Oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sktshtr1, Jun 28, 2021.
  1. Jun 28, 2021 at 6:43 AM
    sktshtr1
    sktshtr1 [OP] Active Member
    Wisconsin
    2019 TRD Sport DCAT
    New to forum. I got my 2019 TRD Sport AT last January with 14,000 mi. It has 18,000 mi. on it now. I know the manual says every 10,000 mi. Oil looks really clean yet so do I wait or do it sooner. And why is there not an access cover for the oil filter housing on the skid plate? Thanks.
  2. Jun 28, 2021 at 6:46 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    I’m not familiar with the sport . The off road skid plate has one .
  3. Jun 28, 2021 at 6:52 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Check your Owner's Manual (OM) for the oil change interval. IIRC, it is 5000 miles. Some will debate the interval length. My thoughts are oil/filter are cheap and too often causes no damage. Follow the OM.
    If this was my truck, I'd change the oil/filter, reset the Oil Change reminder and just drive. An alternate is to stop at Toyota to have the Service Desk run the history on your VIN, then get a print out of the record.
    Malinosan likes this.
  4. Jun 28, 2021 at 7:01 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    10k is the common interval for synthetic these days and is what Toyota care does. What does your window sticker say? I would guess your previous owner probably had it changed around 10k with Toyota care or the dealer did it before you bought it?
    gsubioguy likes this.
  5. Jun 28, 2021 at 7:07 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    10k recommended. 5k if you just want peace of mind. I believe the only thing with a true access hole is the TRD Pro skid plate. The TRD Off Road does NOT have an access hole. You have to remove the entire skid plate which isn't terrible because it allows you to dump out all of the dirt and debris that has collected up there.
  6. Jun 28, 2021 at 7:11 AM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    The pro skid plate has one.
    The off road skid plate must be removed.
    My guess is that the op’s truck has the pro or an aftermarket skid.
    BSFord likes this.
  7. Jun 28, 2021 at 7:29 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I just did an oil change on my OR last week, it DOES NOT have an access plate for the oil filter. You'll have to remove the skid plate, but its not too difficult, and gives you an opportunity to inspect around to check for leaks, etc.
    Some pro tips: when you remove the bolt on the bottom of the oil filter canister, there is a small rubber o ring gasket, make sure you replace that---it should come with your OEM filters. There is a plastic tip which gets inserted into the bottom of the filter housing, which drains the remaining oil so its not a shit show when you take your housing off.
    If it was me, i would replace the oil. You never know what the previous owner changed it with, how they did it, or anything like that. Start fresh and give yourself peace of mind by doing it correctly. Never know if dealer or owner forgot to change the filter or fucked up the gaskets
    Also, manual says 6.2 qts, when i did mine, i drained all the oil, added 6 qts even and just moved on. I checked the oil the other day and its at about 3/4 on the stick so i just added a bit and we're good to go. You'll notice when you first change the oil its really really really difficult to read oil since its so thin and clear. So for me, i dont even check oil level after i change it, i add 6 and just drive it for a week or so until it darkens a bit
    Hope this helps
    mquibble and ceh527 like this.
  8. Jun 28, 2021 at 7:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    An access cover would take a minimum of two fasteners. The stock thin skid takes four fasteners and is pretty light, so Toyota probably figured it wasn't worth the trouble to deviate from the 2nd gen design.
  9. Jun 28, 2021 at 7:52 AM
    sktshtr1
    Wisconsin
    2019 TRD Sport DCAT
    Many thanks to all who responded. Good advice. I'll just change it and be done with it. Installing Fumoto oil drain plug also. Any thoughts on that?
  10. Jun 28, 2021 at 7:59 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    For those buying Mobil 1, $10/5qt (max of 2 rebates per address) going on at the moment with w-mart having it on rollback. Makes it ~$12/5qts depending on your taxes. I just submitted mine for rebate last week which was already approved.
    Oh and that 0-20 comes out fast and furious so better have some good ground coverage around the pan as it'll splash out of anything you have.
    gsubioguy and Tacowin1013 like this.
  11. Jun 28, 2021 at 8:03 AM
    Tacowin1013
    Used to always be $12/5 qt, oh well still better than nothing! Makes the oil changes super cheap though! I'll have to check to see how many i have left, i think i still have about 10 qts left
  12. Jun 28, 2021 at 9:20 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    10K is okay.
  13. Jun 28, 2021 at 10:13 AM
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    Not specific to Toyota but a friend who use to sell cars once told me that 10k oil change interval is mostly a marketing ploy to make a car seem like it is low maintenance. In the real world, city traffic and short trips to the mall put a car in the severe service range, meaning most drivers don't fall in the regular service 10k oil change interval even if they are not hard on their car.
    Of course, if you do short term leases or trade in every few years, then ignore the above.
    GA59SnsfGMuyW4zj and DAS Taco like this.
  14. Jun 28, 2021 at 10:28 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    With all the marketing wank it's hard to know what to believe. That's why I sent my oil (trans and engine) to be analyzed. The recommended 12k on the oil after I sent it in at 10k
    skiploder, Lt. Dangle and usmc2msu like this.
  15. Jun 28, 2021 at 10:44 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    If your oil change doesn't look like the end of a Quentin Tarantino film then you're not doing it right.
  16. Jun 28, 2021 at 12:00 PM
    Banker
    Banker Well-Known Member
    OHio
    2017 Sport TRD DCSB
    Furmoto drain plug is great. I think they have free shipping now on an email I got. I change my oil at 5,000. Overkill, maybe, but it is not that hard to do.
    soundman98 likes this.
  17. Jun 28, 2021 at 12:22 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Yes.
    verlaryder likes this.
  18. Jun 28, 2021 at 12:30 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
  19. Jun 28, 2021 at 12:47 PM
    sktshtr1
    Wisconsin
    2019 TRD Sport DCAT
    Thanks Benny, good stuff.
  20. Jun 28, 2021 at 1:17 PM
    JZinNM
    JZinNM Well-Known Member
    Southlake, TX
    2016 TRDOR DCLB
    Agreed. My fumoto's have been very handy and reliable.
    soundman98 and 44-16 Taco like this.
