Oil change - OR NOT????
Discussion in 'Technical Chat' started by Alby22, Oct 1, 2020.
  1. Oct 1, 2020 at 6:16 AM
    Alby22
    Alby22 [OP] Well-Known Member
    Ashville, Ohio
    Cement 2020 Toyota Tacoma TRD Sport 4x4 Double Cab, Long Bed
    So, I bought a new Cement 2020 Toyota Tacoma DCLB Sport. It currently has 4700 miles, and I’ll be driving it on a trip from Ohio to Louisiana. I’m taking it in for it’s first service before I leave. Even though the service manual says that the first oil change should be at 10,000 miles, I planned on changing it before I leave for peace of mind. A friend recommended that I wait until 10,000 miles because it may have “break in” oil in it from the factory. My question to you is, should I change it or not???? I would think that new oil in a vehicle could l never be a bad idea. Your thoughts? Thanks in advance for your opinions
    NAAC3TACO and Bastek like this.
  2. Oct 1, 2020 at 6:22 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Do it. Just change it. It's not that expensive, and you'll keep clear conscience.
    Now, is it really necessary? Probably not. But if you will not change it, and it's going to occupy your mind....
    Like you said:
    BalutTaco and RedWings44 like this.
  3. Oct 1, 2020 at 6:23 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Change it. Mine had its 2nd at 5k
  4. Oct 1, 2020 at 6:24 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    You’re gonna get a lot of don’t change it manual says 10000 miles and change if you want to answers. I had them change my oil and filter at the 5000 miles/ 6 month inspection with less miles than you. Old school engine break in philosophy, synthetic be damned, and I own the truck. ;)
  5. Oct 1, 2020 at 6:24 AM
    Michigan Curmudgeon
    Michigan Curmudgeon Well-Known Member
    There is no 'break in' oil. The factory fill is TGMO.
    I'd change it.
    TGMO is very good oil, the Toyota Denso filters are sturdy but filter below average.
    My choice for a filter is a WIX for 5K mile OCI, or a Fram 'Ultra' for 10K mile OCI.
    suaveflooder and SR-71A like this.
  6. Oct 1, 2020 at 6:26 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    After a Blackstone analysis and TBN of Amsoil signature 0W-20 I was advised to go 7000 between changes.
    I drive my truck hard FWIW
  7. Oct 1, 2020 at 6:45 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The old school engine break-in days are long gone.
    Modern machining technology and practices have eliminated this need.
    If you want to change it, then yes, it won't hurt anything. But there really is no dire need to change it.
    Basically, you can, but don't need to.
  8. Oct 1, 2020 at 6:56 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    There's always a break in period. It may not be what it used to be, but it is still there. The manual suggests the first 1000 miles.
  9. Oct 1, 2020 at 6:58 AM
    RedWings44
    Michigan
    I'd change it, it is cheap insurance. When you'd use conventional, it was always 3k miles. With synthetic I'd be comfortable with 5-7k. 10k is pushing it in my opinion unless you're always on flat ground, unloaded, never laboring the engine, etc. Some oils claim 15k, but they're classic cases of just what I mentioned above. Just because you can, doesn't mean you should. I change mine every 5k. Good peace of mind.
  10. Oct 1, 2020 at 7:03 AM
    Alby22
    Ashville, Ohio
    As expected, I’m getting quality feedback from this forum. For peace of mind, I’ll be changing it. Thanks again TW
    Bastek and RedWings44 like this.
  11. Oct 1, 2020 at 7:07 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    What's an oil change?
    Alby22[OP] and NAAC3TACO like this.
  12. Oct 1, 2020 at 7:11 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I believe there are about 4 million TW threads on the subject, but I keep reading them. What’s wrong with me?
  13. Oct 1, 2020 at 7:12 AM
    Knute
    You're looking for the tranny fluid change posts..............
    NAAC3TACO and Greg.Brakes.Tacos like this.
  14. Oct 1, 2020 at 7:15 AM
    RedWings44
    Michigan
    Nothing, it's good for the lifetime of the engine...which may be shorter than some
    fanchaztik and NAAC3TACO like this.
  15. Oct 1, 2020 at 7:44 AM
    davidstacoma
    David
    NC
    Nope. Gone for you but still here for a lot of us. ;)
    There’s still a break in period on a new engine whether you change your oil or not. https://auto.howstuffworks.com/do-still-have-to-break-in-new-car.htm
  16. Oct 1, 2020 at 7:47 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Just be sure you actually drain the engine oil, seems to be an unreasonably common mistake around here.
  17. Oct 1, 2020 at 7:47 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    if it helps you sleep at nite, change it
  18. Oct 1, 2020 at 7:47 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Engine break-in occurs in the first 1000 miles according to the owner's manual, so you're well past it. Whether you "should" change the oil depends on several factors, namely how long you plan to keep the truck and how much road salt you get in the winter.
    If you DIY, be sure to have all the tools ready before you start, like a correct wrench for the cartridge filter housing cap, 3/8" drive ratchet, and breaker bar.
  19. Oct 1, 2020 at 1:25 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I do it just cause it’s fun to see the guys that think they’re gonna out engineer the engineers.
    Hobbs, whatstcp and NAAC3TACO[QUOTED] like this.
  20. Oct 1, 2020 at 2:39 PM
    davidstacoma
    David
    NC
    I do it for the amusement of total trust on engineers by some on TW. After all all Tacoma’s are perfect and never have issues lol.
    Sorry, being an engineer that’s just my take on it. :D
    fanchaztik likes this.
