Oil Change
Discussion in 'Canada' started by Toyoghi, Dec 22, 2011.
  1. Jan 5, 2012 at 12:21 AM
    Toyoghi
    Toyoghi [OP] Well-Known Member
    Shoghi
    Vancouver, BC
    2011 Tacoma Double Cab
    Solid tri-fold Tonneau, Deezee Bed mat, Pop n Lock.
    the toyota filter is a wopping 7 bucks. The phram is what 5 or 6? for a buck difference isn't it better to be safe?
  2. Jan 5, 2012 at 6:51 AM
    Gatorstaco
    Gatorstaco Well-Known Member
    ontario
    07 X-Runner
    Cold air with scoop, JBA exhaust, all AMS oil, tonneau cover, hitch, extra LED light(back). Scan gauge II. Sirius radio
    If you can, cut the filter open and you can see how the filter is made. The fram XG 3614 is well made as for the Amsoil. The less expensive one may be of less quality
  3. Jan 5, 2012 at 2:43 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Don't bother. Chris4x4 cut open a shit ton already. The OEM Toyota one was the one of the best for build quality and filter material as well as amount of filter medium available in the filter.
  4. Jan 10, 2012 at 9:55 AM
    HipHead
    HipHead Well-Known Member
    Jeff
    Gilford, Ontario
    09 Access Cab V6 4L 6 Speed TRD Off Road
    Weathertech bug deflector, Uguard side step, tri-fold tonneau cover, Weathertech floor mats
    Ok. I went ahead and purchased a Toyota OEM oil filter. And used 5W 30.
    Done many oil changes before. And this one went well too. But I have a question about draining the oil from the oil filter. How does one prevent the oil from leaking from the filter?
    I realize there is a drain plug where a hose can be connected to drain the oil under the oil filter holder. But I was unable to remove the plug. How do you connect a hose?
  5. Jan 10, 2012 at 12:29 PM
    BRONSON
    BRONSON Member
    Saskatoon, SK
    '09 TRD Sport DCLB
    The rubber plug should slip right off, it's just friction fit. A length of 5/16" I.D. hose will then slip over the drain down to your oil catch, or you can just wedge a small container under there. Loosen the filter a few turns and let it drain.
  6. Jan 10, 2012 at 3:09 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Yup. Just pull that fucker off. It won't be easy but it can be done.
  7. Jan 10, 2012 at 3:47 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    See this link on why to buy OEM Filters:http://www.tacomaworld.com/forum/te...-oil-filter-made-thailand-vs-competition.html
  8. Jan 11, 2012 at 9:49 AM
    HipHead
    Jeff
    Gilford, Ontario
  9. Jan 11, 2012 at 9:52 AM
    HipHead
    Jeff
    Gilford, Ontario
    Just to make sure I understand. The rubber plug slips off? Or there is a sleeve on the rubber plug and the sleeve slips off the plug?
    I was able to turn the plug in both directions but wasn't sure how to disconnect from the oil filter holder.
  10. Jan 11, 2012 at 3:08 PM
    BRONSON
    BRONSON Member
    Saskatoon, SK
    '09 TRD Sport DCLB
    The rubber plug itself slides straight down. It's basically a condom covering an inch or so metal extension (the drain hole) on the filter holder, which is what you then slip your 5/16" drain hose over. I'm not even sure why the rubber plug is necessary. I left mine off last oil change.
    http://www.tacomaworld.com/forum/technical-chat/11201-ultimate-oil-change-thread.html
  11. Jan 12, 2012 at 10:48 AM
    HipHead
    Jeff
    Gilford, Ontario
