Oil Change, . . Now Squeaking Belts??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaRXP, Feb 13, 2011.
  1. Feb 13, 2011 at 5:19 PM
    TacomaRXP
    TacomaRXP [OP] Active Member
    Bryan
    NC
    05 TRD 4x4 SR5
    K&N CAI
    hey guys just did a regular oil change now my belts are squeaking like an 84 oldsmobile. any ideas whats going on or has this happened to someone out there?? going to try belt dressing tommorow thanks
  2. Feb 13, 2011 at 5:29 PM
    BBY2KS2K
    BBY2KS2K Jon Stewart / Stephen Colbert 2016
    Lake Stevens, WA
    2005 PreRunner DC
    16x7.5 TRD Bronze "beadlock" wheels without the beadlocks w/ 265 70 16 Bridgestone Revo II tires (non-winter) 16x8 KMC Enduro w/ 265 70 16 Bridgestone Blizzak DMV-1 tires (winter) McGard Spline Drive lugs and locks, Satoshi Grill, BLHM, blacked out badges, Aries side steps, Smittybilt light bar with PIAA 540 plasma ion fogs, Aero-Turbine muffler
    Did you get oil on the belts?
  3. Feb 13, 2011 at 5:48 PM
    TacomaRXP
    Bryan
    NC
    05 TRD 4x4 SR5
    K&N CAI
    it's possible. . . would that cause it to squeak? might have happened from the oil filter drain.
  4. Feb 13, 2011 at 6:02 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Anything like oil on the belt will cause it to slip and thus squeal. You need to clean it off. The easiest way is to spray brake cleaner on it while it's running, rev it up, and drive it around a bit. The squeal should eventually go away.
    And FYI, you have an '05 and if you haven't changed the belt yet, now would be a very good time to do so (just clean off the pulleys first so you don't get any oil on the new belt).
