Oil Change With Skid Plate - 2025 Tacoma Pro
Discussion in '4th Gen. Tacomas (2024+)' started by Fastbolt, Jul 10, 2025.
  1. Jul 10, 2025 at 12:17 PM
    Fastbolt
    Fastbolt [OP] Member
    SW PA
    White 2022 Toyota Tacoma TRD Pro
    ReTraxPro MX Bed Cover, Miller Cat Shield
    Apologies if this has been asked/answered, but I was unable to find same.
    I will be taking delivery of a 2025 Pro sometime in September. As relates to changing oil, specifically the filter, can anyone advise if it is necessary to remove the entire skid plate which is heavy, in order to reach the drain plug and filter? My 2022 Pro's skid plate had a removeable service panel that permitted access to the filter and a circular hole that permitted egress to the drain plug.
    Thanks in advance.
  2. Jul 10, 2025 at 12:23 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
  3. Jul 10, 2025 at 12:26 PM
    Fastbolt
    SW PA
    I checked that thread but may have missed it.
    Thanks.
  4. Jul 10, 2025 at 12:46 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Yes
  5. Jul 10, 2025 at 1:41 PM
    2battranger
    2battranger Active Member
    Paul
    25 Tacoma TRD Off Road
    3.5’’ Rough country lift
    Just did my first oil change yesterday, TRD Off Road. But I added the one piece heavy aluminum skid plate your getting. It has to be removed to get to filter and drain plug.
    it’s made with 2 of the 6 bolt holes slotted so you leave them in. It’s kind of a pain but the slotted holes make hanging back up really easy.
  6. Jul 10, 2025 at 2:10 PM
    Fastbolt
    SW PA
    Many thanks for the timely reply.:thumbsup:
  7. Jul 10, 2025 at 6:52 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I installed a Trailhunter skidplate on my OR. I assume it's the same steel plate?
    I put the truck up on ramps, scoot under on a creeper, loosen the two slotted bolts, remove the others, and then lower the plate on my chest and roll back out.
    Easy peasy. Same with the reverse.
    However, I can tell you that it's a much cleaner job with a Fumoto valve. Without it, the black goo really shoots out.
    OregontoBajaCA likes this.
