Oil Change Makes Brakes Go Bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jage, Nov 5, 2013.
  1. Nov 5, 2013 at 3:07 PM
    jage
    jage [OP] Well-Known Member
    Franktown CO
    '010 Silver Double Offroad Leather/Sunroof
    OK, so I've got infant twins and figure it's worth dropping some $$ on a mechanic to change the oil. Save some time, right? Stupid.
    They took 45 minutes and when I drove away the brakes are soft.
    What the hell, is it possible this is in my head? The fluid level is fine and all the connections up top look undisturbed. Would an ASE really open the fluid lines at the wheels and let air in? The fluid is clean as a whistle in the reservoir, I can't imagine why they'd even drain some with so little mileage.
    I don't know what to think, but 54,000 miles and suddenly a soft pedal... stops fine, it just feels squishy at the top. Again, is it possible this is in my head because I don't like people touching my vehicles?
  2. Nov 5, 2013 at 3:09 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    that does sound fishy
  3. Nov 5, 2013 at 3:10 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Tacoma's are notorious for having squishy feeling brakes. It's probably your mind psyching you out.
  4. Nov 5, 2013 at 3:11 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Do you know if they touched the tires, brakes anything else rather than doing your oil change? Some places do visual inspections and such. I couldn't see anything to why just an oil change would effect your braking. I would go back and have a talk with the mechanic.
  5. Nov 5, 2013 at 3:14 PM
    fenderpicks
    fenderpicks Well-Known Member
    There should be a noticeable difference if air somehow got into the brakes system.
    It is either U KNOW FOR SURE theres air, or you are just feeling paranoid because someone other than u worked on it.
    But does the truck feel normal when ur stepping on ur brakes? Does it STOP STOP?
    OR
    You BARELY manage to stop?
  6. Nov 5, 2013 at 3:18 PM
    Joe D
    Joe D .
    Could the shop have spilled oil on your disks. Granted it should burn off but???
    I just can't see a reputable shop tampering with your brakes...
  7. Nov 5, 2013 at 3:25 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^That. You really have you go out of your way during an oil change to let air into the brakes. Probably either some oil got on some how or it's just in your head.
  8. Nov 9, 2013 at 9:53 AM
    jage
    Franktown CO
    I'm willing to believe it's in my head, I just can't seem to get there on my own.
    The truck stops fine and the feel is all in the pedal. It just suddenly feels like crap, like I wouldn't have bought the truck if the brakes felt like this. And it's not like I was in another vehicle between, getting used to something else, etc.
    I don't think it's oil on the rotors, like I said the truck stops fine. They did a full inspection, checked fluids, and came back with a $1,000 estimate for my 60K service which is coming up in a few thousand.
    My only thought is if they checked the cleanliness of the brake fluid by opening the bleeders it could cause the pedal to go soft, but I can't imagine that's a standard method of inspection... argh.
    Thanks for the advice and opinions- it helps!
  9. Nov 9, 2013 at 10:02 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    1k for 60k service? [​IMG] Change your own diff oils, lube the driveshaft u-joints and save $900.
