oil change INSPECTIONS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mooney16q, Jun 18, 2011.
  1. Jun 18, 2011 at 6:27 AM
    mooney16q
    mooney16q [OP] New Member
    James
    Alabama
    2010 DC long bed 4x4 TRD Sport long bed MG
    ARE Z series shell with Yakima rack, Toyota sidestep bars & bull bar, warn lights, Ready Lift leveleling lift, Toyo Open Country AT 265/70/17, K&N Air fltr, weathertec, Pioneer Avic 920 with Iphone cable & steering wheel controller
    This is my first post so If I goof I apologize. This is a special notice to all members. I recently had an experience with my dealers service dept. that everyone should take note of. Apparently, there is a practice of inserting old oil quart bottles under the drip tube below the oil filter housing. This puts the bottle jambed and pinched directly against the pulley tensioner arm and your serpentine belt. I ran with this thing for three days after the service date. I always use the dealers service dept to perform all of the recurrent service to keep good maintenance logs. I have had trouble before because they did not tighten the oil pan servicing lug and of course oil leaked out. So I have been inspecting the work they do after each service they perform. I never thought this kind of gross incompetence could take place. They are now going to replace the pulley arm, serpentine belt and the engine cover they damage. DO NOT TRUST ANYONE DOING SERVICE WORK THESE DAYS, EVEN IF ITS THE DEALER. CHECK, RECHECK AND DO NOT LEAVE WITHOUT DOING A THOUROUGH INSPECTION. THIS COULD HAVE BLOWN THE SERPENTINE BELT AS IT WAS DAMAGED BECAUSE OF THIS AND BLOWN THE ENGINE!!!!!!!
  2. Jun 18, 2011 at 6:51 AM
    Brunes
    Brunes abides.
    Rotorhead
    Blown engine from a damaged/broken serpentine belt?? That sounds like a bit overkill-
    but the idea is right...The people you pay to work on your car are the same as you...human. They make mistakes too.
  3. Jun 18, 2011 at 7:00 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Does the dealer you go to have an ExpressLube lane? The dealer I use has several technicians doing the service (1st guy in the pit drains the oil and checks the suspension, 2nd guy fills the oil from an overhead hose, 3rd guy checks tire pressure, 4th guy does the wash, etc.). The entire "line" is behind a glass wall so you can see all the operations. Error is minimized because each guy has a very limited scope of work.
  4. Jun 18, 2011 at 7:16 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    The other way of looking at it is the potential for error is compounded 'cause they have to coordinate efforts. A topside guy could mistake the signal and drop oil with the plug missing... you get half full oil as no one wants to admit they dumped it into the drain before noticing. Or worse, start the truck completely empty before noticing the oil light. If they even look for it.
  5. Jun 18, 2011 at 7:19 AM
    KenLyns
    Belly of the Beast
    They still check the dipstick.
  6. Jun 18, 2011 at 7:23 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    well, I will check my dipstick before driving it away...that much I can depend on!
  7. Jun 18, 2011 at 7:28 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Thats why many guys do thier own work, especially oil changes. I do not save much money on an oil change since I use upper end oils and filters- but thats not the point. Knowing good oil and filters are installed correctly, everything tight, proper levels etc., plus you get a chance when you pop the hood to check and look over everything, top off fluid levels if needed, window washer reserve, etc. You would be surprised how much you may find or see ahead of a problem with regular visual expections. Preventitive maintenance keeps you rolling...;)
  8. Jun 18, 2011 at 7:52 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    OP, You're preaching to the choir to about 75% of the people on TW. That's why we do our own oil changes. Thanks for reinforcing what many here already believe.
  9. Jun 18, 2011 at 9:19 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Ha dealers perform service? I tought they only sell cars. :confused: snd sell parts
    :D
  10. Jun 18, 2011 at 10:15 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Why not just do your own oil changes? It doesnt get any easier than this truck when it comes to an oil change.
    imo, the "i go to a dealer for records keeping" is old thinking. Keep the receipts from the oil you purchase if you require records. Thats good enough. I've never asked to see oil change records when I've purchased a used car. Only major services or tsb work.
  11. Jun 18, 2011 at 1:19 PM
    JKD
    JKD Well-Known Member
    If you use toyotaownersonline.com to keep track of the service you do, then the very same records that the dealership updates get your updates too.
  12. Jun 18, 2011 at 1:54 PM
    cast71
    cast71 Active Member
    Pete
    NY
    2012 AC SR5 4X4 I4
    yellow wire mod, mud flap mod, differential breather mod, steering shaft tsb, rear leaf spring tsb
    ^^^^^^ I signed up, but didn't realize you can update your own records. Thanks:)
