Oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rlacu, Mar 19, 2018.
  1. Mar 19, 2018 at 6:34 PM
    Rlacu
    Rlacu [OP] New Member
    I have a 2012 Tacoma,2.7 engine with 52000 miles. I have changed the oil every 5,000 miles, and used Moble 1 synthetic 0W-20 oil. Up to the last two oil changes the oil from the motor was slightly dark. Now, for the last two changes the oil is almost black. Motor runs good, gas mileage is about the same. I have talked to two mechanics about this. They have no idea. Suggested that I change the oil every 4000 miles, which I will do.
    Has anyone else seen this, what could cause this, and is it a problem?
  2. Mar 19, 2018 at 6:37 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I have 47+ k miles. My oil is black every change, but blackstone labs says everything is A+. Don't sweat it... it's dirty oil.
    ARB1977 likes this.
  3. Mar 19, 2018 at 6:38 PM
    JW87
    JW87 Well-Known Member
    JW
    Richmond,VA
    2015 TRD Sport 4x4 DCLB
    American Racing black bajas with Cooper RTXs 265/70/17. Black Depo tail lights. LED interior, license plate and reverse lights.Debadged. OME 885 coils and Dakar leaf packs. OME Nitros front and back.
    What kind of filter are you using?
  4. Mar 19, 2018 at 6:41 PM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    Send it to Blackstone and you will know for certain if there is a issue.
  5. Mar 19, 2018 at 7:11 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I'm doing a 12,500 mile oil change interval per Blackstone lab analysis. 5k synthetic changes are a waste of $$ imo
    Avsfreak18 and Too Stroked like this.
  6. Mar 19, 2018 at 7:13 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Can’t judge an oil by its color. If your worried get an oil analysis done.
  7. Mar 19, 2018 at 8:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    When the oil is black it only means that the oil is doing its job and suspending the soot etc. Color doesn't mean much.
    REDdawn6, ausfahrt, spitdog and 2 others like this.
  8. Mar 20, 2018 at 10:10 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I also think its a good idea to send a sample of oil to Blackstone Labs for analysis.
    Order their free test kit online now so you have it ready for your next oil change (can take a couple weeks to get it).
    The color of your oil is not indicative of oil wear.
    Oil will almost always be black. I bet if I changed my oil, drove around for 50 miles and drained the oil it would be black. Oil doesn’t sit in a sealed unit.
    I think if you are noticing a difference in your oil color or smell after all these years it justifies a lab test. It’s cheap and easy.
  9. Mar 20, 2018 at 1:48 PM
    ausfahrt
    ausfahrt Well-Known Member
    FL & VT
    2015 SR5 MT 4X4 V6
    I am happy when my old oil comes out black, that just means that it has done it's job. Internal combustion engines have blow-by, even new tight engines have some.
    TexasWhiteIce likes this.
  10. Mar 20, 2018 at 1:54 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Has anyone received a bad report from blackstone?
  11. Mar 20, 2018 at 2:00 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I’ve seen two on this forum I think, and pretty sure both of them were doing very long oil change intervals. Not like catastrophic bad but more metals than average.
  12. Mar 20, 2018 at 2:03 PM
    TrabFTW
    TrabFTW Active Member
    Bart
    14 Tacoma TRD PreRunner Sport
    Interesting thread. So, I suppose I don't need to be doing 3k oil changes with synth blend then?
  13. Mar 20, 2018 at 2:20 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    3000 mile oil changes are a thing of the past. Do 5K as the owners manual defines as the normal interval.
  14. Mar 20, 2018 at 2:23 PM
    TrabFTW
    Bart
    Saw that, but then the maintenance light kept coming on at 3k, so figured better safe than sorry. Thnx
  15. Mar 20, 2018 at 2:23 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    I use regular oil and don’t even do 3k, I do 5k. I would probably do 10k with synthetic.
  16. Mar 20, 2018 at 2:33 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    The light comes on that early? i though it was 4750 for it to blink and when you hit 5000 its solid. Plus 5k is the recommended interval for a rotation. You sure it comes on every 3k?
  17. Mar 20, 2018 at 2:34 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Mine is 4750-5000
  18. Mar 20, 2018 at 2:34 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    I find 7,500 miles is good per change on synth 5w-30. Rather change the filter then than keep running it till 10k or change it at 5k halfway through the oil life.
  19. Mar 20, 2018 at 2:37 PM
    TrabFTW
    Bart
    Not any more. I'll have to double check now.
  20. Mar 20, 2018 at 2:37 PM
    spitdog
    So what if you drive 6k a yr with synthetic. What determines changes. Mileage wise it would mean about two yrs. OR Do you go to the yearly interval.
