oil change intervals
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brians05taco, May 25, 2010.
  1. May 25, 2010 at 3:06 PM
    brians05taco
    brians05taco [OP] Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    just had toyota change my oil and they recommend every 5000 miles and use castrol oil...it went from three to four now 5000 just had me concerned a bit not using any oil and have an 05 tacoma. ok or stick with lower mileage
  2. May 25, 2010 at 3:07 PM
    PreRunner
    PreRunner Well-Known Member
    go the 5k and use mobile1
  3. May 25, 2010 at 3:08 PM
    Agent7
    Agent7 Senior Executive of Nothing.
    Toronto, Canada
    07 Tacoma TRD Sport 4x4 6spd
    BHLM, Stubby Antenna, Custom Front Grill, Debaged Tailgate, Added TRD Emblem, Removed Factory Pinstripes, Leer 100XL Cap, Prolumen 6000K HID Kit with custom glare shields, Eurolite Yellow fog lights, 20" Fast Hustler wheels (black w/3" deepdish polished lip), Cooper Zeon LTZ 275/60/20's, Spidertrax 1.25" Wheel Spacers, Custom LED Gauges, Pioneer AVIC F700BT All-In-One Indash Navigation (Hacked)
    Did they use synthetic?
  4. May 25, 2010 at 3:11 PM
    brians05taco
    Brian
    Lafayette,La.
    nope i called them and they follow what castrol says and that the oil is supposed to not break down as easy and a bunch of other crap... i had 4000 when i brought it and oil was still pretty clear.
  5. May 25, 2010 at 3:11 PM
    redezman
    redezman Well-Known Member
    Charles
    Raleigh N.C
    2012 4Runner SR5 4x4
    All Factory for now, LOVE it that way
    my dealer does mine every 5000
    part of the deal for me buying, 5 yr or 75000 miles free oil changes and tore rotations
  6. May 25, 2010 at 3:13 PM
    brians05taco
    Brian
    Lafayette,La.
    damm nice deal they charge 36 just for the oil change.
  7. May 25, 2010 at 3:14 PM
    Agent7
    Toronto, Canada
    If it's synthetic, than 5000 miles is no problem...
  8. May 25, 2010 at 3:15 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    On modern engines 5000 mile oil changes are fine with any quality oil. However, if you drive your engine hard (towing, heavy duty off-roading, etc.), I would change it every 3000 with conventional oil, 5000 with synthetic, but that's just my opinion.
  9. May 25, 2010 at 3:18 PM
    brians05taco
    Brian
    Lafayette,La.
    sounds good to me, daily driver mostly, not driven hard
  10. May 25, 2010 at 3:19 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Regular oil = 3000 miles
    Full Synthetic oil = 5000-6000 miles
    I love how the deal says you can go 5000-7500 on regular oil. Yeah you can but you're seriously shorting the life of your engine. The dealer wants you to go higher milage on regular oil so they can sell you an engine @100k.
  11. May 25, 2010 at 3:29 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    SoCal
    07 PreRunner SR5 V6 Black
    5k on synthetic for me
  12. May 25, 2010 at 3:37 PM
    TacoRan
    TacoRan Well-Known Member
    Maryland
    2012 TRD Sport
    I followed the owners manual maintenance interval until I hit 100,000 miles. Now its every 3,000 religiously
  13. May 25, 2010 at 3:48 PM
    Manwithoutaplan
    ID
    I get my oil change at 5000 miles exactly or little earlier.
  14. May 25, 2010 at 4:09 PM
    StarGazer
    StarGazer Well-Known Member
    MegaMan!
    Wherever, Tx.
    2007.5 Dodge Ram 2500 Mega Cab 4x4
    I've done so many mods to this truck it turned out to be a Dodge Ram 2500! WOW was that expensive!!
    I use Pennzoil 5W-30 and change every 5,000 miles. I mostly drive 10mins to and from work (during rush hr.) and tow my TT once a month.
  15. May 25, 2010 at 4:53 PM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    The only way to know for sure is to get an oil analysis done after each oil change for 2-3 oil change cycles. Stick with a particular brand to avoid introducing unnecessary variables. The lab will then tell you how long you can go between oil changes.
    I change my oil every 5k with Mobil 1, which is about every 6 months. Blackstone Labs tells me I could lengthen the interval if I want. I drive under "severe" conditions (short trips, wet, cold, sometimes dusty).
  16. May 25, 2010 at 5:43 PM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I know I'm overdoing it a bit but Mobil 1 5W-30 at 3000 miles with OEM filter. I go up, over, down and back on a 7200 ft. elevation freeway about twice a week. The engine is working and revving higher than normal driving. I figure it's considered hard driving and so I change more frequently.
  17. May 31, 2010 at 3:46 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    10 PreRunner AC Sport Rally 5 Spd
    Tail gate hose clamp, Front Windows 50% tint, fog lights, 894 backup light mod, LED license & interior.
    Would I void any part of the warrenty if I changed my oil at 5300 miles but only 4 months apart? I use full synthetic.
  18. May 31, 2010 at 3:48 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    They have to prove your maintenance schedual actually caused the damage. If something should happen just say you did your changes on a regular basis.
  19. Jun 2, 2010 at 7:14 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    If you drive "normal", and 99.9% of us actually do, 5000 mile change intervals on conventional oil in a typical vehicle (non turbocharged) will still leave plenty (1000+ miles) of oil life remaining.
    I've had multiple oil analyses done on multiple vehicles, including my Tacoma, and on every one I can go well beyond 5000 miles and be fine. It's not 1970 anymore but Valvoline and Auto Zone love you 3000 mile oil change guys that still change oil like it's 1970 with its lesser oils, carburetors, and leaded gasoline.
    You should have an oil analysis done for real evidence on what is actually necessary vs what you think is necessary.
    edit:
    this is really old but some of you may not have seen it. It has some interesting data
    http://neptune.spacebears.com/cars/stories/oil-life.html
  20. Jun 2, 2010 at 7:49 AM
    Barnone
    Barnone Guest
    I'd say that most of the replies were opinions and not data. The only data were a few posts about sending off samples for oil analysis.
