Oil change
Discussion in '4 Cylinder' started by 808tacomas, Jan 8, 2013.
  1. Jan 8, 2013 at 11:25 AM
    808tacomas
    808tacomas [OP] Well-Known Member
    kingrob
    oahu
    2011 toyota tacoma 4door 4 cyl.
    working on it..need some advice
    Hey TW. I'm doing my first oil Change. I have a 2011 tacoma. 4 cylinder. 2.7L. Double cab. Can you guys help me out with what engine oil I should use and what oil filter I should get. How much engine oil should I get? Thank guys
  2. Jan 8, 2013 at 11:28 AM
    smurf taco
    smurf taco Well-Known Member
    Brian
    Hobe Sound, Fl
    speedway blue 09 prerunner sport 2wd
    brite ass led headlights and fogs, fuel hostage wheels, mellow tone dual exhaust, black westin bull bar, go rhino nerf bars, toyota neoprene black and blue seat covers, image dynamics door speakers all around, Bilsteins 5100s all around set at 0 with maxtrac spindles and eibach coils and total chaos UCAs with OCtaco brakelines all around and all pro expo leafs in the rear running 295/70/17 cooper ST Maxx, cobra cb radio w/ 3ft fire stik, bed lights, jvc double din head unit, AC in cab mod, AFE CAI...more mods to come
    if you go to your local auto parts store then can search up your truck and tell you everything you need to know as far as how much oil to get. idk know much and the 2.7L. if i were you i would use the mobil 1 oil and the toyota OEM filter
  3. Jan 8, 2013 at 12:07 PM
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    Buy 6qts of Mobil 1 ow20 from Walmart and a Toyota filter put 5.5 qts in
  4. Jan 8, 2013 at 12:09 PM
    808tacomas
    kingrob
    oahu
    Sound good
  5. Jan 8, 2013 at 12:10 PM
    808tacomas
    kingrob
    oahu
    Thank bud. I'm actually going to wal mart rite now.. Lol
  6. Jan 8, 2013 at 12:12 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    4 cyl takes 5.5 qts like the 6 does?
  7. Jan 8, 2013 at 12:28 PM
    TwzteD
    Kyle
    St Lucie Fl
    5.5 will fill it right to the top o the full line of the dipstick.
    Walmart is the cheapest place to buy oil, and the Toyota filter is way better than most aftermarket brands like Fram and what not. Plus my dealer offers buy 3 get one free wich I take advantage of.
  8. Jan 8, 2013 at 2:38 PM
    tlh178
    tlh178 Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    thats the program i'm running in my 2012 R/C 4x4. don't see how anyone could beat that protection!
  9. Jan 8, 2013 at 2:49 PM
    TwzteD
    Kyle
    St Lucie Fl
    pretty much cant!
  10. Jan 8, 2013 at 9:40 PM
    808tacomas
    kingrob
    oahu
    i just got the fram because they didnt have any toyota filters. can i put the new oil around the oil filter seal or use the old one?
  11. Jan 9, 2013 at 4:37 AM
    TwzteD
    Kyle
    St Lucie Fl
    Yea put clean oil on seal, Walmart don't sell Toyota filters gotta get them from dealer but ask them about any deals like buy 3 get 1 free.
  12. Jan 9, 2013 at 5:16 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    You might want to consider filling the filter up with new oil, it helps the oil pressure to build up faster when you first start it up. The oil you put in the filter is part of the 5.5 qts total, not in-addition to it.
    Iv been doing this since the second oil change i did on my truck in order to stop the ratcheting sound that dry hydraulic tappets make.
  13. Jan 9, 2013 at 3:46 PM
    808tacomas
    kingrob
    oahu
    GOT HER DONE. Thanx guys. I LOVE TW!
  14. Jan 9, 2013 at 4:08 PM
    TwzteD
    Kyle
    St Lucie Fl
    No problem, oh and if you get filters from your dealer ask for crush washers, they give them to me for free with each filter, and replace it every oil change.
  15. Jan 18, 2013 at 5:20 AM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Crush Washers? With my 4 runner I would just take off the old filter drain the oil, put the new filter on add new oil. This is going to be first oil change on the truck. can you please tell me what those are?
  16. Jan 18, 2013 at 5:27 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    There should be a little washer you need to replace each time. Just a[​IMG] basic washer
  17. Jan 18, 2013 at 5:35 AM
    TwzteD
    Kyle
    St Lucie Fl
    It goes on the drain plug not the oil filter.
  18. Jan 18, 2013 at 6:00 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    So the washer is the same thing as what was referred to as a gasket from the v6 changing thread? I guess I just got confused with the terminology thanks. If your using the tube, did you find that at walmart?
    Make sure you have all you need for your Oil Change:
    Oil filter
    Oil filter wrench
    New oil plug gasket (available from dealer)
    5.5 quarts of oil
    5/16" ID 5ft long tube
    14mm socket wrench
    Oil pan
    Oil funnel
  19. Jan 18, 2013 at 6:06 AM
    TwzteD
    Kyle
    St Lucie Fl
    Yea it's a nickel size washer with like felt on it and goes between the plug and oil pan. Before you put the filter in keep filling it up till it don't take any more oil as it will absorb it, dont fill it all the way to the top (but close) or some might spill when u try to put it in. Then put a little fresh oil on the filter seal, make sure the seal from the old filter isn't stuck up on the block.
  20. Jan 18, 2013 at 6:17 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Thanks I was just confused on this washer/gasket thing. I am pretty sure I have a filter left from the 4 runner at home, I think that would fit on the Tacoma. Just don't have the washer, hopefully the dealer will have one tomorrow.
