oil change on tacoma 08
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fred56, Jan 31, 2009.
  1. Jan 31, 2009 at 9:37 AM
    Fred56
    Fred56 [OP] Member
    in South Dakota
    Tacoma sr5 4x4
    Hello,
    I have a 08 tacoma dbl cab 4x4 with skid plate. Do I need to remove the skid plate in order to change the oil?
    Thanks for your help,
    Fred56
  2. Jan 31, 2009 at 10:07 AM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    You should have access to change the oil behind the skid plate, center line of the oil pan, towards the rear.
  3. Jan 31, 2009 at 10:48 AM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    Agreed, there is a small access at the rear of the plate, makes it real easy, but you will have to find a way to route the filter drain hose down through the small openings on the plate, so you don't get oil all over it.
  4. Jan 31, 2009 at 11:18 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    Just put an old 20 oz. water bottle under the oil filter drain hole. The bottle fits in the area without even holding it while the filter oil drains. This keeps you from attaching a hose and snaking it down past the motor to your oil drain container.
  5. Jan 31, 2009 at 11:21 AM
    Stu
    Stu Well-Known Member
    G'Ville, NV
    Taco TRD OR
    Not much yet, got a pretty good sound system w/ my custom sub box. Plan on adding more lights & a tool box.
  6. Jan 31, 2009 at 11:38 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    yup... :thumbsup:
  7. Jan 31, 2009 at 11:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  8. Feb 1, 2009 at 8:03 AM
    Fred56
    Fred56 [OP] Member
    in South Dakota
    Tacoma sr5 4x4
    I got it, thank you all. It was easy to change the oil. I read all the suggestions and watched the video clips, and then decided to change it myself. This is first time that oil has been changed on this tacoma 08. It has 2k on the odometer. I replaced with 5qt of Valvoline premium 5W-30 oil, and I think I need to add half a quart to make sure that has enough oil as it is suggested by toyota. The oil filter is shorter than the oiriginal one. Is that okay? It is Toyota brand, and I asked for Tacoma.
    Thanks
  9. Feb 1, 2009 at 8:23 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah that's normal. ;)
  10. Feb 1, 2009 at 9:21 AM
    Drew793
    Drew793 Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    I have a 2008 V6 engine and have found that If you don't run the engine, there will be no oil in the oil filter so when you remove the oil filter, there won't be any oil mess.
    I recommend having something there to catch it just in case but I have done it this way a few times on my V6 with success.
  11. Feb 1, 2009 at 9:31 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Yep, I do exactly the same Hillbilly. I just wedge a water bottle under the oil filter housing drain port - a lot easier than running a long tube, etc. I will be installing a Fumota oil drain valve with my next change. I got the one with a nipple attached so no more mess!
  12. Feb 1, 2009 at 9:44 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
  13. Feb 1, 2009 at 1:11 PM
    LDrider
    LDrider Active Member
    Maine
    Ford F150
    That sounds kinda scary. Which filters are you using that don't have anti-drain back valves? I thought every spin on filter had them.
    Starting an engine every time and waiting for the oil pressure to build sounds like a recipe for engine damage.
  14. Feb 3, 2009 at 11:55 AM
    Drew793
    New Jersey
    OEM Toyota oil filter
  15. Feb 3, 2009 at 12:07 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I use a Mobil 1 and it's always full of oil AFTER I drain the pan.....if your filter is dry, there is a problem.
  16. Feb 3, 2009 at 12:31 PM
    Drew793
    New Jersey
    The first 2 oil changes that I did, I ran the engine to heat up the oil and then shut it off to drain the oil. This is how I've always done it on other vehicles. The oil filter had oil in it.
    The next time I changed the oil, with a cold engine (sat all night), I crawled under the truck (no ramps required), unscrew the oil filter and it was dry. I buy the filters right from the dealership.
    I guess that most are going to run the engine before they change the oil.
    Either to get it up on ramps, position the vehicle into garage or driveway or just to get the oil warm.
    Has anyone else tried this? Remove the oil filter with the engine cold?
  17. Feb 3, 2009 at 12:41 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I have drained cold oil and then removed the filter (I always remove the filter last) and there has always been oil in the filter. Always. Hot or cold.
  18. Feb 3, 2009 at 2:58 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    There is two reasons you should change your oil when warm.
    First, most importantly; when the oil is circulated through the engine the harmful acids, heavy particles, and moisture are suspended in the oil. This allows you to drain that matter with the oil change.
    Secondly, the oil flows more easily and will drain the maximum amount of old oil in a reasonable time. Especially when you use a fumoto or other brand quick drain.
    As for the filter, I use a WIX and it does have the anti-flowback valve.
    I cannot find any data on the Toyota factory filter and since I don't use them, I can't cut one open and find out.
    I really can't imagine an inverted filter not have one, though. Just a SWAG.
  19. Feb 3, 2009 at 3:00 PM
    Drew793
    New Jersey
    I've gotten the oil filters from the same dealer every time. They are OEM and sealed. There has to be an explanation for this. I will ask someone there but I doubt they are going to be able to answer my question. The oil must drain out of the filter overnite. I would think that unless does an oil change in this similar manner, they would never know.
    I'm curious to see if this happens on my next oil change also. I will post in about a 1,000 miles or so and do my next oil change.
    Thanks for your reply and input on this.
  20. Feb 3, 2009 at 6:04 PM
    LDrider
    Maine
    Ford F150
    If what you say is true, what is happening is that all of the crap that the filter has trapped, is flowing down back into your sump. The reason why all vertical mounted filters must have an anti-drain back valve is to prevent this back flow into the pan when there is no pressure in the system.
    Filters that are mounted vertically but upside down (opposite of your Tacoma) do no need an anti-drain valve since gravity will keep the junk in the filter.
    Every time you start your engine, it is running without any oil pressure, since the oil pump has to fill your filter with oil first. Since all the particles in your filter are being drained back down into the pan, you are also in effect running without any filtration at all. Sell your truck before the engine explodes. :eek:
    Ok, wait a minute...I just saw where you <crawled under the car to change the filter>...My truck has the filter up top, since it is a six. You sig says you have a six...Why are you crawling under the car to change the oil filter???????
