oil change today and oil was a deep red ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johnnym, Feb 5, 2011.
  1. Feb 5, 2011 at 4:12 PM
    #41
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I wonder if he has some type of batman symbol we can project towards AZ?
  2. Feb 5, 2011 at 4:13 PM
    #42
    johnnym
    johnnym [OP] Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    will do i ordered there kit
  3. Feb 5, 2011 at 4:14 PM
    #43
    jandrews
    '09 FourDubDee TRD OR
    RP is purple for about 2 minutes at most.
    Every time I change my oil (I use RP in both cars) I run them for about 2 or 3 minutes and check the dipstick, and the oil on the dipstick is clear.
    If you drive you vehicle anywhere, that purple dye immediately burns off.
  4. Feb 5, 2011 at 4:17 PM
    #44
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Classic signature! Now back to the oil issue.
  5. Feb 5, 2011 at 4:21 PM
    #45
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You stated it's been 4 months since the Jiffy Lube oil change and you hadn't driven the truck in the last 2 months. Since the oil was only used for 2 months maybe it just still looks new with a reddish/golden tint?
  6. Feb 5, 2011 at 4:24 PM
    #46
    johnnym
    john
    NH
    i guess its possible but i have never seen motor oil like that after a couple months. Thats why i figured id share it with everyone here and get others opinions on it
  7. Feb 5, 2011 at 4:25 PM
    #47
    Sandhopper
    Sandhopper Well-Known Member
    Just because it's a Taco does not mean they should have refilled it with picante sauce... Blackstone is real good, I use them to analyze every change. Good Luck!
  8. Feb 5, 2011 at 4:28 PM
    #48
    johnnym
    john
    NH
    thanks sand
  9. Feb 5, 2011 at 4:56 PM
    #49
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    looks normal. i have drained oil that sat in my old car before. same color. no need to worry.
  10. Feb 5, 2011 at 5:17 PM
    #50
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The only reason I can think of in which that oil will be a red color is a filled it with transmission fluid. I have never seen a reddish colored motor oil before. Definitely send it out to have samples taken.
  11. Feb 5, 2011 at 7:11 PM
    #51
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....I couldnt see the pics on my phone, but like mentioned, it looks normal.
  12. Feb 5, 2011 at 7:14 PM
    #52
    johnnym
    john
    NH
    alright im still going to get it tested just to understand it better.. thanks guys
  13. Feb 5, 2011 at 7:53 PM
    #53
    GotLift37
    North East AL
    07 4Runner 4WD
    i wouldnt even send it in if i was you.
  14. Feb 5, 2011 at 7:53 PM
    #54
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Never hurts to pull a sample every now and then.
  15. Feb 5, 2011 at 9:10 PM
    #55
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    maybe it's that time of the month for your tacoma?
  16. Feb 19, 2011 at 8:08 AM
    #56
    johnnym
    john
    NH
    so i just wanted to update this..
    here is the printout from blackstone labs ..
  17. Feb 19, 2011 at 8:11 AM
    #57
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That report is as good as any I've rcv'd from them....I wouldn't worry.
  18. Feb 19, 2011 at 8:14 AM
    #58
    johnnym
    john
    NH
    yes im very happy with it and happy with there company i will be using them in the future
  19. Feb 19, 2011 at 8:30 AM
    #59
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The fuel is higher than it should be......Could be indicative of alot of short trips.
  20. Feb 19, 2011 at 10:13 AM
    #60
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks for posting the results. Peace of mind for $30 or so, will worth it IMHO.;)
