Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JPC2061, Jan 19, 2010.
  1. Jan 19, 2010 at 9:58 AM
    JPC2061
    JPC2061 [OP] Well-Known Member
    J.P.
    Maryland
    2010 Black SR5
    Weather tech Floor liners, Flash Light mod, MBRP Exhaust, Grille Guard, Tinted Taillights, Side Steps, Front Windows Tinted to match rear, De badged
    Im just wondering this might come off as a dumb question but the normal mileage for an oil change is 3000 miles but in the owners guide it states to change it at a 5000 mile interval. Should I stick to the 3000 mile or what the guide says?
  2. Jan 19, 2010 at 10:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    5000 mile is fine. Best thing is to have an oil sample taken, and see what the report comes back as saying. Personally, I aim to change mine at about 3500 miles.
  3. Jan 19, 2010 at 10:00 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2010 4Runner Trail Premium
    technically you are suppose to use full synthetic and if you do that with a good filter then NO just do it at every 5000 miles... if you use regular non 0synthetic oil then its recomended every 300 miles. I would stick to full synthetic every 5000 miles. Itys better plus the light will remind you everytime you need an oil change..
  4. Jan 19, 2010 at 10:02 AM
    Death_Stalker
    Talha
    Cypress, TX
    Mind you this is under normal driving conditions ... ^^^^^^
  5. Jan 19, 2010 at 10:06 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I used to change mine every 3K-3.5K using full synthetic but within the past year I have been going to about 5K every oil change. I have an 06' with a little over 30,000 miles on it. So do the math, thats less then 2 oil changes a year!!!:eek: Damn, I need to get her out more!!:D
  6. Jan 19, 2010 at 10:12 AM
    harvey
    harvey New Member
    I like to change every 5000 with full synthetic, and change the filter at every 2500 and top off the oil.
  7. Jan 19, 2010 at 10:29 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh so you change your filter twice in between oil changes? I dont think I have ever heard of someone doing that?:confused::cool:
  8. Jan 19, 2010 at 10:47 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If anything the oil filter would probably be fine for at least 2 changes, though I change it every time they're cheap.
    The manual calls for dino based oil every 5,000mi. Not synthetic. However, I use full synthetic (Castrol GTX Syntec) every 5,000 with a K&N oil filter. Check out www.bobistheoilguy.com for reports from other users. The absolute best way to tell when you need your change intervals is to send a sample to Blackstone Labs and see what the chemical analysis is. Someone with a 2nd gen Tacoma found using Castrol that it was still fine at about 9,000mi intervals, so I guess I'm going overkill.
  9. Jan 19, 2010 at 1:54 PM
    mr2crazed
    mr2crazed Well-Known Member
    Morro Bay, CA.
    06 DC PreRunner SR5
    Interesting. Was that with dino or synthetic?
  10. Jan 19, 2010 at 2:05 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah this last oil change was the first time I went to 5K and it wasnt filthy black but just dark enough to know that it was a good time to change the oil. Oh and I run Pennzoil Platinum full synthetic with the Toyota OEM oil filter.
  11. Jan 19, 2010 at 2:19 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Castrol GTX Syntec... I'd pull up the thread but I read that several months ago... lol
    Also note, from what I read on bob was that the old GTX Syntec seems to work better than the new "better" Edge
  12. Jan 19, 2010 at 2:59 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I've never heard of this before... where is it written in the owners manual? From what I understand Toyota doesn't use synthetic for oil changes, and as far as know the genuine Toyota motor oil they sell isn't synthetic either...but they still recommend every 5,000 miles.
  13. Jan 19, 2010 at 3:09 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I prefer synthetics for reasons that have been discussed a million times on this forum, but you can go 5,000 miles or more on a quality conventional oil too. Just remember to use a quality oil filter like K&N, Mobil 1, Toyota OEM, etc.. A great filter is as important as using quality oil. I follow Toyota's guide lines of 5,000 miles or 6 months, but after the engine is out of warranty, I might extend those intervals a bit. BTW, I use Mobil 1 with K&N filters. Gotta love the 1" nut on the end and the 10 micron filter media. JMO.
  14. Jan 19, 2010 at 3:12 PM
    ElectronMan
    ElectronMan Well-Known Member
    Full Synthetics can last MUCH longer than 5000 miles. Many of the popular Mobil or Pennzoil blends can last 8-9k miles with a good filter. Dino oils can last much longer than recommended change intervals as well. Just make sure you stick with a good oil filter, I prefer the PureOne over the factory replacement.
  15. Jan 19, 2010 at 3:18 PM
    Tacoda
    Tacoda Well-Known Member
    Adrian
    Virginia
    2010 DC Sport 4x4
    I used to change my oil and filter every 3,000 miles even though I used synthetic oil, Mobile. I have since concluded that I was just wasting money. Now I use the same oil and change my filter and oil on 5,000 intervals. The oil could probably last longer. If I were using non-synthetic I would probably change at 3,000 miles even though the manual says 5,000 - your truck won't suffer from earlier oil changes, only your wallet.
  16. Jan 19, 2010 at 3:29 PM
    ElectronMan
    If you ever feel frisky enough you should get a lab to do a Used Oil Analysis for you. I would recommend Blackstone Labs as they are very reputable and make solid recommendations on your oil usage.
    Here is a sample of their work. UOA is from an 06 Charger using Pennzoil Platinum and 10k miles on the oil.
  17. Jan 19, 2010 at 3:49 PM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    Is anybody else running the Synthetic 0W30 Mobil 1? I tried it the last oil change and I have about 2400 km on it and it is just starting to turn amber. No oil consumption showing on the dipstick. How much does it cost for the oil analysis?
  18. Jan 19, 2010 at 3:58 PM
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    IMO, that's the perfect oil to run in your 4.0, especially in a colder climate. I have no idea what the cost of an oil analysis is. I hope someone answers that question, because I would like to know myself.
  19. Jan 19, 2010 at 6:19 PM
    ElectronMan
    UOA from Blackstone is $22 I believe. There are other quality labs out there.
  20. Jan 19, 2010 at 6:36 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    x10000000000000000000000
    Changing a synthetic oil out at 5K is still a waste of money since a good synthetic can last twice that interval. A good filter such as a Pureone, Wix, Mobil 1 or K&N or any synthetic media filter will last just as long. A lot of people still go with dad's old oil change interval of 3K because that's what was thrown down our throats for 40 years. Many dino oils last beyond this interval as well, but hey it's your money, waste it as you see fit, and if it helps you sleep at night. I prefer to conserve oil since the price is constantly going up, and over time becoming a more rare resource. I have no worries going over 5K using Pennzoil Platinum and Pureone.
