Oil Change Questions - new owner
Discussion in 'Technical Chat' started by ammoriso, Jun 1, 2007.
  1. Jun 1, 2007 at 8:11 PM
    ammoriso
    ammoriso [OP] New Member
    Hey Everyone,
    I just bought a 2005 with about 30k miles. I figured it was time to switch to Mobil 1 since I'm a huge believer in synthetic oil, but after I filled it back up with the perscribed 6.1 quarts, it seemed a bit overfilled. I couldn't really be sure though because the dipstick seems impossible to read, especially at night by flashlight!
    I'm looking for advice as to the oil capacity other people acutally use, and, am I going blind, or is the dipstick a pain?
    Thanks! Hope to talk to many of you in the future...
  2. Jun 1, 2007 at 11:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    05 4cyl or v6?? if its the v6....its 5.5 quarts, and i think the 4cyl is almost 5 quarts. where did you see 6.1 quarts at??
  3. Jun 2, 2007 at 4:24 PM
    ammoriso
    It's the 2.7 L...
    Quoting from my owner's manual:
    Oil Capacity (drain and refill)
    L (qt., Imp. qt.)
    2tr-FE engine
    With filter 5.8 (6.1, 5.1)
    Without filter 5.1 (5.4, 4.5)
    That says to me that the capacity with filter is 5.8L or 6.1 qts.
    Thanks for the reply...
  4. Jun 2, 2007 at 7:08 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I have not changed the oil on my new truck yet, only 1600 miles so far so it's not time, but on my 2004 with the 2.7 I found that perhaps from completely empty it may have been 6 quarts, however, from the design of the oil pan on that truck combined with the slight angle of my driveway, it never completely drained, so I stoped at 5 quarts, started the truck and then checked and added as needed. It may have added another 20 minutes to the job, but compared with overfilling the oil it seemed well worth the extra time.
    Just my $0.02
  5. Jun 2, 2007 at 8:33 PM
    wash23
    wash23 Member
    Sounds like a good strategy. Always easier to add than to take away for me.
  6. Jun 3, 2007 at 9:12 AM
    RaiderSix
    RaiderSix Well-Known Member
    I do the same underfill/run/let oil settle/add more type oil change as well. I went synthetic on my bike, but flinch at the high oil cost when it comes time to change it. :D The bike spins at some crazy high RPMs so I figure the synthetic is doing some good in there.
  7. Jun 3, 2007 at 3:50 PM
    wash23
    wash23 Member
    Bike, huh? I'm using Mobil 1 in two of mine. Plan on changing two Harleys from Syn3 to Mobil 1 next change. What bike you got?
  8. Jun 3, 2007 at 4:38 PM
    RaiderSix
    '02 Yamaha R6.
  9. Jun 3, 2007 at 4:53 PM
    wash23
    wash23 Member
    Nice! My 600 (636) is an '05 ZX-6R. Definitely they are crank spinners.
  10. Aug 11, 2008 at 7:28 PM
    Cavender76
    Cavender76 Well-Known Member
    Clint Cavender
    Mobile, Alabama
    2020 SR5
    Removed Window Sticker
    Oil is always still in your motor.
  11. Jun 3, 2010 at 8:10 PM
    blazrmike
    blazrmike New Member
    Los Angeles, CA
    Base model. 2TR-FE 4 Cylinder, 5 speed
    sorry to bring up an old thread but this little typo in toyotas owners manual about 6.1 quarts in the 2TR-FE 4 cylinder engine has me going crazy! i can't get in more than 4.9 quarts with an oil filter change. I think this is why my truck is leaking in the rear main seal because of all the years it had the 6.1 quart oil changes. this dipstick is also a pain to read! anybody else having this problem?
  12. Jun 3, 2010 at 8:38 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    On my 07 the dip srick is hard to read...scratching it up with some rough sandpaper in a "X" pattern seems to help.
  13. Jun 4, 2010 at 6:08 AM
    Barnone
    Barnone Guest
    Another good tip. My auto trans dipstick is hard to read also.
    Thanks
