Oil Change Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaZL, Jun 4, 2015.
  1. Jun 4, 2015 at 8:27 PM
    TacomaZL
    TacomaZL [OP] Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Hey guys,
    I know these are two dumb questions but I gotta ask any way..
    I have a 2013 Base Model 4 cylinder, the manual calls for 6.1 qts but then says 5.1 imp qts....which one is right? How much oil does mine take?
    Also, how do I know which is the OIL drain plug and which is the TRANSMISSION drain plug... how can I be sure which is which?
    Thanks Guys!
  2. Jun 4, 2015 at 8:36 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Both are correct, you buy quarts, not imperial quarts. I find 6.1 overfills and only put in 5.5 to hit full dipstick.
    Access the oil drain plug from the front of the truck and you can go wrong.
    Jere likes this.
  3. Jun 4, 2015 at 9:10 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  4. Jun 5, 2015 at 1:33 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Rounded off, 6.1 quarts equals 5.1 imperial quarts. These are two different measuring systems. Most oil containers in the US use the quart system; read the label to make sure. Use an online converter to convert from one to the other. 6.1 quarts actually equals 5.078 imperial quarts.
    As for the oil plug vs the trany plug. It's very simple: the oil plug is on the oil pan which is at the bottom of the engine block; whereas, the trany plug is on the trany pan which is at the bottom of the transmission. If you are still uncertain, pick a plug and slowly loosen it until you get a small leak. Use a clean paper towel to soak up the fluid; trany fluid will show as red and engine oil will show as anything but red.
  5. Jun 5, 2015 at 3:44 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Oil plug is behind or above front skid plate. Tranny plug is under center console in cab.
    Ugly Betty likes this.
  6. Jun 5, 2015 at 4:29 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Its great to do your own maint. If your a newbee get a friend to show you the proper way to change oil, We have heard of guys removing the transmission plug by mistake several times. To put oil back in the transmission is a TRICKY JOB.........GOOD LUCK
  7. Jun 5, 2015 at 6:22 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    I was actually worried about this after reading this forum and all the fuck ups on draining transmission fluid when trying to change oil. I laid down under the truck and thought to myself, how do people fuck this up? One is clearly on the engine and the other is clearly on the transmission.
    Takes all types I assume.
  8. Jun 5, 2015 at 6:33 AM
    Lester Lugnut
    And I thought the "Engine overheats, coolant level drops" thread was strange.
    Thanks for posting this. Still recovering from all of the belly-slapping laughter.
  9. Jun 5, 2015 at 8:30 PM
    TacomaZL
    Illinois
    Thanks for the help guys! Do you guys usually use the full 6.1 qts? I feel like just using 6 qts would be enough, am I right?
  10. Jun 5, 2015 at 9:58 PM
    worthywads
    I may be the only 2.7L owner to comment on this thread. I use 5.5 as stated before, you'll find that pretty common, 6 or 6.1 puts you way over the line. I've also never heard of anyone with the 2.7L accidentally drain there transmission by mistake, only V6. Again access the drain plug from the front instead of from behind the front wheels and you can't go wrong.
  11. Jun 6, 2015 at 4:04 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I just use 6 and let it roll. The 0.1 quart of oil isn't even a thought.
  12. Jun 6, 2015 at 7:43 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I use 5.5 qts, you're fine using just 6, dont worry about the extra 0.1.
  13. Jun 6, 2015 at 10:37 AM
    TacomaZL
    Illinois
    Thanks everyone for the replies. I don't have a lot of money so I have to keep my truck running good as long as I can, and am always checking to make sure I'm not screwing things up. Thanks!
    DoorDing likes this.
  14. Jun 7, 2015 at 12:49 AM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    There are some threads out there about the accuracy of the dipstick and whether or not an oil change with filter requires 6.1 qts of oil. According to my findings, an oil change with filter will put me a few tick marks over full on the dipstick with 5.5 qts.
    See here for my results.
  15. Jun 7, 2015 at 8:42 AM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    I put 6 in but I'm going to do 5.5 on my next oil change. The 4 cylinder section of this forum has a great first time oil change thread with pictures. Could also pick up a Haynes manual as well.
  16. Jun 8, 2015 at 11:33 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I feel I've grown as a human being since then.
  17. Jun 8, 2015 at 1:40 PM
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    An oil change is as simple as it get's there are only two drain plugs down there so you have a 50/50 chance of getting it right. LOL
    The quarts amount required is merely a guide the proper way to refill is keep checking the dipstick as you get closer to your required level. Do not overfill or you'll get crank seal leakage, well on the 2nd gen 6 cylinder Tacomas you do.
  18. Jun 10, 2015 at 7:41 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Yeah but the potential fuckup for a new shade tree mechanic is pretty major since it's a sealed Transmission.
  19. Jun 11, 2015 at 2:55 PM
    TacomaZL
    Illinois
    Did the oil change with 5.5 qts of oil, and learned that Toyota put the oil filter in the 4 cylinder Tacoma in a dumbf*** location....thanks all for the help.
  20. Jun 11, 2015 at 4:53 PM
    worthywads
    Filter location is
    Oil filter location isn't bad at all to me. Even with the 5-lug I roll under with my creeper and use an oil filter socket wrench with a 8 inch extension.
    No big deal.
