Oil change
Discussion in 'General Tacoma Talk' started by mike s, Dec 22, 2023.
  1. Dec 22, 2023 at 2:38 AM
    mike s
    mike s [OP] Well-Known Member
    South Carolina
    2019 TRD OR
    I’ve been waiting all week to ask this, what are your solutions to prevent oil from splashing out of the catch when draining the engine oil?
    Mine comes out like a fire hose, and makes a mess. Maybe it’s the type of bucket I’m using.
  2. Dec 22, 2023 at 2:53 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Azza2 likes this.
  3. Dec 22, 2023 at 3:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    Thank you for making such a thoughtful gesture here in the Christmas season!
    Happy Friday to you!
    TS4x4 likes this.
  4. Dec 22, 2023 at 6:08 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    are you lifting the truck? if so, i like to get the oil catch pan up on blocks to minimize the oil free fall. especially with engined warmed oil. i use one of those storage catch pans, so the shallow initial pan is very splatter prone. i mitigate fine.
  5. Dec 22, 2023 at 6:44 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    With skid plate removed, lets you review for other potential issues.
  6. Dec 22, 2023 at 8:39 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    2x for Fumoto valve. You control how fast it comes out. Long nipple or short nipple for attaching a drain tube, or some just get no-nipple and control the speed of oil flow out. Still ... a large cardboard sheet is hard to dismiss as "useless" as a backup.
    Also Motivx makes a good oil-filter-housing removal tool that allows pre-draining the filter housing: https://www.motivxtools.com
    GilbertOz likes this.
  7. Dec 22, 2023 at 11:35 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    x3 for the fumoto valve. with the clip on hose attachment, i can easily wear a suit, and drain the oil into multiple gatoraid bottles without a problem.
    before, i was dropping somewhere near a quart onto the ground. my bad luck, it always missed the pan, and the cardboard. the last time before switching to the fumoto, i scavenged an entire refrigerator box, covered the ground wheel-to-wheel, and the entire front half of the truck, from the front bumper to the back edge of the front doors. i aimed my drain pan to where the stream ought to shoot(3" behind the oil pan), and released the oil plug. the stream hit and deflected off the edge of the pan, splattered in front of the front bumper. right where my torso was, without cardboard... my swear jar had a healthy donation that day...
    the fumoto has literally saved me $50-100 every oil change in cleanup and mathematical guesswork on stream pressure/angle/velocity.
  8. Dec 22, 2023 at 3:24 PM
    RichochetRabbit
    Smoke pouring out of the ears and grinding of gears ... :D
    My work area is rather smoke filled most of the time ... :annoyed:
    soundman98[QUOTED] likes this.
  9. Dec 22, 2023 at 3:29 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    I hold the drain pan up close to the drain plug with one hand, then with the other hand I remove drain plug. Keep holding the drain pan up high close to the oil pan as the oil starts to drain into the drain pan. After about 10 seconds there is usually enough oil in the drain pan I can then start to lower the drain pan to the ground. Once on the ground there is enough oil in the drain pan that the remaining oil doesn't splash out. I don't get any oil on the floor with this method.
    Another thing that can help is to not remove the oil fill cap until the above is done. Keeping the fill cap (and filter) in place will keep pressure in the system which will cause the draining to be at a slower rate.
    Gfenza89 likes this.
  10. Dec 23, 2023 at 4:33 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  11. Dec 26, 2023 at 5:36 PM
    PirateMica
    PirateMica Well-Known Member
    2014 Pyrite Mica SR5
    You should look into getting a Fumoto oil drain valve. Attach a hose (which is optional), flick a lever, done. Don't even get your hands dirty.
