Oil change
Discussion in '4 Cylinder' started by Babbar Khalsa, May 6, 2011.
  1. May 6, 2011 at 7:55 PM
    Babbar Khalsa
    Babbar Khalsa [OP] Member
    Manjot
    Cooper City FL
    03 PreRunner SR5 2.7l
    Stock
    Hey everyone i have 100k miles on my tacoma 2.7l and am about to do an oil change soon. What type of oil should i put in now? 5w 30??, 10w 30?, High Mileage?
    I highly appreciate your help
  2. May 6, 2011 at 7:57 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    +1. I believe that engine calls for 5w30.
  3. May 10, 2011 at 4:00 PM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Amsoil 0w30. End of story, anything else is a waste.
  4. May 10, 2011 at 4:25 PM
    frog13
    frog13 Well-Known Member
    I'd go with whatever the manual recommends!.
    Synthetic at this point and time may give you some "leak" issues.This is where synthetic has received some bad publicity....when folks put it in older engines.Some folks have experienced leaks when they switch their older vehicle to synthetic...this is due to years of using "dino" oil...the acidic "build-up" creates degradation of the gaskets.When synthetic oil is used ,the owner sometimes experiences oil leaks when they did not have them before.....the reason for this is because synthetic oil has better flow characteristics than dino oil...it is not more "slippery"...this is still oil,not an oil additive like slick-50 and the like.Stay with the dino oil and change it often.Folks also get into the mind set that since they are running synthetic,they can run longer than usual...this is not the case...these are still internal combustion engines....synthetics are actually used for EXTREME CONDITIONS,I know, someone will chime in and refute every word that has been typed....oh well.
  5. May 10, 2011 at 4:29 PM
    bowhunter11199
    bowhunter11199 Well-Known Member
    no man sounds like you put some serious thought into it^^^^^:thumbsup:.
    but what about if its been running on synthic for whole life/before the 100,000 mile mark?
  6. May 10, 2011 at 7:54 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    100k for a Toyota truck engine isn't that much, actually. Just use whatever you've been using.
  7. May 12, 2011 at 7:58 PM
    bowhunter11199
    oh ya i know.i was just asking.i have 151,800 and running mobile 1 syn(5w-30w) with mobile filter( i freaking drop like 60 bucks each oil change) and i change it at every 2500 miles. mabey a little over kill :D
  8. May 12, 2011 at 8:36 PM
    Gonzoso
    Gonzoso Well-Known Member
    Keith
    NE PA
    2000 5spd 2.7L 4x4
    Tool box, Bedliner, Not too much yet as I bought it 4/28.
    How are you spending 60$? I get my oil at wal mart for 24$ for 5 quarts and I order filters online, I got 3 toyota oem filters for like 18$.
  9. May 13, 2011 at 8:54 PM
    bowhunter11199
    at oreilys(only place in town) its 9.99 per quart(but i have some connects and get it for 7.00 a quart) and mobile 1 filter is like 19.99 ( but i get it for 15.00). then i buy restore oil additive( supposley garenteed to restore power/seal piston rigs) thats like 7.99 so that add up to 57 then plus tax takes me over 60
    and for some reason i change it every 2500 miles:rolleyes:
  10. May 19, 2011 at 2:59 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    The filler cap has some numbers on it that indicate the viscosity you should use. Any brand with the API-SM specification is fine: Castrol, Valvoline, Pennzoil... whavever your flavor. I used to insist on name brand oils but modern oils are all high-quality. So I will use whatever is on sale, including Peak (NAPA brand), O'Reilly brand oils, and Flag. They are totally fine because they have the API logo and the SM classification. The best kind of oil is the kind that's changed reguarly, that's most important. Never miss an oil change.
