Oil change question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Devilfan, Jul 2, 2024.
  1. Jul 3, 2024 at 8:39 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
  2. Jul 3, 2024 at 9:28 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    :cheers:
  3. Jul 4, 2024 at 4:44 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Yeah but it’s the satifaction of getting 5% off :D
    I also get the 5 quart jugs of Mobile 1 on sale. Full synth changes under $30 for me.
    2015WhiteOR likes this.
  4. Jul 4, 2024 at 5:03 AM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    if ONLY the 2TRFE was so easy at ground level :(
  5. Jul 4, 2024 at 6:04 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Bingo. If you shop ahead and catch deals, you can always be doing premium synthetic oil changes for cheaper than a shop would charge for conventional.
    PzTank[QUOTED] and Torspd like this.
  6. Jul 4, 2024 at 7:38 AM
    TacoTuesday1
    SD CA
    you don’t have to look for deals
    Walmart rotella T6 is and has been $23 as well as other places
    or become the magical profession of mechanic using leftover oil for free making it $5
  7. Jul 4, 2024 at 7:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Are you sure there was no oil in the filter? Did you poke at the anti drain back valve flapper through the holes with a pocket screwdriver?
  8. Jul 4, 2024 at 8:09 AM
    Devilfan
    Devilfan [OP] Well-Known Member
    No, I didn't poke it. There had to be oil flowing through it because there was a light film it it. I just never changed an oil filter and not have a little oil spill out when I removed it.
  9. Jul 4, 2024 at 10:44 AM
    kidthatsirish
    The 2TR-FE is pretty dang easy bro. You don't even have to jack it off the ground!
  10. Jul 4, 2024 at 11:47 AM
    Black97v6MT
    iMA0
    tacoLand USA
    Cannot reach the oil filter on the shoulder on the ground, no clearance, it's upside down high up there!
  11. Jul 4, 2024 at 12:21 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Normal,nothing to worry about like others have said.
  12. Jul 4, 2024 at 1:07 PM
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    when I change... first i put a couple holes in the top of the filter with an electrician splicing knife, and then crawl under and pull the drain plug. by the time the under is done i screw off the filter and all the oils is always drained out of it, so no spill no mess.
  13. Jul 4, 2024 at 1:59 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Get a Fumoto Valve and it gets even easier…
    R0dzilla75 and Monkeybutt2000 like this.
  14. Jul 4, 2024 at 4:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Can you go through the wheelwell?
    Black97v6MT[QUOTED] likes this.
  15. Jul 4, 2024 at 5:12 PM
    #35
    Black97v6MT
    iMA0
    tacoLand USA
    i have not checked on that way, will take a good peek at it!
