Oil change,Too much oil??
Discussion in '1st Gen. Tacomas (1995-2004)' started by krienhart, Dec 30, 2014.
  1. Dec 30, 2014 at 8:19 AM
    krienhart
    krienhart [OP] Member
    2003 Tacoma SR5 TRD
    I have the 2003 Tacoma prerunner 4cyl 3rz-fe, did my oil/filter change and added 5.7 quarts as per manual. Oil is over full line on dip stick. Is this ok? Thank you everyone!
  2. Dec 30, 2014 at 8:21 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    The 4 banger takes 5.7 Qts?
  3. Dec 30, 2014 at 9:02 AM
    krienhart
    2003 Tacoma SR5 TRD
    ENGINE LUBRICATION​
    Oil capacity (drain and refill),
    L (qt., Imp. qt.): and does this mean Liters, Quarts, Imperial Quarts????
    Two- wheel drive models except Pre
    Runner
    2RZ- FE engine
    With filter 5.5 (5.8, 4.8)
    Without filter 4.8 (5.0, 4.2)
    5VZ- FE engine
    With filter 5.4 (5.7, 4.8)
    Without filter 5.1 (5.4, 4.5)
    Four- wheel drive models and Pre
    Runner
    3RZ- FE engine
    Does not say anything about 4 or 6 cylnder
  4. Dec 30, 2014 at 9:16 AM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    Start it up for a minute shut it off check again the dip stick won't lie always go off of it
  5. Dec 30, 2014 at 9:17 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    No. Drain until its in the middle.
  6. Dec 30, 2014 at 9:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    1) correct
    2) looks like you picked correctly
    3) doesn't need to say 4 vs 6 if you've picked your model correctly. The model is exclusive to the engine type.
    Have you started the motor to fill the filter yet? If not, run it for a minute or two, check for leaks, then let it sit for 10 min before checking again (on level ground of course)
    Let us know what you find then.
  7. Dec 30, 2014 at 10:02 AM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    My dealership has been changing mine for 140,000 miles. Every time I get it back its just as you described. I wouldn't worry about it. My truck now has 184,000 on it and runs great.
  8. Dec 30, 2014 at 12:35 PM
    krienhart
    2003 Tacoma SR5 TRD
    Drove it for a few miles, dipstick registers less than 1/4 inch above full line/hash marks on stick...
  9. Dec 30, 2014 at 2:58 PM
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    That's not enough to worry about. Leave it as is, you'll wind up burning that off before too long anyway. If you start dumping in 1+ quarts excess, then you may wind up with some issues, but that small amount above full - fahgedaboutit.
  10. Dec 30, 2014 at 4:14 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    actually it does, the engine number says what it is:
    2RZ- FE engine - this number means its a 2.4L 4 cylinder engine
    5VZ- FE engine - this number means its a 3.4L 6 cylinder engine
    Runner
    3RZ- FE engine - this number means its a 2.7L 4 cylinder engine
    when I do an oil and filter change on my 2.4L 2rz engine I put one 5 gallon jug of mobil one full synthetic in it and it is at the perfect level
  11. Dec 30, 2014 at 4:18 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    ^^ This
    Be sure the filter is full of oil by running it for a minute or two. Check again shortly after shutdown.
  12. Jan 1, 2015 at 12:27 PM
    SGaynor
    SGaynor Member
    Scott
    Bristol, TN
    '03 Tacoma Extraca V6 SR5 TRD
    :eek:
  13. Jan 1, 2015 at 1:33 PM
    jkulysses
    jkulysses Well-Known Member
    Jake
    Oregon
    01' Tacoma 4x4 3.4l 5 spd
    I just put 5 quarts in & that always puts the level right at the full mark on the stick after the motor has been ran. I'm assuming it drains out all but a half of a quart for whatever reason because my manual also says it should hold like 5.7 quarts.
