oil change... time vs mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Aug 19, 2025 at 11:44 AM.
  1. Aug 19, 2025 at 11:44 AM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've been changing my oil every 1,000 miles due to short trips, towing the boat, wheeling on dry dusty dirt roads, etc. Looking back through my records from the last 37 changes the time between changes varies between 2 months to 1 year... average time 6 months. Just curious what others time periods are... do you think 1 year is too long even though it's only been 1,000 miles? Sending a sample in to Blackstone... oil is usually pretty dark (Mobile One synthetic 5W-30.) What's the time between your changes?
  2. Aug 19, 2025 at 11:48 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    1 year or 5,000 miles, which ever comes first, is good enough for me.
    fatfurious2, Scrapla, TACOTU3 and 4 others like this.
  3. Aug 19, 2025 at 11:49 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Every 5K miles for me, 6 months or 6 years.....send it :anonymous:
  4. Aug 19, 2025 at 11:55 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I don’t really see the reasoning behind changing to a calendar schedule, exactly. Does the bottle of oil expire on the shelf at the auto parts store?
    That said, if you do a lot of idling you are going to want to change your oil before hitting 5k miles. I guess in that case, it might be useful to put an hour-meter on the engine and change the oil based on that.
    The other thought I have is that living the in the northeast, I don’t want to change my oil in the dead of winter. So I might change the oil in December rather than waiting to hit 5,000 miles in February.
    TS4x4 and ABA180 like this.
  5. Aug 19, 2025 at 11:58 AM
    scocar
    scocar Patron of the Farts
  6. Aug 19, 2025 at 12:02 PM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    o_OIs it Friday already?:confused:
    Oh, every 5K miles without exception.
  7. Aug 19, 2025 at 12:04 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Lawfarin likes this.
  8. Aug 19, 2025 at 12:05 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Darkness of oil has little to do with the chemical robustness of the oil. Your main driver for changing oil should be "TBN" (total base number) which reflects the oil's ability to resist acidification.
    There are some oils that can be used for 10,000 miles and still end up with a good TBN which means the oil is still very usable.
    TartanEagle likes this.
  9. Aug 19, 2025 at 12:09 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I watch a ton of YouTube motorhead videos to relax including I Do Cars, Farm Project and the Motor Oil Geek to name a few. Seems the general advice I've seen is that these folks seem to recommend lowering modern manufacturers OCI's to about 5k miles max but with the properties of modern synthetics, calendar time doesn't make much of a difference. A year is likely fine but would be interested to hear what Blackstone has to say since I use Mobil 1 and also drive my 2nd gen no more than a few thousand miles a year.
    OffroadToy[OP] and Jakerou like this.
  10. Aug 19, 2025 at 12:09 PM
    TnShooter
    Deogee
    STOCK
    I'd be lying if I said I haven't done that.
    300zx set in a garage for over 3 years with no oil change.
    Driven less than 1,000 miles in those 3 years.
    But this is the internet, so that car had to have been ruined by my neglect.....
  11. Aug 19, 2025 at 12:10 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    194,000 miles and I've always done every 5000 miles regardless of time.
    2015WhiteOR and Jakerou like this.
  12. Aug 19, 2025 at 12:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    Roughly 1 yr or 10k miles whichever comes first.
    Usually it's the 1 year-ish.
    Pro tip. Color, taste or smell may help ID a vehicle fluid. But it won't tell much about the condition of the fluid.
    Exception: Automatic transmission fluid is best when a pinkish red. When it's blackened, it's a problem. I can check this on my transmission dipstick, which many of you cannot. :p
    #savethedipsticks #dipsticksmatter
  13. Aug 19, 2025 at 12:25 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There is alot of factors that determine how long the oil is good for.
    This is why many vehicles oil life systems don't just factor in miles but also engine temp, load, runtime, idle time, actual time, etc, while they still go too long IMO they are alot more accurate than just counting miles.
    Short trips especially in cold ambient temps are the hardest on oil because it never gets hot enough to burn off moisture and also the engine runs alot richer when cold so fuel dillution is higher especially in DI engines.
    Extended idling also shortens oil life.
    If most of your trips are under 10 miles I wouldn't go longer than 6 months, oil is cheap compared to replacing an engine.
    TOMB and ABA180 like this.
  14. Aug 19, 2025 at 12:48 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    37,000 miles and 37 oil changes!?!
    Dude, you could literally be selling your old oil for money
  15. Aug 19, 2025 at 12:51 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    NOT FRIDAY!
    every 5K
    [or in reality probly closer to 6K by the time i get my shit together and actually do it]
    po35042 and Citron like this.
  16. Aug 19, 2025 at 1:09 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Every thousand miles, total waste of time and money. Just follow the OM.
    MtnMan307 and TartanEagle like this.
  17. Aug 19, 2025 at 2:08 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    259,000 miles. I changed it every 10,000 miles for the 1st 180,000 miles. Full synthetic only. At that time I drove about 20,000 miles/year so it worked out to about every 6 months. For the last 80,000 miles I don't drive it as much. It's a 3rd vehicle now used mostly around town or for shorter road trips within about 50-75 mile radius. Because I use it differently now, I have now change at 5000 miles. In the 18 years I've owned it I've never added a drop of oil between changes. It still doesn't use any.
    Every 1000 miles is insane unless you only drive 1000 miles/year. Oil should be changed every year regardless of miles. I wouldn't do it at any more often than 5000 miles or 1 year.
    lowmower, CrashZone and a400ryan like this.
  18. Aug 19, 2025 at 3:56 PM
    OffroadToy
    some of the oil changes in the winter months are 1,000 miles after 12 months... normal is around 1,000 miles every 6 months or so. Just curious... is your oil pretty dark when changed out? Mines dark (almost black)... allways thought is was due to the short trips, towing fishing boat up a mountain to lake at 6,000', and occasional offroading on dry dusty dirt roads.
  19. Aug 19, 2025 at 4:01 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Your oil being black is normal. It will vary from engine to engine but in my experience, oil turns dark/black VERY quickly and is not an indicator of it being bad or needing to be changed.
    Since you're sending your oil in to Blackstone, I suggest you ask them about this. You're going to get a whole lot of armchair quarterbacks here online. This topic has been beaten to death and you'll see people equally passionate about their opposing opinions but none of these people have the knowledge that Blackstone does.
    Now, my $0.02. I've been getting my oil analyzed for nearly 20yrs now. Every car. Every oil change. I've also spent some time listening to the Blackstone podcast from time to time. Based on my experience and knowledge, oil should be changed based on mileage and conditions - not time. Time intervals are typically not helpful and usually just result in you changing your oil more often than you need to. Which isn't harmful, but it is wasteful/expensive. I'm sure there are some use cases where time based OCI's make sense, but those will be few and far between. Blackstone always provides their suggested OCI and I follow their guidelines. Every car we have is on a different OCI, which shouldn't be a surprise considering they are all different engine designs and different use cases.
    Additionally, one of my cars sits most of the time and sees very little mileage. I've gone multiple years without changing the oil and the oil analysis always comes back just fine. Never has Blackstone told me to change it more often.
  20. Aug 19, 2025 at 5:33 PM
    Moto521
    Moto521 Well-Known Member
    2006 Tacoma DCSB TRD OR
    While modern oils can last longer, the plain fact that contaminates are suspended in the oil. And the only way to get rid of them is to put fresh oil in. Now is your oil still looks new after 5,000 miles, well...
    For me, I'd rather not pump dirty oil through my very expensive engine for an extended period of time. Thirty bucks every 4k or so provides me peace of mind.
    lowmower, OffroadToy[OP] and ABA180 like this.
