Oil change whoopsies
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hour, Mar 15, 2013.
  1. Mar 15, 2013 at 6:51 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    When I had a plug, I'd put it on top of the new filter.
    Plug went in before the filter went on.
    Now I just remember to close the Fumoto before changing the filter.
    Likewise with the oil, radiator, or any other cap in the engine compartment... they go on top of the hood latch. Can't close the hood without putting the cap back on.
  2. Mar 15, 2013 at 6:56 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Seven years on my fumoto drain valve. I still take the skid plate off for the oil filter.
  3. Mar 15, 2013 at 7:44 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I totally agree! He's like " UUUUUhg, Goddammit! :rofl: It's right at 1:20! Then he goes about his business. Oh fuck me I can't stop laughing! I just drooled on my keyboard from laughing so hard!
  4. Mar 15, 2013 at 11:33 PM
    MindOVERMatter
    MindOVERMatter Active Member
    Tampa Bay area FL.
    Tacoma TRD Sport 4x4
  5. Mar 15, 2013 at 11:47 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Shit, damn 6.4 PS holds 14 qts. I used a 5 gallon bucket. PITA though! Needed a larger catch pan. Maybe the fumoto makes sense! :p
  6. Mar 15, 2013 at 11:48 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Beats the classic -- double gasketed my oil filter!
  7. Mar 15, 2013 at 11:50 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Nice one haha
  8. Mar 15, 2013 at 11:50 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    But uhh, never once in 68k miles have I changed that stupid crush washer. Not a drop ever leaked.
  9. Mar 15, 2013 at 11:51 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Well that was my dad :p
    I always clean the mating surface just to make sure for this reason.
  10. Mar 15, 2013 at 11:51 PM
    MonkeyProof
    SoCal- SGV
    Yeah..hand tight untill I can't turn it any further..no need for a oil filter wench.
  11. Mar 15, 2013 at 11:52 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Till gasket meets base and a 1/2 turn more. I never need a wrench to take my filters off.
  12. Mar 15, 2013 at 11:57 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Not needed.
  13. Mar 16, 2013 at 12:21 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ditto.
    Never doubled one because of this practice, but in 40 years, I've had 4 or 5 stick to the block. Happened most recently on my motorcycle, the Duramax, and Tundra.
  14. Mar 16, 2013 at 12:22 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    It makes it easier! :p
    In the end if you're the only one doing it, do what works best for you, but I think it'd save you some effort.
  15. Mar 16, 2013 at 12:23 AM
    #35
    Rich91710
    Rich
    Los Angeles
    08 Base
    Hand tighten only.
    I bring it into contact and then hand-crank 3/4 to 1 turn beyond.
    I do need a wrench to remove, but never use one to install... especially with a strap wrench, it's too easy to collapse the can and damage the element.
  16. Mar 16, 2013 at 9:28 PM
    #36
    Rich91710
    Rich
    Los Angeles
    08 Base
    True true.
    I used to use a cap wrench to install, and still do on my bike, but never more than 1 turn beyond contact.
    The Toyota gasket is more of an O-ring, and getting more than 1/2 turn takes a bit of muscle by hand, so that's about all it gets.
  17. Mar 16, 2013 at 9:31 PM
    #37
    BamaToy1997
    Bill
    Navarre, FL
    OP, as a suggestion, use cardboard instead of newspaper as a base. Wind won't affect it as much.
  18. Mar 31, 2013 at 10:10 AM
    #38
    jcman01
    jcman01 Well-Known Member
    Buck
    Colorado
    2015 Offroad, 6-manual, Blue Ribbon Metallic
    Not a prude nor religious, but you lose a lot of credibility with your GD this and GD that. You sound like an uneducated loser.
  19. Mar 31, 2013 at 12:04 PM
    #39
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    What a tard! Who the hell with any kind of common sense puts a drain pan full of oil INSIDE the cab of the vehicle? What's even more scary is this guy is performing instruction to others...:eek:
  20. Mar 31, 2013 at 12:21 PM
    #40
    MonkeyProof
    SoCal- SGV
    What the hell?
    :popcorn:
