2010 at 2:14 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i take off my wheel :)
  19. Jun 4, 2010 at 2:41 PM
    jandrews
    I'm speaking for my Matrix. I have not yet had a vehicle with an inverted oil filter that didn't drain directly "to the ground". Is there something under the oil filter of the 5VZ?
  20. Jun 4, 2010 at 2:43 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    lol, you could just drive the passengers front tire up on another car to get the clearence!
