Oil change questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pdeinc, Mar 25, 2022.
  1. Mar 26, 2022 at 1:58 PM
    #41
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Check with your town or city if they have a recyling bin if a resident. They do here that you bring your used oil, or coolant to dump in 50 gal. drums.
    NoOne likes this.
  2. Mar 26, 2022 at 2:34 PM
    #42
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    True, ours takes gas, coolant, oil, filters, containers. Good reminder!
  3. Mar 26, 2022 at 2:49 PM
    #43
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Good tip, have never heard of that around here, but definitely worth checking into
  4. Mar 26, 2022 at 3:09 PM
    #44
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    I got my tires from Discount tire. While I can rotate the tires, they rotate them, balance them and fix flats for free. I get to sit in the truck and watch them do it and they impact the nuts on, and then torque them to specs with a torque wrench for the final torque. I have double checked behind them and they are accurate on the lug torque. I change my own oil ad filter.
  5. Mar 26, 2022 at 3:18 PM
    #45
    IntrepidTraveler
    IntrepidTraveler Well-Known Member
    Irv
    Aiken SC/ Carlsbad NM
    2020 TRD Pro Army Green
    To be clear, is that Amazon genuine Toyota part linked above good for a Gen 3 Taco, specifically a '20 TRD Pro?
    After one of my early "free" oil changes, I drove to work, and when I got there, the oil light came on. There was a good size puddle of oil under the truck in no time. The dealer had it towed in and fixed it, no harm no foul, but I'm guessing when they changed the oil, the over torqued the plastic canister housing. I'm thinking I'll get the aluminum one if that's the right one for my truck, even if I don't do oil changes myself.
  6. Mar 26, 2022 at 5:04 PM
    #46
    joserwb503
    joserwb503 Member
    this worked on my 18 taco
  7. Mar 26, 2022 at 5:37 PM
    #47
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I bought this one:
    https://www.amazon.com/gp/product/B07984MX2G?ie=UTF8
    And will be installing it when I do the next oil change.
