Oil change problem/question
Discussion in '4 Cylinder' started by numbah57, Aug 8, 2010.
  1. Aug 8, 2010 at 12:26 PM
    numbah57
    numbah57 [OP] GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Ok so i just got back from walmart with two 5qt jugs of mobil 1 5-30wt oil but I happen to look at my owner manual when i got home and its says to use 5-20 and 0-20, will the 5-30 f'up my truck or will it be alright, kinda scared to fill'er up with the wrong shit.
  2. Aug 8, 2010 at 12:27 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    you will be fine i use 5w-30 all the time
  3. Aug 8, 2010 at 12:28 PM
    numbah57
    kahai
    Maui, Hawaii
    You got a v6, I'm 4 bangin...still ok?
  4. Aug 8, 2010 at 12:33 PM
    SKINUM
    SKINUM Well-Known Member
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    It will be fine.
  5. Aug 8, 2010 at 12:34 PM
    numbah57
    kahai
    Maui, Hawaii
    thanks guys, here goes nothing
  6. Sep 14, 2010 at 2:12 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    You should be fine with the 5w-30. I run 5w-20 with better results as far as fuel economy go. This might not be the case for everyone but I got a good 1-2 mpg better.
  7. Sep 14, 2010 at 2:14 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i run 5w 30 all the time.
  8. Sep 16, 2010 at 11:52 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    The best protection against wear is probably a product that is a little thicker (such as SAE 10W-30 or 15W-40) and has more antiwear additives than the oils that support the warranty. The best oil for your vehicle depends on your driving habits, the age of your engine and the climate you drive in, but it is not necessarily the type of oil specified in the owner’s manual or stamped on the dipstick.
    From here... http://www.machinerylubrication.com/Read/518/motor-oils
  9. Sep 16, 2010 at 12:47 PM
    mwilkerson
    mwilkerson Member
    El Paso Texas
    01 prerunner trd
    Found this reference sheet thought it might be helpful.From what i know about Toyota is that some of there newer engines are running tighter oil clearances so they require lighter oil.I have seen Toyota's that are using the heaver oil with out a problem.I am a firm believer in using whats recommended but that's just me.
