Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by modster, Jan 29, 2016.
  1. Jan 29, 2016 at 4:39 PM
    modster
    modster [OP] Member
    2005 Tacoma TRD
    I have always taken my 2005 Tacoma to Toyota for oil change service.
    Recently, they increased the oil change price close to $50 using only conventional oil.
    So, I was there for an oil change the other day and noticed that they were having a big sale on oil filters (like $3.95 each). I bought several and was planning to do the next oil change myself.
    The parts service guy there told me that I have to replace the washer each time I change the oil. The washer is for the bolt underneath the truck where you drain the oil.
    Is this correct? do I have to replace this (paper like) washer that Toyota is charging $1.50 for?
    Please advise.
    Many Thanks!
  2. Jan 29, 2016 at 4:46 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Yes you should replace the crush washer.
  3. Jan 29, 2016 at 4:49 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    i don't replace it every time, and I've gotten them for free from the dealer
  4. Jan 29, 2016 at 4:49 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I always replace it, they are dirt cheap.
  5. Jan 29, 2016 at 4:52 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Replaced with a Fumoto drain valve. [​IMG] No more gaskets, just flip the switch.
    DrFunker, TacoDan723 and billybob50 like this.
  6. Jan 29, 2016 at 4:56 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Hmmm
    tagged for later
  7. Jan 29, 2016 at 6:02 PM
    modster
    modster [OP] Member
    2005 Tacoma TRD
    car78412 likes this.
  8. Jan 29, 2016 at 6:20 PM
    lunchbox421
    lunchbox421 Member
    California
    2015 Doublecab 4x4 SR5 Silver Sky
  9. Jan 29, 2016 at 6:58 PM
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    I have used a similar valve on a semi in the past with no issue.
  10. Jan 29, 2016 at 7:28 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    +1 they work great
  11. Jan 29, 2016 at 7:31 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
  12. Jan 29, 2016 at 7:40 PM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    I've used these since the early 80s' their great! Even though you might not do your own, it'll keep the grease monkeys from stripping your pan bolt threads.
  13. Jan 29, 2016 at 8:28 PM
    modster
    modster [OP] Member
    2005 Tacoma TRD
    Thanks Gents!
    I have ordered the valve from Amazon. It looks like the Fumoto F-103N works for my Tacoma v6.
    Cheers!
    DrFunker likes this.
  14. Jan 29, 2016 at 8:40 PM
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    I had one for years on my first gen and it was one of my first purchases for my 2nd gen. Never had a problem.
  15. Jan 29, 2016 at 8:50 PM
    Pigpen
    Dan
    Northwest Montana
    I've had mine on for at least 3 oil changes. It's great. I got the one without a nipple and am very happy with it. I changed my oil 2 days ago in wet wintery weather and it really wasn't a hassle. I wouldn't have bothered before having the valve. It does take longer to drain, but I use that time to grease the drive shaft.
  16. Jan 29, 2016 at 8:52 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    +1 on the fumoto drain valve. Can do a oil change super fast, only downtime is the oil draining! Get a little c-clamp to put on for precaution. At least that what I did.
  17. Jan 29, 2016 at 9:12 PM
    modster
    modster [OP] Member
    2005 Tacoma TRD
    Does anyone know where I can dispose of the old oil? I heard you can drop them off at any auto zones for free.
  18. Jan 29, 2016 at 9:13 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Or Firestone. Swing by your local oil/lube place and just ask.
  19. Jan 29, 2016 at 9:21 PM
    modster
    modster [OP] Member
    2005 Tacoma TRD
    Can anyone please let me know what type of oil should I use? I would like to use the convention oil like the ones that Toyota uses for oil change.
    Thanks
  20. Jan 29, 2016 at 9:33 PM
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    Always a GREAT investment! Had them on every truck.
