Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by modster, Jan 29, 2016.
  1. Jan 30, 2016 at 10:21 AM
    #41
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    The answer is you do not have to replace the washer unless it is damaged. I have never replaced mine.
  2. Jan 30, 2016 at 1:26 PM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you got metal shavings in the oil pan you already have big issues. Oh and the stock oil drain plug is not magnetic.
    You should run the engine to warm the oil and circulate the oil. This will suspend all the tiny particles in the oil and they will drain out with the oil.
  3. Jan 30, 2016 at 3:09 PM
    #43
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    If you are concerned about wear metals in the oil you could always get one of these:
    http://www.filtermag.com/
  4. Jan 30, 2016 at 3:25 PM
    #44
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
  5. Apr 30, 2016 at 12:58 AM
    #45
    eon_blue
    Azusa, CA
  6. Apr 30, 2016 at 1:04 AM
    #46
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    as with all other questions... google it. 0.24 seconds
    eon_blue likes this.
  7. Apr 30, 2016 at 1:06 AM
    #47
    eon_blue
    Azusa, CA
    yup
  8. Apr 30, 2016 at 7:54 AM
    #48
    Iowa10
    Iowa10 Well-Known Member
    Exhumed thread. It liiiiiiives!!
