Oil change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alquimista, May 7, 2021.
  1. May 7, 2021 at 6:22 AM
    Alquimista
    Alquimista [OP] Well-Known Member
    México
    2012 TRD Sport 4x4 Double Cab
    Hi,
    I have a Tacoma 2012 4x4, 143,000 kms. For the last 3 years I have not used it much. In March 2020 I was recommended to use Mobile synthetic oil, and a special oil filter for this type of oil, and so I did. By March 2021, the truck had only run 3,000kms since the oil change, and checking it seems still celan.
    In the Toyota shop they recommended to change it, even when synthetic may run up to 15,000 kms. A mechanic friend of mine, tells me that the synthetic does not loose properties as the mineral oil does, and I can wait until 10,000 or 15,000 kms.
    Opinions?
  2. May 7, 2021 at 6:31 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would just do what your manual says.
  3. May 7, 2021 at 6:33 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Oil Thread.... IN!
    BTW: do what the manual states and use OEM filters.
  4. May 7, 2021 at 6:40 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Here we go! lol
    I’ll give you my experience. I’m at 160,000 miles on the motor.
    I go 15,000 km between oil changes using Mobil 1 and a factory filter. my oil analysis reports show no signs of early wear and the oil still has its properties remaining.
    I just had the valve covers off to change the cam gears and everything looks amazing.
    I have no indications that I’m doing any harm by running 15k km OCIs.
    willie2 and Alquimista[OP] like this.
  5. May 7, 2021 at 6:52 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Are those 3k severe duty? Dusty, short cold trips, very hot operating environment. Not so much about the oil, synthetic is fine at that life, it’s about the additive package and debris.
    Getting it up to temp most trips helps get fuel residue and water to evaporate out. Mostly short cold trips is hard on oil life. Antioxidants and detergents are sacrificial in nature. If you just did normal driving the past year, it’s probably still fine.
  6. May 7, 2021 at 6:55 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Listen to the people that made it they have a pretty good ideal. Between all of the Toyota's I have owned it's pretty close to a million miles.
  7. May 7, 2021 at 7:00 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I run 20w-50 diesel oil in mine.
    asuchemist likes this.
  8. May 7, 2021 at 7:03 AM
    Alquimista
    México
    90% of those 3K where regular high way trips. 10%, city drive. No off road. Temperatures, between 10 and 35 Celsius, nothing extreme
  9. May 7, 2021 at 7:04 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You'll be fine. I ran 12 month 7500 mile oil changes in my 2nd gen in conditions ranging from -50F to +100F, on/off road, towing, idling to warm up daily, etc and had no indications of any wear on oil analyses.
    Alquimista[OP] likes this.
  10. May 7, 2021 at 8:50 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I love oil threads
  11. May 7, 2021 at 9:04 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    The oils been sitting in the crankcase exposed to temperature changes and the condensation that goes with it for a year. Sounds like you possibly didn't get the engine up to operating temperature for long enough, and enough times, to burn that accumulated moisture off. Depends on your climate temperature ranges and humidity.
    If it was my engine, I'd play it safe and change the oil. But many will probably disagree. I just don't like taking changes with an expensive engine because of a simple oil change.
    That's just my cautious 2 cents worth.
    I can never resist an oil thread :bananadance::broccoli::dancingbacon:
  12. May 7, 2021 at 9:05 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Id keep oci’s at 5k to keep things cleaner, regardless of what flavor oil you run
  13. May 7, 2021 at 9:06 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I run only pure white vinegar and change it every 3 mikes.
    No problems yet.
  14. May 7, 2021 at 9:07 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I believe the OP question is related to time not distance -- the oil has been currently been in the engine for a year.
    If he waits until 10-15K the oil will be in the engine 3 to 5 years at the current rate of driving.
  15. May 7, 2021 at 9:09 AM
    Key-Rei
    Key
    Florida
    LoL yes. Oil can turn acidic over time if left to set.
    I believe mobile1 states directly on the bottle to change every Nk miles or every 12 months IIRC because of the above reason.
  16. May 7, 2021 at 9:13 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    There are lots of us in this predicament now. Every year feels adequate.
    Accipiter13 and R0dzilla75 like this.
  17. May 7, 2021 at 9:21 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Are use mobile one full synthetic but I still change my oil every 5000 miles
  18. May 7, 2021 at 9:35 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Once a year sounds like a good plan.
    Geeves77, Chris(NJ) and spitdog like this.
  19. May 7, 2021 at 10:07 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Once a year regardless of mileage.
    Spizike231, Geeves77 and spitdog like this.
  20. May 7, 2021 at 10:12 AM
    spitdog
    I’m at once a year and I drive right at 5k, give or take 1k
