Oil change on 2018 tocoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hoopstir1, Feb 16, 2019.
  1. Feb 16, 2019 at 6:48 PM
    hoopstir1
    hoopstir1 [OP] Member
    David
    Limerick Pa
    14 double cab
    Hello Everyone
    Has anybody kept the plastic oil filter housing or swapped out it out with the aluminum housing??Can you get the aluminum one at the dealer?Does everyone let the dealer do the oil changes??and wait till 10,000 miles??why does the maintenance light comes on at 5000 miles?
    for a 10,000 mile oil change.
  2. Feb 16, 2019 at 6:50 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Maintenance light comes on for the tire rotation at 5k.
    Lt. Dangle likes this.
  3. Feb 16, 2019 at 6:52 PM
    hoopstir1
    David
    Limerick Pa
    14 double cab
    thanks a lot for the info does any body wait for the 10,000 miles though??
  4. Feb 16, 2019 at 6:53 PM
    shakerhood
    Southern Ohio
    That is what the recommended change interval is so you will be fine.
    Lt. Dangle and boynoyce like this.
  5. Feb 16, 2019 at 8:28 PM
    tacomalimited
    tacomalimited Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    I change mine every 5000,it's just what I've always done,10,000 seems like a lot.
  6. Feb 16, 2019 at 8:30 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Yes. Why wouldn't you?
    shakerhood likes this.
  7. Feb 16, 2019 at 8:31 PM
    Lt. Dangle
    Ohio
    I found the aluminum filter housing was much cheaper at my local Napa.
  8. Feb 16, 2019 at 8:48 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Most do because.... that is what the engineers who designed the truck say to do. Change it whenever you want. Your money.
  9. Feb 16, 2019 at 8:54 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    I stick with the plastic, there have been users who have had small oil leaks from the metal. Why take the risk? I do oil changes myself. I change it every 10k miles. Maintenance light comes on every 5k miles for tire rotation and fluid checks.
  10. Feb 16, 2019 at 9:01 PM
    bluzharp
    bluzharp Well-Known Member
    Central AR
    19 OR DC LB Cement (the slowest color)
    Pro Suspension, Roadmaster overloads, Diamondback
    I just did my first oil change on the new truck. I sure miss the oil filter on the 2nd gen. This one is a pain in the butt. Have to remove the trap door in my fancy pants TRD skid plate first. Then work through the hole. The drain gizmo drips a bit on the outside, so even though I had a tube, still got oil on top of the skid. Not too difficult but way worse than the old truck.
    BTW, I swapped out the housing for the aluminum one. There is nothing inferior about the plastic one though.
    I have 2100 miles on the original oil. It was filthy black. I will change it again at 5K, 10K, then go to 10K intervals.
    02Duck likes this.
  11. Feb 17, 2019 at 6:45 PM
    hoopstir1
    David
    Limerick Pa
    14 double cab
    thanks guys for the information.Does anybody put toyota oil filters in or use other brands??
  12. Feb 17, 2019 at 6:51 PM
    Shellshock
    Iowa
    Dealer did 10k & 20k service
    30k service I replaced mine with the aluminum one. In the process found out the dealer has used the 3/8 socket hole to tighten the assembly onto the truck so getting the drain plug out was a PITA.
    Also discovered they had messed up one of the bolts on my pro skid plate so it wasn’t tightening down all the way and was crooked
    I’ve done all the services and maintenance since…
    Denniskap, Amanelot and shakerhood like this.
  13. Feb 17, 2019 at 6:57 PM
    hoopstir1
    David
    Limerick Pa
    14 double cab
    thanks everyone
  14. Feb 17, 2019 at 7:57 PM
    Amanelot
    Amanelot Member
    Texas
    The dealer cross threaded one of my skid bolts as well. I used washers to take up the slack and keep the skid snug. One day I'll retread it, but for now it works. I assume they were working too quickly and using power tools to try and tighten it.
  15. Feb 17, 2019 at 8:00 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    I changed my oil at 1,500 miles. Then at 10k and 20k the dealer took care of it. I changed it and installed a Fumoto drain valve at 30k and had the easiest oil change of my life at 40k.
    Some members have sent oil for testing and the companies were recommending 12-15k intervals. Synthetic is good shit nowadays.
  16. Feb 17, 2019 at 8:11 PM
    Jmac2408
    Jmac2408 Well-Known Member
    Justin
    Southern California
    18 TRD Off Road 4x4
    I do 5k for peace of mind and I’ve kept the plastic housing. I’m sure 10k is fine and what Toyota recommends
  17. Feb 17, 2019 at 8:12 PM
    Shellshock
    Iowa
    On mine they tried backing the bolt fully out one at a time which moved the retaining ring. They then just tightened as much as it would go but bound up on the retainer so it wouldn’t go in all the way. Glad it wasn’t cross threaded but still took a while to figure out wtf the issue was
    Amanelot[QUOTED] likes this.
  18. Feb 17, 2019 at 8:45 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
  19. Feb 17, 2019 at 8:48 PM
    Amanelot
    Amanelot Member
    Texas
    Lucky.
  20. Feb 19, 2019 at 8:23 PM
    hoopstir1
    David
    Limerick Pa
    14 double cab
    Hello again does everyone like the Fumoto drain valve ?? pros & cons??
