Oil change question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EastMesa_Taco, Jul 14, 2018.
  1. Jul 14, 2018 at 8:53 AM
    EastMesa_Taco
    EastMesa_Taco [OP] New Member
    2016 Mag Gray Met Tacoma Dbl Cab TRD
    Stock...........for now.
    G'morning folks, 1st post here so cut me a little slack. Recently changed my oil & filter with truck parked on a level surface using the plastic drain insert that comes with new filter. I made sure it was securely snapped in, but very little oil drained- nowhere near the 6.2 qt estimated capacity for the 2GR-FKS with tow package.
    Anyone else experience a similar issue & if so, what's the go-to method to drain the majority of your oil? Thanks!
  2. Jul 14, 2018 at 8:57 AM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2024 Tacoma TRD Off Road
    The plastic drain insert just drains the filter.
    You still have to drain the oil pan.
    So, the engine has 12 quarts of oil in it now?
    Shmody likes this.
  3. Jul 14, 2018 at 8:58 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    What does the dip stick say. Also the oil that you drained was it red?
  4. Jul 14, 2018 at 9:01 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Just take it to toyota man lol some people are just better off that way
  5. Jul 14, 2018 at 9:02 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Sounds like you only drained oil from the oil filter---did remove the oil pan bolt? From the way your OP read, it seems like you missed a step...
    tacoguy88 likes this.
  6. Jul 14, 2018 at 9:11 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
  7. Jul 14, 2018 at 9:17 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Change the filter,and then drain the oil pan by taking out the drain plug,MAKE SURE ITS THE OIL PAN YOU DRAIN AND NOT THE TRANSMISSION PAN,the oil pan should drain out about 4-5 qts of oil.
    CONQUESTBLACKROCK and #4TOY4ME like this.
  8. Jul 14, 2018 at 9:19 AM
    lynlan1819
    Tacoma
    Lifted
    The engine does not have 12 qts of oil in it,that would be the transmission.
  9. Jul 14, 2018 at 9:21 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I second this lol
    OP it sounds like you may have now about 12 qts of oil in there which is certain to fuck sth up.
    At least watch a YouTube video how to do it, gotta get under her no way around it
    CONQUESTBLACKROCK likes this.
  10. Jul 14, 2018 at 9:22 AM
    TireFire
    Olympic Peninsula
    You don't get it
    tcjacado, BSFord, Dens71TA and 7 others like this.
  11. Jul 14, 2018 at 9:24 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Watch this video and hopefully this is what you did.
    https://www.youtube.com/watch?v=oNfLLRzAMQc
  12. Jul 14, 2018 at 9:26 AM
    lynlan1819
    Tacoma
    Lifted
    I get it just fine,you guys are assuming he drained the transmission pan,he may or may not have done that,but instead of helping him you guys are just being annoying.
  13. Jul 14, 2018 at 9:52 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No, I think they were saying if OP only drained the filter and not the pan and then added 6 quarts of oil he now has 12 in the engine.
  14. Jul 14, 2018 at 10:01 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Absolutely no offense to you, but you should have someone who knows what they’re doing take care of that. If you can’t change your oil you should ask someone to show ya or just fork out some money and know it was done correctly. You certainly will be f*****g stuff up in your engine if you’re driving like that. Your seals will go bye bye along with your other components. Your brand new truck may have just gotten some lifespan taken out!
    Your drain plug for the oil pan should be towards the transmission, and it should have an opening through your skid plates or you may need to remove them. I have not done my own yet since I have been getting them at Toyota. But do that, change your oil filter and then put everything back.
  15. Jul 14, 2018 at 10:01 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    If you are serious... As others have said. You only drained the oil filter. You need to drain the main oil pan by removing the bolt from further back under the middle section. It will drain approximately 6 quarts. Replace everything and fill.
    tcjacado and Plain Jane Taco like this.
  16. Jul 14, 2018 at 10:08 AM
    TireFire
    Olympic Peninsula
    Still don't get it. If you a really read his post he only drained the oil filter and don't even go under his truck at all.
    I think this might be a troll actually
  17. Jul 14, 2018 at 10:21 AM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    He has to go under the truck to drain the oil filter.
    The other guy who said 12 quarts now... assumed he added another 6 quarts after only draining the oil filter which would now have 12 quarts if thats what the OP did.
    This is all an assumption.
    Maybe the OP after draining everything looked like he only drained out 4 quarts, who knows at this point.
    TireFire[QUOTED] likes this.
  18. Jul 14, 2018 at 10:27 AM
    TireFire
    Olympic Peninsula
    Had no idea. I have a second gen so filter is right there if you open the hood
    tcjacado likes this.
  19. Jul 14, 2018 at 10:29 AM
    Rustytaco71
    2018 4Runner
    Lucky guy, wish they would’ve done it that way in the 3rd gens. My 4Runner had it underneath though so I’m curious if it was a new thing.
  20. Jul 14, 2018 at 10:32 AM
    TireFire
    Olympic Peninsula
    You musta had a V8 4Runner then, huh?
    Cuz the 1grfe runners have it up top too
    Edit: I'd take a low oil filter with a V8 over the 4.o in my truck any day lol
    shakerhood likes this.
