Oil change thread???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrFixit420, Mar 26, 2020.
  1. Mar 26, 2020 at 9:49 AM
    MrFixit420
    MrFixit420 [OP] Well-Known Member
    Portland Oregon
    2014 TRD Off Road DCSB
    Eibach Pro Stage 1 on 2nd clip, 3 leaf Icon AAL's in back.
    I have found a thread on everything except a "how to" on a basic oil change.
    I figured it would be linked in the how to area of the mods thread but I didn't see it.
    A search didn't help either.
    SO am I just missing something and can't find it or is it so basic no-one has done a write-up.
    Mostly just looking to see if anything extra had to be done to get to the oil pan plug or if there were any hints or tips on how too's.
    Thanks
  2. Mar 26, 2020 at 9:56 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Dude, lay off the 420
    it’s in the mods & tutorials
    Kolter45, TireFire and Jojee117 like this.
  3. Mar 26, 2020 at 10:00 AM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Kolter45 and MrFixit420[OP] like this.
  4. Mar 26, 2020 at 10:33 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Luckily for you I don't think an oil change could be any easier than on a Tacoma.
    Kolter45, Jojee117 and MrFixit420[OP] like this.
  5. Mar 26, 2020 at 10:35 AM
    MrFixit420
    Portland Oregon
  6. Mar 26, 2020 at 10:38 AM
    MrFixit420
    Portland Oregon
    These mods and tutorials or somewhere else cause I can't find it here.
    https://www.tacomaworld.com/threads/2nd-gen-tips-mods-more.7174/
    There is probably another one I haven't seen so please link.
    Those of us in the cannabis business are considered essential during this time of crisis. We supply medicine to many.
    Shaggs likes this.
  7. Mar 26, 2020 at 10:40 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    The 4.0 taco is probably the easiest vehicles to do an oil change on. Takes 1.3 minutes.
    Chris(NJ) and MrFixit420[OP] like this.
  8. Mar 26, 2020 at 10:42 AM
    coopcooper
    alberta canada
    Ask your boyfriend for help then.
    TireFire, Jaypown and TexasWhiteIce like this.
  9. Mar 26, 2020 at 10:44 AM
    MrFixit420
    Portland Oregon
    Please show the tutorial on how you open 6 quarts of oil and poor them into the engine along with changing the filter in 1.3 minutes and I will. But since you can't do that I will just ignore your comment.
    Oh I forgot to add the draining of the oil to that.
    So lets see your 80 second oil change. :rofl:
  10. Mar 26, 2020 at 10:47 AM
    Jojee117
    Joe
    MT
    Honestly if I cant find something in the search bar on here, I'll just search it on google and 90% of the time a TW page will be one of the first results.
  11. Mar 26, 2020 at 10:47 AM
    coopcooper
    alberta canada
    its not that hard lol. drain oil replace filter put the plug back in fill oil done.
  12. Mar 26, 2020 at 10:48 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Takes more than 1.3 minutes to clean up the spill from the inverted oil filter...
    Shaggs and MrFixit420[OP] like this.
  13. Mar 26, 2020 at 10:49 AM
    coopcooper
    alberta canada
    clean? We don't do that here.
    Shaggs likes this.
  14. Mar 26, 2020 at 10:50 AM
    Pigpen
    Dan
    Northwest Montana
    Just make sure you don't drain the transmission accidentally. It's been done a lot here.
    MrFixit420[OP] likes this.
  15. Mar 26, 2020 at 11:14 AM
    MrFixit420
    Portland Oregon
    LOL. Going to get to that next and may do it at the same time but thanks for the heads up. Putting an extra 6 quarts in the engine and running on an empty tranny might make for a catastrophe. :bananadead:
    Jojee117 likes this.
  16. Mar 26, 2020 at 11:56 AM
    TexasWhiteIce
    Texas
    cool story bro
  17. Mar 26, 2020 at 11:59 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Now we can turn this into what brand oil is best! Pennzoil :duh:
  18. Mar 26, 2020 at 12:47 PM
    MrFixit420
    Portland Oregon
    :bananadance::broccoli::dancingbacon::cheers:
    Shaggs likes this.
  19. Mar 26, 2020 at 12:56 PM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Your name on here is, "mrFixit420" but you created a thread on looking for a how to for an oil change? o_O
  20. Mar 26, 2020 at 1:25 PM
    MrFixit420
    Portland Oregon
    Correct. I was looking to see if I needed to remove anything to get to what I needed. The oil change part was not in question it was access to the drain plug I was mostly interested in. And thanks to the members here I also found out about the filter drain hole and how not to make a mess.
    I could have jumped under there and done it without this knowledge and done it just fine but would probably not have seen that drain port and leaked oil on the engine.
    It's always best to ask before diving into something. Sometimes you can't see the rocks under the water.
    As to my moniker. I have done everything from Aircraft electrician working for Lockheed to ASE certified mechanic at my own shop. I've fixed every type of equipment in restaurants from under the floor to on the roof. I built and installed satellite systems back when the dishes were 12' and larger. I could add more to the list but you get the idea.
    So before I crawl under my rig I want an idea of what I actually have to do rather than guess. For all I knew the skid plate may have had to be removed or worse.
    Thanks for asking.
