oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Nov 23, 2008.
  1. Nov 23, 2008 at 9:47 AM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    i want to do my own oil change instead of paying 80 dollars for one.
    1. im too broke
    2. i want to learn...
    can u guys help me out
  2. Nov 23, 2008 at 9:59 AM
    TengoTaco
    TengoTaco Wish i was wheelin
    Tyler
    San Diego, CA
    2001 TRD stock
    None
    First you will have to get the supplies.
    Oil Filter
    Oil
    Oil Plug Washer
    Wal-Mart has some good prices. Esp. if you use Mobile 1. You can look up your oil filter number in books they have. You will then have to make a trip to the dealer. Get the oil drain plug washer for around a dollar.
    Its best to change oil on a hot engine because the oil flows out better.
    First unscrew the oil fill cap and set it to the side. Next get under the truck. Find the drain plug and remove it. Have an oil pan handy and let all the oil drain into the pan until it stops. Remove the oil filter let it drain. Get the new oil filter. Put some oil on the rubber seal and put it back on. Making sure its snug but not over tight. Then get the oil drain wash and bolt put it back on. Fill your truck with the new oil and put the cap back on.
    And your done! :bananadance:
  3. Nov 23, 2008 at 10:16 AM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    That's pretty much it, I would add that you should probably pick up a filter wrench, it'll make taking the filter off much easier. On the V6 the oil from the filter will want to drip all over your serpentine belt and pulleys. Do whatever you can to keep that to a minimum. Good Luck!
  4. Nov 23, 2008 at 10:31 AM
    Marioso
    San diego Ca
    can anyone post pics? am i asking for too much? hehe sorry but id really appreciate it
  5. Nov 23, 2008 at 10:53 AM
    Joe B
    Joe B Well-Known Member
    The Tacoma V6 is one of the easiest oil changes.
    A 15 minute job.
  6. Nov 23, 2008 at 11:07 AM
    traderdell
    traderdell Member
    I pick up my first Tacoma actually my first Toyota tomorrow so I am interested in this as well. How many grease fittings are there to take care of at the same time as changing the oil?
  7. Nov 23, 2008 at 11:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  8. Nov 23, 2008 at 12:23 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    The thisng to do is have someone who has done this before help you the first time. Hands on is the best way to learn.
  9. Nov 23, 2008 at 12:25 PM
    grivera
    Hanover, MD
    BTW, don't get obsessed over the "washer" thing. It is hardly necessary to change the drain plug washer everytime you do an oil change. I've been doing oil changes on all of my vehicles for over 20 years and only changed washers about twice. I've never had a leaky drain plug seal.
  10. Nov 23, 2008 at 12:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmm....I tried to not replace mine a few times, and 2 out of the 3 times, they leaked. Not bad, but just enough to leave a film of oil on the pan.
  11. Nov 23, 2008 at 12:52 PM
    grivera
    Hanover, MD
    That's interesting. The second one I ever changed was on my 06 Camry, at about 70K. I only did so cause it was distorted. The other was on my 99 Durango, same issue. Guess I've been lucky...
  12. Nov 23, 2008 at 1:50 PM
    Marioso
    San diego Ca
    no worries guys i did it...very easy...take off the cap, drain the oil, swap out the filter, close the oil drain hole, fill it...drive around i paid 64 dollars for everything usually the oil change costs me like 74
  13. Nov 23, 2008 at 2:00 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    and dont use recycled engine oil
  14. Nov 23, 2008 at 4:33 PM
    TengoTaco
    Tyler
    San Diego, CA
    2001 TRD stock
    None
    Like the old oil people bring back to autozone after the oil change? I bet its cheap. :p
  15. Nov 23, 2008 at 5:08 PM
    grivera
    Hanover, MD
    x2
  16. Nov 23, 2008 at 5:19 PM
    MusicOn
    MusicOn Member
    Virginia
    09 4WD TRD Sport
    TRD Cat Back
    FYI - I picked up a bunch of the gaskets (oil plug washer thingy) for about a buck apiece at Napa - I even had my choice of classic metal or metal with rubberized coating!
  17. Nov 23, 2008 at 5:23 PM
    Lentsnh
    yeah but its terrible for your engine, my sister's Acura TSX started to run weird when she it. she got it bc it was cheap
  18. Nov 23, 2008 at 5:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!
    My Brother used gasoline that he used to clean parts in to fill his F250's engine after an oil change. He was drunk and thought it was the "good used oil". He filled the crank case, started it up, and BOOM!
    SO, dont do an oil change when drunk. :D
  19. Nov 23, 2008 at 5:53 PM
    Marioso
    San diego Ca
    64 dollars
    6 quarts of at 6.99 each
    one oil pan 2.99
    one funnel 2.39
    oil filter 10.99
  20. Nov 23, 2008 at 6:05 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
