Oil change mess. drained transmission fluid instead
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, Oct 9, 2010.
  1. Oct 9, 2010 at 8:00 PM
    JUJtacoma2010
    JUJtacoma2010 [OP] Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    My first time oil change as you can guess. I bought all the stuff from Kragens and printed out the instruction from the Ultimate oil change thread here.
    I had the toughest time removing the factory oil filter so I just drove a scewdriver though and that did the job.
    Then I went underneath and in excitement opened the transmission fluid drain plug. when I saw clear redish fluid coming out, I knew it was trans fluid. so I quickly put the plug back. I probably drained maybe 1 quarts of it.
    Now the problem is that, I couldnt find where the transmission fluid dip stick was to check the level. Does any one know how I can check the trans level and which transmission fluild to add?
    Please help.
  2. Oct 9, 2010 at 8:03 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    The tranny has to be a certain temp. There is no dip stick.
  3. Oct 9, 2010 at 8:03 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    its a sealed system. i did the same thing. you need to pump transmission fluid back in. so theres no dipstick. just take it to toyota.
    i did the same thing :anonymous:
  4. Oct 9, 2010 at 8:13 PM
    dwgltdco
    dwgltdco Live to Ride
    david
    Indian Hills
    08 tacoma trd offroad acess cab Silver
    trd intake
    This is a mistake that is common on 2nd gen tacomas.
    The bad news is that there is no dip stick. You will need to go to the thread that has this procedure. It basically says the vehicle needs to be a certain operating temp , engine running, in neutral and have enough toyota syn trans oil to come out the over flow bolt at the front of the trans pan.
    DO NOT use anything but toyotas trans fluid, period.
    To get this fluid into the trans pan you will need a fluid pump that can be bought at most auto parts stores only about $10. The fill hole is on the passenger side trans up and not fun to get to near the exhaust pipe. Take your time or take it to a dealer. With only one quart missing and not a long dist. to a dealer I would probably drive it. Good luck...
  5. Oct 9, 2010 at 8:18 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    i put a white x next to my oil drain so i wouldn't do th
  6. Oct 9, 2010 at 9:07 PM
    JUJtacoma2010
    Fresno
    How many quarts does that pan hold? Is some been in this situation and refilled the fluid themselves? I am still looking for that thread. appreciate if some one can forward the trans fluid fill link to me.
  7. Oct 9, 2010 at 9:09 PM
    JUJtacoma2010
    Fresno
    And if I take it to the dealer? what do I tell them?
  8. Oct 9, 2010 at 9:09 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Krazie did this and did a whole lot worse. Don't follow his thread about it.
  9. Oct 9, 2010 at 9:11 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Tell them what happened, since you will be paying for it anyways.
  10. Oct 9, 2010 at 9:31 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    if its under warenty tell them your friend has a truck just like yours bought around the same time and his tranny was shifting funny so when he took it in the fluid was low... lol and if they can check yours too because you felt it shift hard a few times when it was cold
  11. Oct 9, 2010 at 9:40 PM
    JUJtacoma2010
    Fresno
    I read the article about doing this myself but thats a little complicated for me. I am pretty sure I just drained probably less than a quart before realising it was atf. Hopefully thats enough for me to take to the dealer.
    yes, mine is under warranty and thats a good idea.
    thanks. I wish there was a way for me to check this myself.
    does anyone know where the overflow plug is?
  12. Oct 9, 2010 at 9:50 PM
    S.B.
    Sean
    San Diego
    15 Taco
    And this is why they wanted to charge me $400 for 1 headlight, $138 for spring silencer pads and some other over priced shit.
  13. Oct 9, 2010 at 9:51 PM
    supataco
    supataco Shaq-enzy Falls
    Ichiro
    Oahu - Hawaii
    2010-SSM-AC-TRDSport-PreRunner
    -17" 4Runner Trail Wheels (265/70/17) -OEM Tube Steps -Tailgate Security Clamps -Trimmed Mudflaps -Bed Bar -Kobalt Box -Bed Mat -Toyota Mats
    Damn, I'm so scared I'm gona do this too. Can anyone link pics of correct oil drain bolt?
  14. Oct 9, 2010 at 10:50 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Its the one under the engine. Its on a smallish black pan.
  15. Oct 9, 2010 at 11:08 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    It's in the hole of your IFS skid plate.
  16. Oct 9, 2010 at 11:14 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Post the tread on your super fuck up. :D
  17. Oct 10, 2010 at 5:47 AM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    christ. how are people still doing this? its so obvious.
  18. Oct 10, 2010 at 5:53 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
  19. Oct 10, 2010 at 6:03 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Gee ... I would start with the truth ...... :cool:.
  20. Oct 10, 2010 at 6:03 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
    I have been sitting here thinking the same thing.
