Oil Change Recs in manual wrong?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elioregon, Feb 12, 2021.
  1. Feb 12, 2021 at 10:34 AM
    elioregon
    elioregon [OP] Well-Known Member
    Eli
    2014 Tacoma 2.7L MT ACLB
    Every time I change my oil (5,000 miles or 6 months whatever comes first) on my 2014 2.7 MT I change the oil and filter. And if I follow the recs in the manual it's Always over the line and I have to go back under and drain some out. This time I only put in 5.5 quarts, which is recommended if you're NOT replacing the oil filter, but i did replace the filter because I do that every oil change. and It's Still slightly above the line on the dipstick. Not enough for me to crawl back under there and pull the plug to try to drain just a little bit out, but still slightly over. I wanted a few months thinking "maybe the filter just needs to soak up some of the oil" but it hasn't changed. Anybody else have this happen to them? BTW I use Valvoline Synthetic 0W-20.
    tacogrizzly and TreeFortRichard like this.
  2. Feb 12, 2021 at 10:44 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I use 5.5 qts and I always change the filter. That's enough oil, like you said.
    If you're using synthetic like you said, 5k mile changes are twice as frequent as you need. I use Mobil 1 and change from 10-12k miles (mostly highway) and there's still life left per the Blackstone analysis.
  3. Feb 12, 2021 at 12:05 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Don't worry so much.
    Change your oil and filter at the interval you want. I wouldn't exceed 10 kmiles.
    Add the amount of oil as recommended in the manual (use the without filter fill). When finished, start the engine, let it run for a few minutes, shut off, allow a couple minutes for drain back to the oil pan. Check your fill level. Add if needed.
    The engine won't go BOOOM!!!! if its a little over or under the dipstick fill line. This isn't precision surgery.
    BTW, 0w20 seems a bit low in viscosity. Check the manual for the viscosity. Use that.
  4. Feb 12, 2021 at 12:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The filter probably holds about .5 qt.
    You need to start the truck before it enters the filter. So this may be why you are reading too much?
    Anyways, I go by the dipstick. Not the book.
    Fill the truck up with oil until it’s close to the full mark on the dipstick. Start the truck. Turn the truck off let and let it sit a few mins. Then fill it on up the rest of the way.
    eherlihy likes this.
  5. Feb 12, 2021 at 12:14 PM
    mrcheap
    mrcheap Well-Known Member
    My 4.0 is at the top line with 5 qts with a filter change. I think the book says to add 5.5
    Rambo MARINE Recon likes this.
  6. Feb 12, 2021 at 12:15 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Filter holds like .2
    ive always done 4.3qt and its right smack in the middle everytime
    TnShooter likes this.
  7. Feb 12, 2021 at 2:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The specs for the 2.7 state 6 quarts on a drain and filter.
    I have always used 6 quarts. Yes it does show a tad over the full mark on the dipstick. Not enough to hurt anything. Way too much trouble to fiddle with a half quart of oil.
    Follow the book you will be fine. Mountain out of a mole hill.
  8. Feb 12, 2021 at 2:50 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I have always dumped 6 quarts in mine as well. It is usually a hair over, but like @Jimmyh it never concerned me. Easy to remember and measure out this way too.
    Mine burns a little oil anyway (seems normal on the 2.7, especially with a fully synthetic oil) so I have to add about 1/4-1/2 quart at 3000 miles.
    elioregon[OP] likes this.
  9. Feb 12, 2021 at 5:15 PM
    TacoTuesday1
    SD CA
    In a vehicle
    with an internal combustion engine
    that uses oil as a lubricant
    there is a dipstick
    with a min and max fill line
    you get it anywhere on that
    you could set the oil to min
    or max
    or halfway in the middle/in between
    whatever amount that takes
    as well as filling the oil filter with oil during the change or running the engine, because it takes some of the oil in it, depending on the filter size
    It Is Not That Complicated...
    when you do it enough times, you will get familiar with what the engine takes
    whether that be 5.5
    or 5.4
    it is usually better it to start under
    because if you're a bit low, it's much easier to just add some, than to remove some if overfilled
    you might be able to use a tool to suck some out of the dipstick tube, instead of opening the drain plug again
    or opening the filter (if 4.0) to drain whatever is in the filter out of the metal cup hole
  10. Feb 12, 2021 at 6:02 PM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    5 quarts puts mine dead on full.
    2015WhiteOR likes this.
  11. Feb 12, 2021 at 6:03 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You will almost never get every single drop of old oil out. If you add full capacity when you change oil you may well over fill. I always add a little less than required. I then start the engine and let it run for a minute or so to fill up the filter. Then I let it sit for a few minutes while I put up my tools and clean up. After about 5 minutes I check the dipstick and add what is needed.
  12. Feb 12, 2021 at 6:09 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Posting like this
    Doesn’t make you
    Sound smarter
  13. Feb 12, 2021 at 6:25 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    You may be over thinking it. As long as you’re not putting 10 qts in, you’re fine.
  14. Feb 12, 2021 at 6:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've dumped in 6 qts in both my 2 .7 and 3.4 since 1998. I don't even bother checking the oil until the next oil change. Usually around 7k miles.
  15. Feb 12, 2021 at 6:43 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    So over thinking this. Just put in what the book says and call it a day. You’ll never under fill or overfill the engine period.
    Jimmyh likes this.
  16. Feb 12, 2021 at 10:51 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i dont even look anymore 5 full quarts and its always right on the full line.
  17. Feb 13, 2021 at 1:07 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    OP has a 2.7L four cylinder that takes 6 quarts with a filter as per the Owners Manual.
  18. Feb 13, 2021 at 4:24 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    This thread makes my head hurt.
  19. Feb 13, 2021 at 9:49 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The line is just there as recommendation, lots of margin. Imagine what happens when you’re driving on a steep incline or decline. Don’t lose any sleep over it.
  20. Feb 13, 2021 at 7:12 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    sounds like sarcasm but that’s ok, that sells here
