Oil Change Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaZL, Jun 4, 2015.
  1. Jun 11, 2015 at 5:24 PM
    TacomaZL
    TacomaZL [OP] Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Well part of my problem was I used a bottle jack that barely got my jack stands under, plus I'm hesitant getting under jack stands (mixture of inexperience and being an overall worrier lol)
  2. Jun 11, 2015 at 5:26 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    No jack needed with a creeper.
  3. Jun 11, 2015 at 6:15 PM
    TacomaZL
    Illinois
    How so? Under my truck there's no room whatsoever if I keep it on the ground.
  4. Jun 11, 2015 at 8:50 PM
    worthywads
    Access the oil filter from behind the passenger side front tire on a creeper.
    I have a fumoto valve for the oil pan so again with the creeper and just reach up and open/close the valve.
  5. Jun 11, 2015 at 8:59 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    The oil filter is still BS. I have to take my AP IFS skid plate off every time I want access to the filter. Can't figure anyway around it.
    Edit: Also I give the oil filter a couple short cranks with a wrench. I'm a noob to this stuff as well and took the advice of going hand tight but on my last oil change I had oil blowing all out from the seal. Gave a couple short cranks and solved the problem. Made a huge mess.
  6. Jun 11, 2015 at 9:09 PM
    worthywads
    Sounds like the skid plate is the BS, put a skid plate in the way of your filter and blame the filter location?
    I've managed to have zero oil filter leaks using the hand tighten method, so maybe you just have a wimpy grip?
  7. Jun 11, 2015 at 9:27 PM
    clc clc
    PA
    Lol Both good points, maybe I should work out. It would just be more convenient to have the same setup as the v6 with it on top. I also have to work in a gravel driveway and crawl underneath with no lift.
  8. Jun 12, 2015 at 7:38 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    On the filter, hand tighten until you feel the gasket make contact, then tighten 1/2 to 3/4 turn.
    BE SURE you lube gasket with engine oil before mounting.
  9. Jun 12, 2015 at 7:58 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    worthwads may be a trim person and/or his truck may be lifted.
    I had a 2004 2.4L Tacoma. Similar in a lot of respects to the 2.7L 2nd Gen. Access to the oil filter(same place as 2.7L) was a pain, but doable. The truck was 2WD and didn't have a lot of ground clearance. I would crawl under from behind the RF tire to gain access to the oil filter.
  10. Jun 12, 2015 at 8:28 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    I keep 2 4x4 post laying around. I lay the post down on ground and drive up on them. That gives me plenty to shimmy my fat ass under there.
  11. Jun 12, 2015 at 9:04 PM
    worthywads
    Wrong on both. 5'11" 230lb and stock height.
  12. Jun 13, 2015 at 7:06 AM
    Lester Lugnut
    Another approach used by some on the 1st Gen Forum - 2.4L engine - is to jack up RF of truck - pull tire - then remove rubber apron. Reach in - loosen/remove oil filter - replace oil filter - put it back together.
    I always found it easier as I said above to just crawl under from behind the RF tire.
  13. Jun 13, 2015 at 8:32 AM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Did this for 15 years on mine, just needed to crawl shoulder deep.
  14. Jun 14, 2015 at 8:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Same here, crawl under behind the passenger side front tire. One hand and a zip lock gallon bag to loosen the filter and catch any spillage.
    If you install a filter by hand as described ( turn until the gasket touches and then 3/4 of a turn ) it will not leak unless something is wrong. Usual cause is when the former filter gasket is stuck to the mating surface and you have two gaskets.
    Always make sure the gasket comes off with the filter you are removing.
    NAAC3TACO likes this.
  15. Jul 1, 2015 at 3:13 PM
    #35
    TacomaZL
    Illinois
    Looked through the torque specs for the Tacoma the other day (bored and stuck at the hospital), and noticed the oil pan drain bolt should be torqued to 28 ft lbs, does anyone torque it that much? It seems slightly high to me but I could very well (and most likely am) wrong.
  16. Jul 1, 2015 at 3:26 PM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    I have never used a torque wrench on an oil drain plug, and I'm an old fucker. Good and snug does the trick.
    DrFunker and NAAC3TACO like this.
  17. Jul 1, 2015 at 3:36 PM
    #37
    TacomaZL
    Illinois
    By all means, I wouldn't either, I'm just curious if anyone has ever torqued it that much, that seems a little "much"
  18. Jul 1, 2015 at 3:38 PM
    #38
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Actually I did torque it to spec my 1st time, then I installed a fumoto valve, now I don't worry about it. By the way, is that considered a "mod" ??? :D
  19. Jul 1, 2015 at 5:29 PM
    #39
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    At Acura, we TORQUED the drain bolts to about 30 Ft-lbs. so its typical. IMO, 28 ft-lbs is not that much. I wouldn't be worried.
  20. Jul 1, 2015 at 11:47 PM
    #40
    Jimmyh
    SC
    2012 Prerunner SR5
    Sorry. :(
    I'll try and do better.
