oil change light help!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by keithlandrum, Mar 16, 2010.
  1. Mar 16, 2010 at 6:23 PM
    keithlandrum
    keithlandrum [OP] Well-Known Member
    Keith
    Saraland Alabama
    2010 chevrolet Z71 4x4
    tint, hid headlights,
    i just had my oil changed over the weekend at the dealership and they didn't reset it so now my oil change light still blinks when i crank it up which i did change it before the 5000 mile service about 400 miles before it was due im just wondering how do you reset it without dealing with the dealer??? thanks for the help
  2. Mar 16, 2010 at 6:25 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  3. Mar 16, 2010 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    With the Key in the ignition and "Off", press and hold the ODO reset button. Then, While holding the button down, turn the key to the "On" position. Not the "Accs" postion, but to the On. Wait until the ODO reads "00000", and its reset.
  4. Mar 16, 2010 at 6:27 PM
    rjreynolds
    rjreynolds Active Member
    2wd 2.7l
    hold down the odometer trip reset lever for 15 seconds with ignition on, then start your engine. that worked for me.
  5. Mar 16, 2010 at 6:29 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    do that, you will see ------ and it will count down then you will see 0000000 then you're done.
  6. Mar 16, 2010 at 6:32 PM
    keithlandrum
    Keith
    Saraland Alabama
    ok thanks for the help!!
