Oil change issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryttingm, Jul 4, 2024.
  1. Jul 4, 2024 at 7:04 AM
    ryttingm
    ryttingm [OP] New Member
    Yesterday I performed my first oil change on my 2014 Tacoma. Drained the oil out, replaced the filter, I added a little over 4 quarts of oil until the dipstick was reading about half way between the 2 dots. I then started the car and pulled out of the garage to park on the street. Car maybe ran for 1 minute. Nothing seemed out of the ordinary.
    About 10 minutes later I went out to reset the MAINT RECQ light and when I turned the key to ON there were 4 lights that stayed on after the initial period where all the indicator lights were on. The CEL, A/T Oil Temp, Battery, and Oil pressure light were on. I then tried to start the car but it would only turn over and not start. I pulled the dip stick and noticed the oil level had dropped to the lowest dot on the dip stick. I'm assuming some of the oil was pulled into the new filter so I added the rest of the 5 quart bottle so the dip stick show a level about 3/4 to the full side.
    I subsequently left the car overnight and again tried this morning. All 4 indicator lights are still on and the car will turn over but won't start. I have an OBD scanner on order so I can read the codes but wanted to see if this sounds familiar to anyone.
  2. Jul 4, 2024 at 7:29 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The oil levels are normal. You will always get a little higher reading until you start the engine and let it run for a minute to fill the new filter. Always recheck and top off if necessary after letting it run for a minute.
    I can't think of a single reason for the oil change to cause the warning lights. Probably just a coincidence.
  3. Jul 4, 2024 at 7:43 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    4 quarts?!
  4. Jul 4, 2024 at 8:43 AM
    Lost Coast Adventure
    Lost Coast Adventure Active Member
    2014 Tacoma DCLB
    You should be putting about 6 quarts back in after a drain.
  5. Jul 4, 2024 at 8:45 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Try disconnecting your battery for a minute and see if that cancels the lights.
    Rusty66 likes this.
  6. Jul 4, 2024 at 8:49 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Check all the fuses, EVERY ONE regardless of what it’s labeled as then go from there.
    Pretty sure the CEL, oil press and battery light are supposed to stay on with KOEO. Not sure about the trans temp.
    wilcam47 likes this.
  7. Jul 4, 2024 at 11:42 AM
    TacoTuesday1
    SD CA
    what engine do you have
    what's the oil capacity
    O'DubhGhaill likes this.
  8. Jul 4, 2024 at 12:24 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Make sure correct amount of oil is in,then do post number #5
    Make sure you didn't knock one of the wires off the battery when you were taking the filter off.
  9. Jul 4, 2024 at 12:29 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    How many miles on the truck?
    What engine is in it?
    When was the battery last replaced and/or health-checked with an automotive battery tester?
    Does it have enough gas in the tank?
  10. Jul 4, 2024 at 1:04 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    2014 both 4 and 6 cyl 4wd and Prerunners take 5.5 qts. Standard 2wds may take less look at your book.
  11. Jul 4, 2024 at 3:55 PM
    ryttingm
    Ok. Mystery solved. I'm an idiot. Turns out that even though the key you have can turn the ignition and turn over the car, it won't actually start unless you're using a coded key. I was using a backup key that won't enable the ignition system.
    O'DubhGhaill, GilbertOz and tacoman45 like this.
  12. Jul 4, 2024 at 3:59 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    That’s great news considering the alternative haha
  13. Jul 4, 2024 at 3:59 PM
    lynlan1819
    Tacoma
    Lifted
    Lol,geez.
